Question about Oakley Thump 2 MP3 Player
Oakley thump pro 05-175
Glasses wont charge. plug them into computer red light just flashes for an hour + and wont play.
    President:
  • 1,944 Answers
From what I understand you are charging with the USB cable. Did you leave it in at least for 3 hours (the PC also has to be on and not in standy or hibernation mode)? Do the glasses charge with the wall charger?
Posted on Dec 21, 2007
  • Damen Wong
    Damen Wong Dec 21, 2007
    Charging through USB takes longer than a regular chager.
    Also you can try resetting the thump. Here are the instructions on how to do it and if that doesn't work, restoration of the firmware could solve the problem.
    • Try resetting Split THUMP. Hold down the Play / Pause button and the
    Previous Song / Rewind button at the same time.
    • If the reset procedure does not work, you may need to restore the internal software.
    SOFTWARE RESTORE AND UPDATE (WINDOWS ONLY)
    Oakley periodically updates Split THUMP software to add features and improve performance. You can choose to either
    restore or update the software in your Split THUMP.
    • If you choose restore, all songs and data files stored on Split THUMP will be erased
    when the internal software is restored.
    • If you choose update, the software will be updated but songs and data files stored on Split THUMP will not be affected.
    Visit www.oakley.com/support/SplitTHUMP to ensure you have the latest software available.
Thump turns on but doesnt play. does play through computer. what up?
update the firmware which is available still from Oakleys website, you must use XP, if that does not fix it them you can visit my website www.oakleythumprepair.com
Jan 24, 2012 | Oakley Thump 2 MP3 Player
I have Oakley thump sunglasses with the mp3. Is it normal for the red light on the side to blink
When you charge gets low on the thump the light blinks red to let you know it's time to charge them up again
Sep 20, 2011 | Oakley Zero Sunglasses
Wont charge properly, music only last 5 minutes or so
Hello there :)
Try to chance the battery and see if it helps or read this site :
http://rubensmenswear.com/pages/photographs/oakley/mp3/oakley%20thump%20faqs.htm
The write on the site :
5. I'm sure my THUMP is fully charged, so why doesn't it play music?
  • Make sure the volume is not set too low to hear.
  • Make sure there are song files stored on THUMP. Connect THUMP to your computer and open the folder that shows the contents of the THUMP memory
  • Make sure you have the correct music file formats loaded into the THUMP memory. Currently, THUMP plays MP3, WMA and WAV file formats. No other music file formats are supported at this time.
  • Make sure the WMA music files you are trying to play are not protected by DRM. (See below for more information on DRM.) If the song files are protected by DRM, you need to download the DRM Enabled Utility found at www.oakley.com/thump.
6. Why can't I get a full six hours of song play time out of THUMP?
  • Many things affect play time, including the volume level, file compression and music file format. Also, lithium ion polymer batteries gradually lose their charge while not in use. These batteries are also susceptible to temperature.
  • Even though they represent the best technology available, lithium ion batteries do not perform best in high heat.
7. Is it best to completely drain the THUMP battery before recharging?
  • It makes no difference. Lithium ion batteries have no "memory effect" like older technologies such as nickel cadmium, so you can charge them at any time - even when they are not fully discharged.
Hope thats helps
If not then try to return here
Please rate my answer :)
Jun 10, 2010 | Oakley Thump MP3 Player
Oakley reset
RESET OAKLEY THUMP2
(FOR TROUBLESHOOTING)
While pressing and holding the Play / Pause button, press the Previous
Song / Rewind button once
Apr 25, 2009 | Oakley Thump 2 MP3 Player
How do you down load music to thump pro glasses
Plug the Oakley Thump into the computer to let it charge for 3 hours - a connector cable should have been provided. Double-click on My Computer - your computer should have assigned it a drive letter. Double click on the right drive letter - most computers will actually label it an Oakley. Look for a folder called Music. Now you must find songs in mp3 format only that are already downloaded on your computer. Drag the music files from the folder where your music files are stored into the music folder of the Oakley.
Not the easiest unit for beginners, but a neat concept.
-Tha Mp3 Doctor
Dec 14, 2008 | Oakley Thump 2 MP3 Player
Connection not recognized
I have often had the same problem. Resetting the software enabled me to recover. Press and Hold the Play/Pause (center) button and the Previous Song/Rewind (rear) button•at the same time. I held it for about 5 seconds. Then I released both buttons, then pressed the Play/Pause for about 1-2 seconds, the unit powered up and I was able to connect and charge the unit.
• If the reset procedure does not work, you may need to restore the internal software.See your .pdf users guide, this will erase your song list.
Good luck.
Oct 22, 2008 | Oakley Thump 2 MP3 Player
Will charge wont turn on
HI,
Try reseting by holding and pressing the power button of your player for 1min.It should turn on.
Aug 26, 2008 | Oakley Thump MP3 Player
Oakley thump pro glasses wont charge
Check to make sure you are using the USB cable that came with them. Although other cables plug in they create the problem you have. I have had a similar experience.
Dec 22, 2007 | Oakley Thump 2 MP3 Player
Oakley thump pro
Make sure you are using the USB cable that came with them. If you use another cable it looks like it should work, but it creates the problem. With the proper cable this may be resolved.
Oakley Thump 2 MP3 Player Logo
1,028 people viewed this question
Top Oakley Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Oakley Audio Player and Recorder Expert? Answer questions, earn points and help others
