Question about Ricoh Aficio 1013F Copier
Ricoh 1013f with optional 2nd tray
How do you sel paper size for 2nd tray ie 8.5x14
    Problem Solver:
  • 11 Answers
You have to set it through the menu button, just scroll through the options.
Posted on Dec 27, 2007
My aficio 1013f can not scan a4 but only b5
CHECK THE PAPER SENSOR, U CAN SEE ON THE RONT OF TRAY COLOR GREEN AND SELECT THE RIGH PAPER SIZE RICH FOR U
Jan 17, 2014 | Ricoh Aficio 1013F Copier
Ricoh Aficio 1013F MFP bottom tray paper senser broke off. Where can I get a replacment?
Remove the actuator and try using super glue or adapted a little part of ABS.
Feb 16, 2013 | Ricoh Aficio 1013F Copier
Ricoh Aficio 1075 - Change paper size on TRAY 1
you need to set the dial on the back of the paper tray
May 21, 2009 | Ricoh Aficio 1013F Copier
Load paper error on and paper is loaded
you have probably knocked sensor out of position at the paper feed in area. To check you will need to remove the paper tray completly from machine, then tilt machine up in front and look where paper is fed in there should be like a black flag in that area. it is the sensor that tells machine there is paper.
Apr 15, 2009 | Ricoh Aficio 1013F Copier
Can't Print
Firstly, I have to ask......the paper is installed, and tray set correctly? Does it read the proper size on the display of the copier?
Ok....next, do you have the optional paper trays installed (3 & 4)?
Is that where the 11 x 17 paper is? Then you probably did not add the accessories when you installed the driver and when printing that paper is unavailable.
right click your printer icon, click "properties", then i think it's under the "accessories" , or "options" button....select the optional trays, and anything else you may have. click 'ok' ...should work.
Mar 19, 2009 | Ricoh Aficio 2018D All-In-One Laser...
How can I print from Tray 2 on Ricoh Aficio 1013F
It needs to be added within the printer driver.
In The Printers/faxes dialog box, "right click" the "Aficio 1013F", click "properties" click the "accessories" (or "change accessories") button, and add tray 2 as an option, Click "apply", and exit the utility, now you can manually select tray 2 when printing.
Feb 20, 2009 | Ricoh Aficio 1013F Copier
How to print 17 inch paper on Ricoh AP 3800 C
You should just be able to place paper on the tray and then select the bypass tray under "properties", "Paper", then under "tray" select "bypass tray" when printing.
Feb 13, 2009 | Ricoh Aficio 1013F Copier
Way around "load paper' error
no there isn't any way to override it you might try the bypass tray.It might work.you have to be very careful with installing and removeing the paper tray when you do get it fixed.
Feb 20, 2008 | Ricoh Aficio 1013F Copier
Ricoh 1013f Paper creasing
1- you need to determine at what point it's creasing
a) when leaving the tray
b) when getting to drum
c) when exiting copier
2- after that you need to see what the problem is,
a) small paper that was torn off causing problem,
b) is the part worn
c) something out of place
3- remove paper or replace part
Nov 12, 2007 | Office Equipment & Supplies
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
