When pressing Underscore key, volume with dot display in the monitor
  • 329 Answers
Uninstall multimedia keyboard software and then reinstall
Posted on Oct 03, 2009
Walkie talkies model gmr325-2 ic;513C-UT914 HOW DO I GET THESE TO TRANSMIT, MY HUSBAND HAS CANCER AND WE NEED THEM IN OUR BEDROOMS AND WHEN I AM OUTSIDE, TK U, TK U
In order to get the most out of your new radio, read this reference guide completely before attempting to operate the radio.
Turning the Radio On and Adjusting the Volume
1) Press and hold the key to turn the radio ON.
2) To change the volume level press the volume/monitor up or down key to increase or decrease the volume level.
3) Press and hold the key to turn the radio OFF.
Adjusting the Sound (Key Beeps)
Your radio emits a beep each time one of the keys (except for the PTT button and call key) is pressed.
The sound of the Key Beep will increase or decrease depending on the volume level setting.
To turn OFF this beep:
Press and hold the call key while turning ON the radio.
To turn ON this beep:
Turn the radio OFF and ON again.
Choosing a Channel
Your GMR325-2 radio has 22 channels you can use to talk to others. In order to speak to someone,
each of you must be set to the same channel.
To choose a channel:
Press the channel/scan up or down key to increase or decrease the channel number displayed.
Channel Scan Feature
Your GMR325-2 radio has a channel Scan feature that allows you to easily Scan all 22 channels. When an active channel is detected, the unit will pause on that channel until the channel is clear. Then after a 2 second delay, the unit will continue scanning.
Pressing PTT button while the Scan is paused on a channel will allow you to transmit on that channel.
To turn ON channel scanning:
Press and hold either the channel/scan up or down key. The channel number on the display
will rapidly cycle through the channels.
To turn OFF channel scanning:
Press either the channel/scan up or down key.
Talking on Your Radio
To talk to others using the radio:
1) Press and hold the PTT button and speak in a clear, normal voice about 2-3 inches away from the microphone.
While you are transmitting the tx icon is displayed. To avoid cutting off the first part of your transmission, pause slightly after pressing the PTT button before you start talking.
2) When you are finished speaking, release the PTT button.You can now receive incoming calls. While receiving, the rx icon is displayed.
Transmitting a Call Alert Tone
Your GMR325-2 radio is equipped with a call tone that will be transmitted when the call key is pressed.
To transmit the call alert tone, press the call key.
The tone will automatically be transmitted for a fixed length of time.
Auto Squelch Feature
The GMR325-2 is equipped with an automatic squelch system which shuts off weak transmissions
and unwanted noise due to terrain conditions or if you have reached your range limit.
Monitor Mode Feature
Your GMR325-2 radio allows you to listen for weak signals on the current channel at the press of a key.
To turn ON monitor mode:
Press and hold the volume/monitor up or down key. The rx icon will blink.
To turn OFF monitor mode:
Press the volume/monitor up or down key. The rx icon will stop blinking.
Automatic Power Save Feature
Your GMR325-2 has a unique circuit designed to dramatically extend the life of the batteries. If there is neither transmission nor an incoming call within 2 seconds, your radio switches to the Power Save mode. The radio is still able to receive transmissions in this mode.
KEYLOCK ON/OFF
Press and hold the call key until the "L" appears. After 1 second, the LCD will return to the channel display.
To exit Keylock on mode, press and hold call again.
Note: While in keylock on mode, it will still receive transmissions.
ROGER BEEP
Roger Beep is a BEEP that is sent to notify the end of transmission.
Roger Beep can be heard through the speaker when Key Beep is on.
Roger Beep is transmitted even if key beep is turned off. However Roger Beep will not be heard from the speaker.
To turn OFF Roger Beep: Press and hold the channel/scan up Key while turning on the radio.
Jun 21, 2011 | Motorola Walkie Talkies 2-Way Radio
I don't fine underscore keypad on the motorola q9h
while typing, press alt key. now press shift key. all the symbols which are not on the keypad will now be available.
discovermayuresh (at) gmail (dot) com
Aug 05, 2010 | Motorola Mobility Q9h Smartphone
Where is the underscore on the LG Neon cell phone?
you can press the sym button and go down the list until you see the underscore button
Dec 25, 2009 | Cell Phones
OSD Lock Problem
I have a hanns g 22" widepanel , I had the same problem with lockout. I had my monitor disc and looked on it, or in a manual if you still have it. Here is the combination I had to press and it worked. I pressed the arrow buttons and the menu button all together a few times and it unlocked. Try that!
Function Key Lock:
Press the <「Volume -」, >「Volume +」and the 「Menu」buttons simultaneously to
enable the Function Key Lock. When the Function Key Lock is enabled, only the Power
button is active. Press the <「Volume -」, >「Volume +」and the 「Menu」buttons
simultaneously again to unlock the function keys.
Aug 03, 2008 | Hannspree HW191D LCD Monitor
How do I underscore
The key combination can vary depending on what language and keyboard files you're using. However, the easiest way might be to use Windows own Character Mapper to copy the underscore to the clipboard.
Run CHARMAP (in XP, from Start menu -> Run and in Vista from Start button -> start search)
Find the underscore character, and copy it to the clipboard. Go to where you need it and use CTRL-V to paste the copied underscore into wherever it is you need it.
May 26, 2008 | Toshiba Satellite A100-S8111TD Notebook
Samsung d900i
hello!
can you please try this if it will work on your phone
-- Go to a text field first, then press the RIGHT-soft key (not LEFT-soft key that the manual incorrectly states) to see a menu pop in the right bottom corner of the screen.
-- The menu shows Emoticons, abc, 123, Symb, etc
-- Select "Sym", and the popup dialog presents a full list of available symbols.
-- Use the Navigation button on the phone keyboard to go to the underscore symbol
-- press OK to input it into the text field.
or
-- hold down the # key for a few seconds and it will display the symbols
-- select the underscore
May 05, 2008 | Samsung SGH-D900 Cellular Phone
How do I text an underscore?
Press and hold the # key until the symbols screen appears. Then use the directional keys to move to the set that contains the underscore, hit the number key that corresponds with the underscore and hit OK.
Dec 08, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
