Posted on Oct 03, 2009
Cd stuck in disc two slot, how do I release it?
I have a Bose Wave system with a cd changer and a is cd stuck in disc two slot, how do I release it?
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Oct 03, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
1608
Points
14
Yo can try a credit card or something thin with some thin double side tape on it and go fishing, Press on the disk with the card with the tape hopefully it will stick to the disk and it will come out. Have patients and take your time be gentle you'll get it.
3helpful
How can I eject my stuck cd multi-cd changer
Had the same problem with mine.....turn it over in your lap and give it a slap..not to hard. that should work. If not, remove the cover and flip the release button located in back. good luck!!
Wave Music system Multi-CD Changer
The unit has a power supply problem, no user servicable parts inside. Bose uses a thermal fuse built into the power transformer. Take unit apart and check for connection issues first, then look for a possible fuse, if none exist chances are it is in the power transformer, contact Bose for service.
10helpful
2answers
2helpful
I have a bose wave system. I tried loading cds in the multi changer and kept showing error and never would play. The multi changer still has one of my disc and will not eject. I tried unplugging and...
Hi, The cd disc is not in his place inside the multichanger, you must open the appliance and try to take out the cd without forcing, otherwise you wil brake the mechanical system,
after this the system will work well.
Thanks.
13helpful
3answers
I have a Dvd stuck in the CD changer in disc 1. It won't eject. How can I get it out.
on the front face of the dvd is a tiny hole which you slide in a rod or pin which releases the locking catch
2answers
I have a Bose Wave Music System with add-on 4 cd changer attached. The top portion (radio & 1-cd function) is working fine. The 4 cd changer is not working, I keep getting an error message and none of...
Bose does not release their schematics or parts lists, effectively making themselves the only repair center for their products. Your only safe repair method is to contact the service/repair center at www.bose.com. They will likely offer you a flat rate repair or credit towards the purchase of a new unit.
1helpful
4answers
Playing CDs
An old post but did you get an answer and do you need a copy of the manual?
donald
36helpful
8answers
Cds Stuck in cd changer. stuck at no. 6.
i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
