Question about HP LaserJet 3050 All-In-One Printer
I can not install fax utility - HP LaserJet 3050 All-In-One Printer
I cant seem to set up my fax for incoming
Uninstall printer prog restart, then reinstall printer programme. This time sit with computer while prog installs, it will ask you question once whole prog installs, you most likely missed the information to install for the fax part?
Nov 01, 2009 | HP LaserJet M1522n MultiFunction Printer
Can't receive faxes through ComSwitch7500 connected to fax. Have Brother 2820 connected from external port on fax to fax port on ComSwitch7500. Have also tried fax machine's line in port to fax port on...
You should be refering to the PC Fax utility. De-install all the drivers from your PC and re-install the drivers with the CD provided. Run the CD without connecting the USB cable, only connect the USB cable when prompted.
Oct 16, 2009 | Brother IntelliFax-2820 Laser Fax
I cant scan a document in my computer
During a normal installation of the HP All-in-One software, the following events occur:
1. The HP All-in-One software CD-ROM runs automatically.
2. The software installs.
3. Files are copied to your computer.
4. You are requested to connect the HP All-in-One to your computer.
5. A green OK and check mark appear on an installation wizard screen.
6. You are requested to restart your computer.
7. The Fax Setup Wizard (Windows) or Fax Setup Utility (Mac) runs.
8. The registration process runs.
If any of these things did not occur, there is most likely to be a problem with the installation. If the essential icons (Scan Picture, Scan Document, and Send a Fax) do not appear, your installation might not be complete.
If your installation is incomplete, you will need to uninstall and then reinstall the software. Do not simply delete the HP All-in-One program files from your hard drive. Make sure to remove them properly using the uninstall utility
provided in the HP All-in-One program group.
Sep 12, 2009 | HP Officejet 5610 All-In-One InkJet...
Just bought lexmark 5600-6000 series want pick up on rings to receieve faxes
Are you asking how to set the printer for the number of rings to wait before answering the incoming call? Please go to the Fax menu on the printer and set the number there. Or use the Lexmark Utility that came on the installation CD. Don
Jun 07, 2009 | Brother IntelliFAX 2800 Laser Fax
SCANNER SAYING NO USER ID
This means that you have not set up any users in the address book in the printer.
Copy is simple, it will scan the document and print out a copy of the scanned image.
Scan however, is trying to make and store an image file of the scan, but it needs to know WHERE you want to scan it to. The printer does not know where to send the stored image unless you create a storage location for it. This is done with the address book that is stored on the printer.
The material below is how to set up the scanner settings of the printer.
Printer Settings Utility Using the Printer Settings Utility window, you can set up the fax system data options, and create and edit Phonebook entries from your computer. You can also configure the destination launches when you access Scan and then PC.
When you install the Dell software, the Printer Settings Utility is automatically installed.
For information about installing the software, see "Installing Software in Windows".
To open the Printer Settings Utility:
  1. Click Start software25.jpg Programs software25.jpg DELL software25.jpg DELL Printers software25.jpg DELL Laser MFP 1815 software25.jpg Printer Settings Utility.
The Printer Settings Utility window opens.
  1. The Printer Settings Utility window provides several features; Directory (Phone Book, Address Book), Fax Setting (Fax Cover Sheet), and Scan (Destination, Resolution, Scan Color, Show Preview).
The Scan Section The Destination Section To configure the operator panel display scan destination list that appears when you access Scan and then PC, click Destination and the Setting button. Using the destination list, you can select a software program that an image can be scanned to.
Oct 07, 2008 | Dell 1815dn All-In-One Laser Printer
Fax name
Hi c_mcnair, when you install the software for you're A960 printer it also installed the Dell All-In-One Center. Within in the dell center you can change you're fax settings. To open the dell center do this, Click Start → All Programs → Dell Printers → Dell AIO Printer A960 → Dell All-In-One Center. Once opened click fax setup utility. Fax starting on page 40 in manual. Once in the fax setup utility you'll be able to change any & all fax settings. I do not have the software installed. If I did I could be more specific, step by step.
(You can't find the back space button). If this refers to you're keyboard it's just above the enter key. It's the key with the arrow pointing to the left on it. ( <------ ).
If you no longer have the user manual for you're Dell A960 you can download it by clicking on this link.
http://support.dell.com/support/edocs/systems/a960/en/a960en.pdf
You'll need Adobe reader software to read the .pdf file, AKA manual. You can download it for free.
Click this link for Adobe reader.
http://www.download.com/Adobe-Reader/3000-2378_4-10000062.html?hhTest=1
Good luck c_mcnair!
Mike
Jul 29, 2008 | Dell A960 All-In-One InkJet Printer
Scan problem
is the com utility running
is a new firewall installed
May 07, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Fax is saying no dial tone and not sending.
if you are using xp home you have to go into the utility and install the fax program its there but not installed and turned on this is most likely your problem, because once installed it will automatically hook itself to the modem.
Dec 13, 2007 | Lexmark X1270 All-In-One InkJet Printer
Configuration of LAN fax
The best solution I use is Smart Net Monitor, which is supplied with the Ricoh disks or can be downloaded from www.ricoh-usa.com . First you need to install the lan fax driver, after that then install Smartnet Monitor.
From there click start, and then control panel, then printers and faxes, then right click on the Ricoh LAN fax driver, from there click properties, click ports, then click add a port, under available ports you will see smartnet port (highlite) and then select new port, a new box will come up and then select search, the software will then make the connection and add the port. Besure to click ok and apply and then you are connected
Oct 09, 2007 | Office Equipment & Supplies
HP LaserJet 3050 All-In-One Printer Logo
Seeker5211
Seeker5211
