Question about Acer Aspire 5920-6727 Notebook
My battery charger ligth is flashing and it is still not charging. I have tried another one and it is still doing the same thing
    President:
  • 2,600 Answers
Your battery has probably reached its service light and can no longer take or hold a charge. Replace the battery.
Posted on Oct 03, 2009
WENT YOU PUT THE MAINS IN THE NEEDLE ON THE PAD SAID IT FULY CHARGE BUT THERE IS KNOW POWER LIGTH AND THE DC AMPERES IS NOT WORKING. CAN YOU LET ME KNOW IF IT THE BATTERYS. ARE IF YOU THINK IT MAY-BE...
Hi, if the meter is not showing a charge , it could be a number of problems, firstly make sure the lead from the charger pot is connecting okay to the batteries, you will need to remove the whole footplate to expose this, now having done that and convinced yourself that's okay , are you sure the charger working okay ?,,,, the last thing being the batteries will not accept a charge...sadly...the needle in the meter could be stuck,, is the scooter running okay and giving the impression the batteries are fully charged ? regards gewiz please rate this...
Sep 01, 2011 | Pride Sonic 3 Wheel Portable Scooter
When I plug in my Dewalt fast charger ( model# DC9310) the red ligth comes on for a secon then goes out. Whe i place the battery in the charger the light still stays off and rhe battery doesnt charge. I...
The batteries are probably bad...especially if you kept them outside in the cold or at some point they got frozen...also, if you don't use them for a long period they will exhibit this behavior..get new batteries
Dec 22, 2010 | Dewalt 7.2-18.0 Volt One Hour Charger
CHARGER PROBLEMS
The flashing light indicates the charger is charging the battery (or attempting it) and if it never finishes charging you should try to charge a different battery, if the charger charges that one ok then the battery is bad.
Jun 18, 2010 | Dewalt 18 Volt Compact Drill Kit
When put on charge the green and red light flash
Yep, not the batteries, mine is doing the same thing but my second charger works fine with the same batteries
Jan 19, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
It's on but not charge
If the light on the adapter was flashing, I would certainly replace it first. You can buy recertified chargers from each computer manufacturer and save $$.
I would also check where the cord from the charger plugs into the laptop just to make sure nothing had gotten inside the jack plugin area and may be preventing it from seating correctly.
Dec 07, 2009 | Televison & Video
Wh put my battery int he charger provided with the camera, the ligth blinks instead of being a steady light. My battery will not charge. Waht is wrong? Is it my battery or the charger?
If the [CHARGE] lamp flashes red
The battery is faulty or the battery is loaded in the charger
incorrectly. Remove the battery from the charger and check if its
contacts are dirty. If they are, wipe them off with dry cloth and
then reload the battery into the charger. When experiencing
charging problems, also check to make sure that the power cord
is not disconnected [CHARGE] lamp from the power outlet or charger.
If an error still continues to occur after you perform the above
steps, it could mean that the battery is faulty. Contact your
nearest CASIO authorized service center.
I hope this information helps you out and good luck!
Nov 20, 2009 | Casio Exilim EXZ75 Digital Camera
Olympus battery charger flashes red when battery is inserted.
@gminvite1
"Another way I found was when this happens, to push the battery to the point the light will turn on, when it starts flashing slide it off then back on. Do this a few times so it charges a little, then you should be fine to leave it on."
I tried to do this with my LI-10C Olympus charger and it worked..The blinking red light turns to solid red..Thanks for the info...Now I won't be bothering to buy a new batt.or have my charger checked..
Nov 14, 2008 | Olympus FE-230 Digital Camera
Battery Will Not Charge
Hi amber_penn, battery charging problems usually come from two sources, the battery or the battery charger.
Check the contacts on both the battery and the charger for oxidation, dirt, etc. Try cleaning the contacts with a little alcohol on a swab. The charger seemed to still work judging from the humming sound. Next step would be to buy a new battery.
Try to follow this link http://www.livingroom.org.au/photolog/reviews/miscellaneous/norcent_dc420.php
Mar 29, 2008 | Norcent Technologies DC-420 Digital Camera
Battery charger
This may mean a dud battery or a faulty connection or many other things - you will simply have to check out with the camera makers web customer support to discover which it is on that particular charger
Oct 04, 2007 | Canon PowerShot A520 Digital Camera
Acer Aspire 5920-6727 Notebook Logo
81 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
