Question about Kodak Professional 8500 Thermal Printer
I recently found out that this printer only prints two passes instead of three. The paper does not enter the machine from the rear for the final printing step, and after a short while the error lamp turns on red. The problem occurs both on my Power MacIntosh (!0.5) as wel under Windows(XP professional). Reinstallation of the drivers did not solve this problem. l
  • f_roelfsema Oct 03, 2009
    I shall look for material fragments in the printer. As far as I can see now no damaged parts are obvious or visible.
  • f_roelfsema Oct 31, 2009
    As I told you no broken parts were in the printer, and I cleaned it thoroughly, although the printer was not dirty, after partial disassembly of the printer and it still did not work properly, including test printing with the disconnected printer.
    I almost gave up, but today I cleaned the sensor, located in the door, with isopropylalcohol and a small cotton bud.and hereafter the whole thing worked as it should.Simple solution, other should try that before rigorous and time consuming approaches. thank you. Did I earn a free ticket?
    best wishes,
    Dr Ferdinand Roelfsema
  • Kodak Master
  • 19,396 Answers
If the problem happens with both Mac and Windows, then it is not related to software or driver, but the printer is defective.
If the error warning light comes on after few prints, that means that a paper jam is detected. if that happens regularly , then one of the feeding rollers had lost grip, or one of the paper sensors (small plastic tabs) is broken.
Check inside the printer for small foreign objects, or fragments of paper the can also cause the problem.
If that does not fix the problem, then the printer must be taken apart to inspect the rollers, and replace the faulty part.
regards.
Posted on Oct 03, 2009
    Problem Solver:
  • 7 Answers
I've got the same printerI recently found out that - 2_bing.gif / same problem. There is a solution that appears to work for me. I contacted Kodak about this several years ago before they discontinued support for this printer. It seems that its caused because the printer loses it's position with the various dye layers on the film and gets "lost". They gave me a 3 step "repair". Step 1 - remove the "green holder" that the film/dye material sits in and reinstall your film right onto the drive wheels (without holder). Step 2 - Locate the small sensor (eye) on the top side of the thermal head (there's a yellow label on my machine on the "door" that lifts up with the head attached that shows the sensor location. CAREFULLY clean that sensor with alcohol. I use a Qtip with the slightest bit of moisture ... you don't want this thing wet ... just clean.
Step 3 - there's a LED that's on the body of the machine directly opposite the sensor (when the lid is closed) that needs the same type of cleaning.
You might want to look in your machine and wipe every roller you see while you are at it with a cloth that's very slightly dampened with alcohol. Most of the time these aren't the problem if the printer actually does start feeding the paper ... at least they aren't for me.
I find that I have to do this sensor cleaning exercise every year ore so. Don't give up hope if the problem returns in a few months.
BTW, it appears that the only drivers that work in this evolving world of computers are those that were written for Windows XP. I've have no luck trying to get this printer to work with the MAC in Leopard or Snow Leopard OS and the Fusion virtual machine options didn't work either. Haven't tried boot camp with XP which I guess is the last option.
Hope this helps. If you need to contact me on this try me at rclementtx@verizon.net
Good luck.
Posted on Jan 17, 2010
Ricoh Aficio AP410N printer won't print on tray 1. Paper feeds through but no print on it. Tray 2 is fine???
Here are a couple of notes I found on the printer:
  • Before printing on paper other than envelopes, make sure that the levers inside the rear cover are pulled up. Leaving the levers lowered can cause print quality problems when printing on paper other than envelopes.
  • If you set [Paper source tray:] to [Auto Tray Select] on the [Setup] tab in the printer properties dialog box, the machine selects the tray automatically. (I imagine you'd have to enter printer Properties or Settings and choose a tray there.)
Nov 29, 2017 | Ricoh Office Equipment & Supplies
When I print a thick blue line (about 3 inches thick) is printed also. How do I get rid of this?
Go into the computer and the click Printers and then Maintenance. do all the cleaning tasks including the one that cleans the paper path if there is one.
If you are printing a line that thick the inkjet head is releasing too much ink. If your menu is on card, you can only print successfully if the printer has a straight pass door at the rear of the machine so the card remains flat. The cardstock will smudge as it passes around the rollers. You can get over this by printing on quality paper and then putting them in a menu folder. I did this with my Inn's restaurant menus. The bar snack menus were printed on card using pass though and on a laser printer..
Jul 01, 2016 | Office Equipment & Supplies
Why is the paper on my printer going through the back and coming out instead of printing?
there is a rear door on this printer if it is removed while clearing a paper jam and not placed back after the paper jam is fixed it would push paper straight out the back of the printer. It could have a paper jam also at the rear of the printer. Recommend checking rear door of printer and also check at this location if paper is scrunched up and causing a jam.
May 29, 2014 | HP Photosmart D110a Wireless E-all-in-one...
I have printed all odd # pages from a document, but my HP Laserjet 4 won't feed these pages back through to print on the blank side with even # pages. I've tried to keep the front (feeding edge) of papers...
You need to try a thicker paper, Heavier stock to double print the page. Slightly more expensive. Recycled paper typically will not work for this type of function. I had this same problem and found this was the only solution.
Oct 31, 2009 | HP LaserJet 4 plus Printer
Brother HL-2070N red "paper" light flashes after a paper jam
http://welcome.solutions.brother.com
Try this
[LED Indication]
The Paper LED is flashing.
Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document.
Clean drum unit:
The corona wire needs to be cleaned.
Oleg Andrukh IT Specialist
PhillyCopiers.com 215 364 3774
Jan 23, 2009 | Brother HL-2070N Laser Printer
Printer will not print, keeps rejecting paper saying it is too narrow. the paper is the correct size. i nee help immediately please
OK there is three places you have to check for correct papersize,-
1)In the settings on the machine
2)On the driver of the printer ,ON your computer -Start,Control panel,Printers and faxes,Right click on driver- Properties,Then you enter the correct paper size.
3)In the page setup in the program you are printing from.File, page setup,set the correct paper size.
Normaly the settings for 1and 2 you enter once and it stays there ,except if some one change it.
Every program have it's own paper size defauld settings.Check them before you print.
Let me Know
Nov 06, 2008 | HP Office Equipment & Supplies
Printer is not printing at all, just blank pages
I can help you troubleshoot your printer. Just be prepared if your printer never prints again. This is rare to say the least. I just want you to know that in advance. OK? Laser printers use a static charge applied to the paper to represent your document and then this charged paper passes over the toner and finally the toner on the paper passes under a tungsten wire heated up high enough to melt the toner into the paper. This is why newly printer pages are warm to the touch. So, with three systems doing the magic any one of them can fail due to fatigue.
To start with, when was the last time you changed the toner cartridge?
How old is your printer and how many pages per month has it printed so far, on an average?
Are you under warranty any longer?
Thanks.
Worldvet
Sep 11, 2008 | Xerox WorkCenter PE120i All-In-One Laser...
NEW HP LASERJET P3005
Paper keeps jamming under guide plate.....and buckels. Require to remove toner cart. and pull back spring loaded plate and remove jammed paper. This happens after printer sits for 1 day. If I can finally get it to print, it will continue to work.
Apr 24, 2008 | HP LaserJet P3005n Printer
Printer Error When Printing Envelopes
I had the same problem with my 7260 and I finally changed the paper type from automatic to plain paper. Go to either Properties or Preferences in your printer set up window. Somehow this turns off some sort of sensor. It might work for you, too. To the person who is using the Hallmark program, that is where I first encountered the problem, I then tried to print an envelope from Word and the same error message came up. I found this solution online from someone using a three in one printer/fax/copier so I tried it and it worked for me, too! I hope this helps......
Nov 04, 2007 | HP Photosmart 8250 InkJet Printer
Kodak Professional 8500 Thermal Printer Logo
127 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
