Question about Lexmark Z1300 InkJet Photo Printer
Can't print from internet with my z1300. printing off line works fine.
No print with new cartridge on z1300
Try to remove and re-insert the cartridges into the printer carrier and make sure they are firmly inserted into the slot. Try to print again.
Print quality issues can be due to dirty or clogged cartridge nozzles. Try to open the Lexmark Solution Center on your computer to clean the cartridges.
On your computer, go to Start menu > Programs > Lexmark 1300 Series folder > Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
Try to print a document again to verify that the problem is fixed.
Oct 28, 2011 | Lexmark Z1300 InkJet Photo Printer
I have a Lexmark Z1300 printer. The cartridges are half full or full and the printer sounds like it's printing, but the page is blank.
Make sure you are using the correct cartridges for your printer. Try to remove your cartridges from your printer. Close the cover. Unplug and replug your printer into th power source to reset it. When the printer turns on, reinsert your cartridges. If that doesn't help, try to clean the print cartridge nozzles. Open the Lexmark Solution Center on your computer -> From the Maintenance tab, click Clean to fix horizontal streaks. Click Print. A page will then be printed, forcing ink through the print cartridge nozzles to clean them.
Mar 27, 2011 | Lexmark Z1300 InkJet Photo Printer
A faint line shows up down the middle of the page, when printing a photo
from cnet review of the product
  • Unfortunately, as with the Z1420, fast print speeds come at the cost of print quality with the Z1300. Black text prints, though nicely dark, were beset by obvious jaggedness. The color graphics print had a slightly faded look to it and color blocks showed graininess and faint horizontal striations. Barcode-style patterns were muddled, too. For our tests, we printed color 4x6 photos with the standard black and tricolor cartridges, as Lexmark did not include photo ink tanks with the test unit. The colors were dull, details were hazy, and again, the entire print was marred by graininess and faint horizontal lines. That said, nobody buys a $25 printer to print photos for framing or to create displays for a classroom science project. A $25 printer is a convenience item for occasional reference prints, and as such, the Z1300 does its job.
Inkjet printer quality
(Longer bars indicate better performance)
b.gif Photo b.gif Graphics b.gif Text Canon Pixma iP1800
Good Good Good Lexmark Z1300
Fair Fair Fair Lexmark Z1420
Fair Fair Fair
Sep 15, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
My z1300 lexmark printer is printing the words so tint i cant read it
Have you recently replaced the printer cartridges? As I would suspect this to be the initial culprit.
If they are fairly new (ie. not used or dried up), you could check the printer settings to see if the printer is set to print lightly, or in economy mode.
Dec 08, 2008 | Lexmark Z1300 InkJet Photo Printer
Z1300
try rebooting your computer, and if told that you have a print job in the queue when you boot back up go to cancel, and hopefully the will resolve you problem
Oct 28, 2008 | Lexmark Z1300 InkJet Photo Printer
Mstr2kx
Simply download the driver here:
http://www.driversbay.com/drivers/printers/lexmark/z1300/microsoft-windows-xp/
After it is downloaded , run the file and it will install everything for you.
You should be printing in no time!
Oct 02, 2008 | Lexmark Z1300 InkJet Photo Printer
Printer seems to be skipping
As the printer is printing fine from word......try to print from notepad and wordpad also.
If it prints fine then it is a problem with internet explorer or it can be also a problem with a particular website.
If you are facing the same problem with all the websites then try reinstalling Internet Explorer.
May 24, 2008 | Dell 922 All-In-One InkJet Printer
Lexmark z1300 printer - one cartridge
if you look at the options in the printer there should be an option to use the color cartridge to print black. How does this work? Well what the printer will do is mix all three colors to make a light black. This will eat up your color cartridge faster but is useful when you are out of black ink and you need to print
Apr 23, 2008 | Lexmark Z1300 InkJet Photo Printer
Lexmark Z1300 InkJet Photo Printer Logo
22 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
