Question about Necvox RE-8169D 8 All-In-One Motorized System Car Video Player
MY NECVOX FD 6569 SCREENS DISPLAY NO PICTURE JUST A FAINT BAND DOWN THE RIGHT HAND SIDE
I've accuired a Vizio P50HDTV10A that was dropped.
Yes, do not bother as it sounds like the display panel is damaged--time for a new set parts cost wise. Since you have nothing to lose open and examine it with the faint hope a plug is loose or off or a board cracked,,,faint chance only.
Oct 23, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Panasonic Pt-47wx53g no sound but has picture
A suggestion here--the fact you have sound is a good sign.
This set was prone to one fairly simple problem----If you turn it on and after a minute or so (sound is there) you see a faint band of white or odd noise on the screen, usually to the middle or right side of the screen (hard to see) you have a bad cap and I can tell where it is and what its value is and how to get at it and replace it---less than a 5 dollar part--but you must let me know if you see the faint band top to bottom after a minute or two.
SD TECH
This part is c509 and is marked on the board---it is a .47 microfarad cap at 200 or plus volts and many times the brown cap will have a crack in the side (not always) but if you have the band of noise it is the problem.
There is right and wrong way to get at it to replace if if it is bad.
This is what the board (right side view and on right side as seen from rear of set looks like.)
Oct 16, 2012 | Panasonic PT-47WX53 47" Rear Projection...
Monitor flickers and faint bands scroll down the
could be fixed by ajdusting the refresh rate....
you could try this (xp pro sp2)
please rate if useful, good luck
Open Display in Control Panel.
On the Settings tab, click Advanced.
On the Monitor tab, in the Refresh Frequency list, click a new refresh rate.
To open Display, click Start, click Control Panel, click Appearance and Themes, and then click Display.
  • The default refresh frequency setting is 100 Hertz, although your monitor may support a higher setting. Check your manufacturer's documentation for information regarding the settings your monitor supports.
  • A higher refresh frequency reduces any flicker on your screen, but choosing a setting that is too high for your monitor can make your display unusable and cause damage to your hardware.
  • Changes to the refresh frequency affect all users that log on to the computer.
Oct 27, 2009 | HP w1907 LCD Monitor
Tv image shifted right
Horizontal hold IC and circuit is failing The remote signal will cause it to spasm because of this faulty set of parts. It needs professional intervention to fix this properly
Sep 25, 2009 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Green av2 msge on screen when tv on
Press Display / Info button on Sony TV Remote, on-screen display will disappear.
Dec 03, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32LS60U FD Trinitron 32
Your tv has Leak cap in POWER supply its either primary or secondary power. Need to replace it. Look for a Electronic Tech.
Jan 17, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Necvox Fd 7569 Headrest monitor
NTSC and PAL you is the after you press the mode, you press up/down very fast
Sep 22, 2007 | Necvox RE-8169D 8 All-In-One Motorized...
Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Necvox RE-8169D 8 All-In-One Motorized System Car Video Player Logo
114 people viewed this question
Top Necvox Car Audio & Video Experts
xxxxxx xxx
Are you a Necvox Car Audio and Video Expert? Answer questions, earn points and help others
