Question about Visioneer Strobe XP 450 - WIN 600 X 1200 DPI, 48bit, Bus-Powered - SXP4501DWU XP450
I have an error message which says document feeder is empty even when the machine has "pulled the first page down" I have downloaded driver and use paperport 12 professional as software thanks Tom
PIXMA MX330 Error message "Document in
The sensor may be dirty even if it looks like there is no paper jam. Take a bottle of compressed air and give it a once over. Make sure you don't shake or tip the compressed air as you don't want to fast freeze anything.
If this does nothing, you probably have a failed sensor which will need replacing.
Chris
Aug 18, 2011 | Canon Office Equipment & Supplies
Document feeder error message
did u guys ever use maginzes to scan documents with they will get jamed in there i would open it up cheak feeders closly ok thx nick
Feb 09, 2008 | Office Equipment & Supplies
Tip
Main Error MINOLTA DI 1611, DI 2011 Messages and Their Remedies
PAPER JAM A paper misfeed occurred in the
main unit.
Open the cover at the indicated
location, and then remove the
misfed paper. (“When the Message
(Flashing alternately)
OPEN XXX SIDE COVER
All misfed paper was not removed
from the main unit.
Check the message in the display
for the location of the paper misfeed,
and then remove the misfed paper.
ORIGINAL DOC.JAM A paper misfeed occurred in the
Document Feeder.
from the Automatic Document
Feeder.
Open the Document Feeder Cover
and the Document Feeder, and then
OPEN DOC.FEED COVER
∗REMOVE PAPER IN
BYPASS TRAY∗
Paper is loaded in the Manual
Bypass.
Remove the paper from the Manual
Bypass.
FRONT COVER OPEN The Front Cover of the main unit is
open or not securely closed.
Securely close the Front Cover.
CLOSE FRONT COVER
DUPLEX COVER OPEN The Duplex Unit Cover is open or
Securely close the Duplex Unit
Cover.
CLOSE DUPLEX COVER
DOCUMENT COVER
OPEN
The Document Feeder is lifted up
(while a document is loaded into
it).
Securely close the Document
Feeder.
CLOSE DOCUMENT
COVER
DOC.FEED COVER OPEN The Document Feeder Cover is
open.
Feeder Cover.
CLOSE DOC.FEED
COVER
TONER EMPTY The toner is empty. Copying and
printing cannot be performed.
Replace the toner bottle with a new
one.
SUPPLY TONER
PAPER EMPTY The selected paper tray has run
out of paper.
indicates the paper tray, and
“XXX” indicates the paper size.
Load paper of the specified size into
the specified paper tray.
on Dec 18, 2009 | Office Equipment & Supplies
Trying to fax, scan or copy and anytime I try the erro message Document in ADF press OK to discharge document
Hi sdrnjen977,
Here's what you can do to address the issue and clear error message: Document in ADF.
If you press the Stop button during scanning, Document in ADF. Redo operation after checking document in ADF and pressing OK. appears on the LCD. Press OK button so that the remaining document is automatically fed out.
Removing the jammed document from the Document Tray:
1. If printing is in progress, press the Stop button.
2. Turn off the machine.
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF, then open the Document Feeder Cover.
4. Raise the Paper Release Lever, then remove the jammed page from under the roller to the Document Feeder Cver side.
5. Pull out the jammed document from the ADF.
6. Press down the Paper Release Lever, close the Document Feeder Cover, then turn on the machine.
Removing the jammed document from the inner side of the Document Cover:
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF.
4. Open the Document Output Slot.
5.Open the Document Cover.
6. Insert your hand into the Document Output Slot, then while pushing up the paper output rollers inside the Document Output Slot with your fingers, pull out the document from the inner side of the Document Cover.
7.Close the Document Cover.
8. Close the Document Output Slot, then turn on the machine.
Hope this helps.
Thank you for using FixYa.
Jun 30, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Cannot clear error message "Document
Hi nigel_lester,
This error message "Document in ADF" that you are getting means that you need to remove foreign object from the Automatic Document Feeder (ADF). Kindly follow the procedure below in clearing document jams:
Document jams in the ADF (Document Tray)
1. First, press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF. 3. Then, open the Feeder Cover.
4. From under the roller to the Feeder Cover side, remove the jammed page.
5. If a document is not jammed, check the document feed area if there's foreign material. If there's any, carefully remove it.
6. Close the Feeder Cover.
NOTE:
  • If documents remain in the ADF after pressing during scanning, [Document in ADF] will appear on the LCD. Press so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (inner side)
1. Press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
4. Open the Document Cover and pull out the document from the inner side.
5. Close the Document Cover.
Note: When rescanning the document after clearing the error, rescan it from the first page.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Canon Office Equipment & Supplies
Evolis Quantum not responding
Try cleaning feeder rollers
shut feeder doors properly
Check for selection of feeders in driver
Mar 27, 2009 | Evolis Quantum ID Card Printer with Mag...
"Check Document" message
look for a switch trapped down in the document feeder
Jan 28, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Blank pages
You might want to start by doing some general print quality troubleshooting, including printing a test page. The test page should give you an indication if you have issues with print cartridges. Also, some printers may not print at all if even one of their cartridges is empty:
Correcting Print Quality Problems
The other thing that occurred to me is that your document feeder could be pulling in more than one sheet of paper at a time, this means it would output blank sheets as well. Here's a web page that describes the problem and what to do about it:
Automatic Document Feeder Error
Hopefully the answer to your problem is available in those web pages. Good luck.
Sep 07, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Document Jam Error Message on Brother MFC-8660DN
I had the same problem with a Brother MFC-8460 and called Brother's support line. The solution that worked for me was to lift the top cover where the sheets of paper go through when you fax. On the right of the black rectangluar piece with grey roller there is a slot in the tray with a black lever inside. The black piece was stuck down inside the slot and had to be popped back out. Once it was out I hit the stop button and it was fixed!!
Mar 03, 2008 | Brother MFC-8660DN 5-in-1 Laser...
347 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
Jeff Hogancamp
Jeff Hogancamp
Cosma Papouis
Cosma Papouis
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
