Question about Pentax Optio S6 Digital Camera
When I turn the camera on it makes a clicking noise and the image on the screen is all blurred !
On my sony dslr a 300 the steady shot warning flashes at the bottom of the view screen like it is not able to steady the shot. this makes it is very hard to take a clear picture without it working...
Before you junk it, double check to make sure steady shot wasn't turned off. Also see if raising the ISO settings and increasing the aperture size fixes the motion blur (this will make image noise and depth of view blur increase though). Lastly Try resetting the camera to factory settings as a last resort.
Hope this helps.
Mar 25, 2011 | Cameras
Blurry images (after a lens error)
There is a mechanical displacement in your camera. Definitely, it is not a software problem. Actually Digi Cams are very delicate, especially small ones.... So get it serviced from a authorised service station. They will fix the problem....
Pleas rate the answer iof you find it useful.
Apr 27, 2010 | Nikon Coolpix S550 10 Megapixel Digital...
My camera when I turn it on makes this weird sound like something popping or cracking really fast and some of the pictures turn out blurred and the view screen (large) has some very fine lines in it. What...
Strong JPEG compression typically produces more JPEG artifacts and destroys image elements including noise; weaker compression preserves more image elements including noise created by the image sensor. It is preferable to use the lowest amount of compression possible for the best results.
Jan 24, 2010 | Nikon Coolpix 4800 Digital Camera
Blurred Images with Olympus E520
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
Mar 23, 2009 | Olympus Zuiko 70-300mm f/4-5.6 Digital ED...
Olympus u 700
In on postion in camera mode,the lens seems to move in and out,blurring the image and then stops with this message on screen. D: 5f O8 5eO2
Jun 26, 2008 | Olympus Stylus 710 Digital Camera
Canon Power shot 570 IS problem
Check to see if your camera is in Macro mode. This may cause blur. Also hit your function/set button to see if it is in digital macro mode.
Make sure your lens is clean.
Make sure you are set to automatic mode and zoomed all the way out. There are several things that may cause blur, the most of which is camera shake. Make sure your Image Stabilization is turned on. If it is, you will see a little hand in the bottom right corner of the LCD screen.
If it's not on, turn it on in the setup (tools) menu.
If your shutter speed is slow, this will cause image blur, but in auto mode, you won't have to worry about the shutter speed, it will be set automatically.
Hope this helps.
Apr 22, 2008 | Canon PowerShot A540 Digital Camera
Pinkish screen and green blurred picture
Sounds like the image sensor is malfunctioning (common symptoms: distorted images with purple or green cast, completely dark images, flickering lines across the screen.)
Oct 26, 2007 | Kodak EasyShare C643 Digital Camera
Blue screen and error message
No solution you can make- The motor mechanism is shot Depending on how long you have had the camera you may get it replaced or a repair price quoted. The repair price will be horrific buy the next camera.
Sep 28, 2007 | Olympus Stylus 710 Digital Camera
Blur image
try turning on the flash when capturing photos or if you dont want to , use a tripod
Sep 27, 2007 | HP Photosmart E317 Digital Camera
Pentax Optio S6 Digital Camera Logo
35 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
