Question about Kenmore Elite 45986 Front Load Washer
Water backup from sewage line
At the north end of our home there is a vertical open-ended pipe. The septic tank sits at the south end of our home and I'm told we have very little slope to the waste line. The problem is when there's too much water usage, the waste water backs up and POURS out of this pipe into our finished basement. We've had the line augered twice. Our best guess is that there's some clogging underneath the disposal.
1) what access do we have to snake from the kitchen sink?
2) why on earth is there an open pipe in a home?!?
    President:
  • Kenmore Master
  • 1,922 Answers
You have to have an aerator pipe or sewer drainage things will siphon lock, you need to raise the height of the pipe, this should remedy your problem,also make sure theres a "P" trap on this stand pipe near the base
Posted on Oct 05, 2009
How to take care of septic system?
the more time you spend on it, the best you will manage.
May 03, 2016 | Plumbing
What's the quickest and easiest way to test a septic system?
There is no quick or sure way to check, you can only look at the obvious for problems and then it is pretty much anyone's guess unfortunately. This article will give you items to look for and look at.
Apr 15, 2016 | Plumbing
Septic Tank Drain Field
In numerous septic system, waste from toilets, bowls, showers, showers, floor drains and bowls courses through a labyrinth of funneling out to your septic tank or cesspit. The septic tank is typically framed of concrete or gum in more up to date plans with either apertures inside of the tank itself or downstream in the channel or field lines on the surge side of the septic system. Restrictions prevent the waste layer from leaving the tank and compacting the drain ranges. TG Wastewater
Mar 19, 2015 | Plumbing
Sewer smell in house from septic tank and idle system
If the house has been sitting for a long time, the traps may have dried out and are not stopping the sewer gasses from being trapped back, flush all toilets and run some water in all the sinks and tubs, to refill the p-traps, also don't forget to pour some water down the washer drain pipe. HOPE THIS HELPS...
Nov 10, 2014 | Plumbing
Septic tank pump is brand new. Our alarm just went off and we looked in tank and the water is very high.... could it be a faulty pump?
could be. could also be a clogged output line, a blockage in the septic field, even a sock stuck in the intake of the pump.
Jul 31, 2013 | Plumbing
Does anyone know how a septic tank works?
Take a look at this good YouTube video so you can see how a septic tank works;
http://www.youtube.com/watch?v=uuORuwb4cfs
Jan 28, 2013 | Plumbing
What is a septic tank?
A septic tank is a key module of the septic system, a small-scale sewage handling system common in areas with no joining to main sewage pipes provided by local supervisions or private houses. Like TGWasteWater.com
Sewer Gass after using Bocsh 300 washer
When you have problems with sewer gas smells around a
fixture, there can be a number of causes.
1. Sewer gas coming back up into the home
a. Blocked vent.
b. No vent.
2. Leaking drains that cause rotting below the floor.
3. Moisture that causes mold buildup.
4. No trap on your sink.
5. One roof vent on septic system.
6. Toilet needs to be reset and calked.
Sewer gas can come back up into your home, when the
trap completely empties after a letting the water out
of a fixture, when the trap dries out, or when it is
sucked out by another fixture flushing. When water
goes into a pipe, it first has to push the air ahead
of it, if there is no place for it to go, it comes up
the trap. This causes a buildup of pressure if there
is no vent.
If there is a vent, the pressure is relieved up to the
roof, carrying with it all of the yucky smells. When
the water runs down the drain, the air behind it has
to be replaced, if its not, the pipes will try to ****
it from some drain...typically the shower drain, but
sometimes the floor drain when its close to a washer.
When vacuum draws air in through the trap on the
laundry tub it also takes the water out of the trap,
leaving an opening where the sewer gasses can come
back up from the septic system .
Think about your pipes as if they are a drinking
straw. When you put a straw into a glass of water,
the water fills the straw. But if you put your thumb
over the end of the straw and pull it out of the
water, the water (or liquid) stays in the straw. This
shows you, air has volume. When you remove your thumb
from the end of the straw, the water flows back into
the glass. This is the principal of a vent.
So if you only have the smell when a fixture is
running, the trap is refilling after the fixture and
blocking the sewer gasses from coming into the home,
but your vent is probably not functioning.
In addition, if you have only one vent up through the
roof on a septic system, you can get sewer gas smells
coming up through your home. As the wind blows
across the roof, it pressurizes the plumbing system.
Since the septic tank is full of water, the wind
cannot go into the septic tank. So it bubbles up through the
traps into the house. Installing a vent on an
opposing roof pitch, helps to relieve the pressure buildup,
since the wind then is only hitting one side of the
roof.
Floor drains are succeptable to this type of pressure.
If your drains are partially clogged it can work
similar to a clogged vent. Since there is no place
for the water to go, it forces the air, which is much
lighter up through traps, bringing sewer gas into the
home.
If your fixture is not set right or is wabbling, the
traps or wax ring that seals it underneith may not be tight.
When this happens, if you empty the fixture, sewer gas
will come under the sink into the room.
Each of these senarios will require a different
solution. The key to solving your problem, is having
the right questions to ask when the plumber comes out
to look at it. The previous information should
provide you with a basis for the questions you need.
Make sure before you call a plumber to check
cleanout covers and pipes to see if they have
openings to the sewer. If you have an opening
without a trap, you will get sewer gasses.
In conclusion, if you don't have a vent inside the
wall which equalizes the air pressure inside the
pipes, if you are on a septic system with only
one roof vent, if the vent is clogged off due to
sludge and soap scum, if you don't have a proper trap
on your sink, or if the drain is clogged, sewer gas can escape
into your home.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
78 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
