Canon pixma 4200 yellow ink faded on test printout ink cartridge full have tried a deep clean. have took out all cartridges shook and put back, have replaced yellow cartridge to no avail.
  • 15 Answers
SOURCE: canon pixma ip 4200 printer problems
in the printer driver there is a option that whenever you install a new cartridge it has to be reset otherwise it shows the message the above you quoted. one more option is there that is change the chip of yellow cartridge and black, after doing this please whip circuits of the cartridge and printer carriage block before installing the cartridge
Posted on Apr 29, 2008
SOURCE: Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Posted on Jun 21, 2008
SOURCE: how to fix my canon pixma ip1000 printer will not print black ink
replace the printer head....
Posted on Jun 25, 2009
  • 5 Answers
SOURCE: my printer has stopped printing from the cyan ink
Hi, did you let the ink cartridge dry out completely before inserting a new cyan cartridge???
If this is the case you may have a bit of trouble getting the ink through the printhead...you have to persevere with deep cleaning and/or head cleaning...
if that does not work you may need a new printhead...which is usually dearer than a new printer...
I would also take the printhead out and clean the contacts with Isopropol alcohol...do not get finger prints on the contacts...that will stop it very quickly...
just a thought...did you remove the sealing tape over the airholes and bottom feeder hole on the cartridge???
if the airholes are sealed the cartridge pulls a vacuum and the ink will not flow...
hope this helps you...
cheers
haitchhcee
Posted on Dec 09, 2009
pineworks
  • 4041 Answers
SOURCE: Canon Pixma iP2000 wont print black ink?
Canon IP 2000 / reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Posted on Feb 18, 2010
New ink cartridges are installed. No error messages but printer not scanning or printing. I have deep cleansed it twice.
Scanning isn't related to the cartridges problem unless you meant copying. The instructions to align the cartridges might help, if it insists on alignment after new cartridges are added.
http://www.manualslib.com/manual/24391/Canon-Pixma-Mp190.html?page=35
Did you remove the (usually pink) tabs from the cartridges before installing?
Did you get a printout from a test page or from the cleaning operation?
Also try a removal, then reinstall of the device.
May 16, 2015 | Canon PIXMA MP190 All-In-One InkJet...
Mx860 prints too light
Replace your ink cartridges again. Seem like the print heads are busted already. Try returning the cartridges to the seller or ask to have them replaced.
Nov 23, 2013 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
The printer is recognising that the Yellow is full but when I print out a test page the yellow doesn't print. Is this a printer or cartridge issue?
try to do deep head cleaning, few times. If this doesn't helps you need to remove the ink's and print head and bottom of print head ( where are ink nozzles ) few times press on wet cloath.
Then repeat the deep cleaning.
Aug 04, 2011 | Canon PIXMA iP4000R InkJet Printer
Yellow is missing in printouts, and the color is heavily purple, even after putting in new red cartridge and doing a deep clean
Yellow cartridge is clogged or bad. If yellow is not being out put then it will throw the other colors off. You could print a yellow, light blue, magenta (pinkish) , and black squares using MS paint or other paint program. This will narrow down which cartridge has a problem.
May 14, 2010 | Canon PIXMA MX850 Multifunction Printer
Just changed the yellow cartridge. The printer says it's full. No ink. Same thing with last cartridge. Tried deep cleaning.
Ok I understand the printer says its full but are you saying your computer says no ink? or that it prints no yellow ink?
Ok assuming you mean that it prints no yellow ink, the culprit ususally means that the print head needs replacing! Call Canon with your model and you can buy the part for new print heads for your printer
Mar 16, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Canon mp530 - colors print dull and faded
The ink tanks may be full but sometimes the pins that connect the cartridges to the printer may have dried up ink on them preventing the ink from flowing. You can try to swab these with a bit of rubbing alcohol on a Qtip and letting it dry for moment or two. I would strongly suggest doing a couple of deep cleanings first and try test printing of the individual colours separately in a program such as paint to see which colour is affected.
Jan 24, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Color ink cartridge does not print in full colors
Canon printers do not like the refilled ink cartridges. After having ruined a few printers trying to "save" money. I went back to genuine Canon ink and have never had a problem since.
Jun 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon ip4200 one cartridge/nozzle does not work
Put isoproply alcohol on the nozzel with a connon swab until it melts(desolves) the drived ink.
Feb 07, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Canon pixma ip 4200 printer problems
Apr 15, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Printer problem
Hi , did you check nozzle what color appear , some ink cartidge are old stock and dry , pullout cartridge clean the contact nozzle .
Feb 01, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
89 people viewed this question
k24674
jasbo
jasbo
