Question about Cameras
30D spot problems
My Canon 30D has suddenly begun capturing dark spots when shooting scenery or interiors that have consistently blank color areas in the upper regions. I've tried cleaning the mirror, and it happens with each of my 3 lenses, so it can't be a lens issue. Any ideas?
    Sergeant:
    Champion:
  • 298 Answers
Here are a couple of links to Canon 30D data
link 1
link 2
I was thinking that you could use the built in
flash feature,and or backlighting to highlight
existing background
Posted on Dec 21, 2007
    Sergeant:
  • 279 Answers
Sounds like dust on the sensor, which is a rather common problem, but not too hard to fix.
The best way to clean it, completely, is to use what's called the "copperhill method" - that requires a cleaning kit, which you can get here:
http://www.copperhillimages.com/shopping/pgm-more_information.php?id=3
It also comes with detailed instructions.
However, if you'd like to try to do it more cheaply, you can try cleaning it with canned air: Set the camera to sensor cleaning mode and hold it with the sensor facing down. Then blow on the sensor at each corner, wait a moment, then blow middle. This will get some dust out of the way, but it mostly just pushes it to the sides of the sensor, where it's less likely to be in the way. Eventually, you'll have to get the kit listed above.
-Dyllan
    President:
  • 1,944 Answers
Have you tried cleaning the sensor? Cause this could be causing the spots. There are good guides on how to do it here and here. If cleaning doesn't help, you can try updating the firmware of the camera and in the worst case scenario, the sensor has malfunctioned (which I hope is not the case). Good luck!
There is a dark spot that is showing up on all my pictures and it's getting larger
To make sure this spot is where I think it is, on the sensor, You should put the camera in manual, A priority and whose the highest value. Shoot in bright light a complete white paper.
Then evaluate the picture on the monitor. If the spot is clearly viable the spot is on the sensor. With a fixed lens on your powershot, you can't repair or correct yourself. You should contact Canon. Don't tell Canon, you were in a moist environment. Perhaps a mould is growing on the sensor.
Feb 06, 2014 | Canon PowerShot Cameras
How to clean EOS 60D sensor manually?
I would not try this as the sensor cleaning system is pretty effective, but if your still getting dust spots I would A. get it sent back to canon for a dust clean (should be free in the first 2 years) or B
use the bundled software DPP to take out the spots. theres a setting in the camera which asks you to take a shot of a blank paper then send this photo to the DPP software. it then maps out the spots on that image and it batch process all you images thats has dust spots in them and removes them. it works really well and canon has had this in their cameras since the 30d.
I dont have the camera with me but if you put the camera into a manual mode them press the menu key and make your way to the yellow area of setting it would be there but first install DPP which would be on the CD that came with your camera.
Failing that if your in the camera settings i believe in the yellow area again there is a setting called "cleaning mode" which will lift the mirror without a lens on so you can use a rocket blower. this setting may have been taken out on the 60d as its not recommended
Jan 09, 2011 | Canon EOS 20Da Digital Camera
On all my Scenery shots there are clear round consistent spots on photos. These 4 spots only show up on sky, ocean, & light scenes. They are consistently in the same spot. Also showed up on a Brides...
You have dust on the sensor. Google the words "cleaning a DSLR sensor" and you will find sites explaining the procedure with pictures and where you can get the supplies necessary. It may sound complicated and scary but in reality it's very easy.
Oct 14, 2010 | Sony Alpha DSLR-A100 Digital Camera
Spots in the same place
Sounds like dirt on the sensor. Google the words "cleaning a DSLR sensor" and you will find sites explaining the procedure and places to obtain supplies. It's very easy to do yourself.
Apr 03, 2010 | Canon EOS 30D Body Only Digital Camera
Dark image when taking pictures of sceneries
If the pictures show up normal on the computer then the back light for the LCD is going bad...
try to replace the back light..
thank u
rate me!!
May 24, 2009 | Canon PowerShot A550 Digital Camera
Dark stain on display screen
it should be a stain spot on the camera lens..try taking it to an authorised service point and have it cleaned
Dec 06, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Black spots on the lcd display
I also have a brand new canon powershot sd750, with the SAME PROBLEM!! what IS THIS?!?
Apr 18, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon 30D spots
It's 99% dust, especially if it appears mostly in smaller apertures (<f/8). To test it, select a small aperture (e.g. f/16) and take a photo of a blue sky. The spots will show consistently on the same location.
They're hard to clean, so chances are you just missed them. Try again, or, better still, send it for cleaning to a professional.
Dec 21, 2007 | Canon EOS 30D Body Only Digital Camera
CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Sep 01, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Cameras Logo
54 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
