Question about Apple iPod shuffle MP3 Player
Woint work it wont charge
    Problem Solver:
  • 5 Answers
Should of went with Microsoft Zune! Lol Mine is 3 years old and still no problems. Most likely it's the battery in it. They put a rechargeable bat. In it. Than want you to send it to them to get a new one put in. It's probably not worth your time and money to do that. I don't know I'd have to see it to be sure so can't say for positive thats the case with yours. May be your cord went bad, Usually where it bends the most is where it breaks and loses connection. Again can't say for sure. If you find out what it is you can try to fix it yourself if you feel brave. There are online sites that buy and sell these thing and part them out. Good luck.
Posted on Oct 03, 2009
Why woint the car start
1. Check fuses in fuse box especially ignition.
2. Check to be sure your battery is fully charged.
3. Bypass the ignition and take a long screw driver and place on starter solenoid. The screw driver needs to touch both points at same time. If it doesn't crank it might be the starter. Be sure the battery is charged prior to this step.
4. Replace your ignition switch if all else fails but remember some cars have a fusible link in the ignition system. The fusible link might need replacing.
Nov 21, 2015 | 98-01 Chevrolet Metro/89-91 Chevrolet...
Bat is good new sterter woint turn over crossed it on the starter turns fine but still woint start
you need to check the ignition switch it sounds as if it may not be making a connection. The key has to be in the run position for the car to run after releasing the key. Hope this helps.
Sep 02, 2015 | 2000 Chevrolet Cavalier
1997 harley davidson has real weak spark woint start
Hi Donnierotten, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below and good luck:
Harley Davidson Sportster error codes and how to access them
Jun 17, 2015 | Harley Davidson Motorcycles
My ps3 wont pick up my wireless noden signal woint let me sign in gives me error code 80028e02
Hi and Welcome to Fixya
Error means there was an issue connecting to your Internet service provider. This happens when your ISP requires you to put in your username and password from the internet browser. Try to browse using your PS3 ans see if you have a message from your ISP or a login page will show up. Follow the instructions and enter the username and password of your ISP. This is not you PSN account login credentials. Contact you ISP you are not aware of you username and password
Thank you for using Fixya!
Feb 21, 2011 | Sony Playstation 3 (PS3) Console
What game card do i need to play nexon .net combat arms
Most graphics cards can be installed BUT pairing them with an old motherboard woint mean so much improvement in gaming as the CPU is slow.
Dec 20, 2009 | Dell OptiPlex GX260 PC Desktop
RCA small wonder EZ205
If the video is stored to a memory card, you can use a memory card reader. It could be that the cable between your camera and computer is bad and should be replaced.
Do you have another USB port available?
Jun 26, 2008 | RCA EZ 105 Camcorder
Apple iPod shuffle MP3 Player Logo
76 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
