Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Replaced color wheel sounds better color is out of whack
  • davewiede Oct 03, 2009
    The picture is on screen there is some color the people are blue.I read something about a jumper wire but not a clue where or what to do with it.Thanks Dave Wiedemann
  • SD Tech
    SD Tech May 11, 2010
    COLOR IS OUT OF WACK? MISSING BLUE OR RED OR GREEN OR JUST LOOKS ODD? Some of these sets when you replace the color wheel you have to remove a small jumper plug on another board----let me know what color looks like... sd tech
    Top Expert:
  • Samsung Master
  • 14,553 Answers
The jumper is a small rectangular plug with a band of metal across the top and is in a opening on the DMD board(the metal box on the back of the light engine -----if the plug is there remove it with either a small needle nose pliers or a hemostat.
Things looking blue point to the jumper that just needs to be removed.
Let me know what happens.
SD TECH
Posted on Oct 04, 2009
Testimonial: "removed jumper picture was excellent. Then the bulb blew such is life.Thanks very much for the info"
Noisy sounds like a fan and the picture starts to flickers multiple colors and picture is scambled.
This tv have a colors wheel.The colors wheel is dead.The colors wheel is dying,going to be dead.The tv make loud humming,noisy sounds like a loud fans or motors noises.Also the tv colors flashes black&white or multiple colors pictures and scrambled.Colors wheel replacement is difficult,never done tv repair before.Hire a tv Tech. to replaced the tv colors wheel.
Nov 16, 2010 | Samsung HLN5065W 50" Rear Projection...
My samsung HL-R5087W tv has a darker than usual picture and then it shuts off and the display has a triangle with and exclamation mark in it. Can someone help me please??? I have already replaced...
Sounds like the color wheel is going bad. Samsungs are notoriuos for this. Sometimes you can hear a whinning noise comming from your set. This is caused by the bearings in the color wheel going bad. If your set is more then a few years old. more then likly it is the color wheel. But to me, after all the color wheels in Samsungs and light engenes in the sony's, I would choose the Samsung. Has a better picture
Jul 12, 2010 | Samsung HL-R5087W 50" HDTV-Ready...
After replacing color wheel horizontal is out of whack. how do you adjust?
Hi once you've replaced the color wheel you shouldn't get any horizontal lines,if you do it might be an issue with the dmd board,This is how the dmd works: http://electronics.howstuffworks.com/dlp1.htm Basically the dmd is a chip that carries 2 million pixels that create the image and colors .When its bad it will cause pixilation,color discoloration or stripes.I found dmd with the light engine http://www.discount-merchant.com/SAMSUNG-BP41-00119E-Light-Engine-w-Color-Wheel-p/1161652.htm?Click=48173 Good luck and God bless you!
Dec 08, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
When i turn my tv on it sounds like a high pitched wine...is it the motor?? Still turns on no picture quality issues just a loud noise that accompanies the picture
Thats your Color wheel But acorrding to what I researched you have to Replace the whole optical Module part# 9NK3797086200 which is optical module,light Engine & Colorwheel Encompass Parts do not have it in stock but they List its Price $1,930.00 core refund $1,030.00 cost of total replacement is $900.00 you can call them to find out 1-800-638-3328 or try UED 1-800-648-6657. See if you can just replace The Color Wheel itself because that is what is Bad! OR are you better off to just replace the whole unit!
Dec 03, 2009 | Sharp 56DR650 56" Rear Projection HDTV
Color wheel, filter broke
There are suppliers of color wheels. But you are better of letting a professional put it in. They are not cheap & can break easily.
Apr 09, 2009 | RCA P61927 61" Rear Projection Television
Loud buzzing noise
sounds like the color wheel needs to be replaced very easy repair on that model Samsung.
Jul 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Loud buzzing sound
Hello Jack,
That buzzing might be two things. It could be the color wheel or the ballast for the bulb. To check this you will have to move the projection section of the TV out of the case and listen for the sound in the area of the color wheel and the ballast. Try removing the color wheel power to see if the buzzing stops if it does then it's the color wheel is not and the ballast is buzzing then It's the ballast, and it will need replacing or if you know electronics you could try fixing the old ballast (I would suggest getting a new ballast).
Better still if you are uncomfortable working on the set you could get a qualified TV repair person to repair your TV .
I hope this helps,
Thank you,
Shuttle83
Jan 07, 2008 | Televison & Video
Course and fine Convergence adjustments
You don't need to raplace all the resisters! Only the bad ones. Remove one lead of each fusible resister out in front of the STK's & check for the ohmage by their color band. You will find the bad one or two resisters causing your problem.
Jul 20, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Colors out of Whack on HD input 4 only
May need higher quality component HD cables? Tried switching Blue on Red? Just some thoughts.
May 02, 2007 | Philips 60PP9202 60" Rear Projection...
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
169 people viewed this question
Henry  Thomas
Henry Thomas
