Full Duplex Hi there. I have a ZyWall 35 Firewall and its set to Half-Duplex, and i cannot for the life of me find where to change it to Full-Duplex. Or the fastest speed possible. I do not have access to the firewalls command line, but i have the GUI interface up. Could you tell me where to go to change this?
    Scholar:
  • 79 Answers
By default, I think these come with auto-sensing turned on, but I may be mistaken.. do not have one available, but do have the manual link if you need it:
ftp://ftp.zyxel.com/ZyWALL_35/user_guide/ZyWALL%2035_4.03.pdf
or:
http://tinyurl.com/2k9gth
I reviewed the entire document and did not see a section on configuring duplex, although it may be in the Bandwidth section.. since they do not show all the configs, I am not sure....
Posted on Dec 23, 2007
Zywall usg 50 won't VPN to 3Com officeconnect
Check the system log of the devices. The log usually can tell you why the VPN is not working.
Apr 02, 2014 | Zyxel ZYWALL USG 50 SEC-GTW 5 VPN TUNNEL -...
NAT session table is full
For each connection (TCP or UDP) that your firewall manages to NAT (ie network translate) keeps track on a in memory table. If it gets full means you've too many open connections. This is often the case when using P2P programs such as Torrent, eMule etc.
You can:
1) reduce the connection usage on the P2P application
2) reduce the connection timeout, in order to force the firewall to close stalled connections, recovering some free entry on the nat table
3) upgrade the appliance to something more heavy duty. Any box running pfSense for example could be a good choice: the web GUI is quite similar to the ZyWall one, but the software is both free and more powerful...
Dec 11, 2013 | Zyxel ZyWALL 70 Firewall
Duplex settings.
under IP settings are there any duplex or speed settings?
Sep 23, 2013 | Cisco - Linksys Wireless-n Home Router -...
I want to block ultrasurf using zywall 2
Open App patrol, search for UltraSurf and block it.
Mar 17, 2011 | Zyxel Zywall 2 PLUS (ZYWALL2PLUS) Firewall
How do i configure my D-Link from half duplex to full duplex
By default switch ports are in auto negotiation mode that means it will auto negotiates with the other end device for the speed and duplex settings.
If you want to hardcode the switch port to full duplex then you need to log into the switch management console and under the interface settings change the duplex to full for the inetrface.
Oct 26, 2010 | D-Link DGS-1024D Ethernet Switch 24 x...
My dad is death and I don't now the password ov ZyWALL 2 plus..please help me... im ITALIAN
Hello there,
Im sorry for your father, by the way if you forget / lost your password(cannot access the web configurator you will need to reload the factory-default configuration file or use the RESET button on the back of the ZyWALL. Uploading this configuration file replaces the current configuration file with the factory-dafault configuration file. This means that you will lose all configurations that you had previously and the speed of the console port will be reset to the default of 9600bps with 8 data bit, no parity, one stop bit and flow control set to none. The password will be reset to 1234, also.
The procedure to use the reset button
Make sure the SYS LED is on ( not blinking) before you begin this procedure.
  1. Press the RESET button for 10 seconds, and then release it. The ZyWALL restarts with the defaults restored. Otherwise, go to step2.
  2. Turn the ZyWALL off.
  3. While pressing the RESET button, turn the ZyWALL on.
  4. Continue to hold the RESET button. The ZyWALL restarts with defaults restored.
  5. Release the RESET button and wait for the ZyWALL to finish restarting.
Hope it help and have a nice day,
regards
Apr 15, 2010 | Zyxel Zywall 2 PLUS (ZYWALL2PLUS) Firewall
I have zyxel zywal 35 have two wan port, wan1 connected to t1 line, wan2 connected broadband line , now the firewall configured on active/ passive mode,it was working fine but some times. fire wall lan ip...
This is due to some bad packets on your network. Check the network for any worms/spywares. Also check if the ethernet connections/card donot malfunction.
Jun 19, 2009 | Zyxel ZYWALL 35 Firewall
Port 80 forwarding
use hidemyass.com as a home page surth from hear
Jan 24, 2009 | Zyxel ZyWALL 2 Firewall
Routing problem
I don't know if this will help because I don't see what you and seeing but here is an idea: In every routing scenario I have experienced, you must specify a default gateway with a specific IP address. 0.0.0.0 only points to the device itself, not the other WANS. The gateway IP addresses should be statically assigned. If there is DHCP involved, insure that the gateway address is not part of the DHCP scope but in an excluded range of reserved addresses. For SMTP to work the gateways (and you should have 2 or 3) must be properly configured and TCP port 25 enabled.
Dec 09, 2006 | Zyxel ZYWALL 35 Firewall
Open Questions:
How to Save Data Backups for 100 Years - Data Backup and Online STORAGE Get all you important data saved safely and securely on the highly advanced online cloud backup solution of Dataalign. This facility of providing large space for online cloud backup is different from its counterparts as it makes optimal use of advanced technology to device features that helps the user to make maximum use of the available space by setting the number of versions and days you wish to keep a file after which it is automatically deleted. Also, the feature of version history helps in viewing the history of each stored file and thus, also let's undo decision mistakes if made in the past. The server cloud backup solution of Dataalign is an amazing way of backing up all your files, folders and data whether related to your business or personal. Many more amazing features of Dataalign makes it super secure and easy to use by anyone. There are different categories of backup plans in Dataalign for various uses. You can choose the plan according to your needs from home free backup, personal standard backup, social backup, personal pro backup, family all in backup and home pro all in backup. The Unified cloud backup feature of Dataalign cloud backup helps in securing data located on various platforms and in different devices at a single place. Everything on your computers, tablets, and smartphones, external drives, servers, network devices and even cloud services like dropbox automatically get imported and saved on Dataalign. The cheap online data backup of Dataalign provides easy access and retrieval of data from any place using any device. Free cloud data backup of Dataalign helps in protecting all your data like documents, photos, music, videos, contacts, messages, calendar, call logs etc. In case of situations when your device gets damaged or you want to upgrade your device, you won't have to worry about transfer of data. You can import all your data by simply installing the Dataalign cloud backup app. With Dataalign keeping all your data safe, you can search and discover documents, presentations and spreadsheets from any device. You can even discover OCR content from scanned PDFs and images. For more information and cheap online cloud backup contact Dataalign at toll-free helpline number +844387-9959.
Sep 21, 2018 | Super Computers & Internet
Computers & Internet Logo
461 people viewed this question
Alun Cox
David Payne
David Payne
