Question about Mitsubishi WD62527 62 in. LCD HDTV
TV will not turn on and i already replace the bulb. What could be the problem?
  • 33 Answers
Mitsubishi has crappy tv sets if you had a power surge or even you electricity turn off and then turned back on then you have to get it fixed
E-mail me at dubcars101@yahoo.com if you have anymore questions
Posted on Oct 03, 2009
Testimonial: "Thanks -- I have been hearing their TV's are bad. "
  • Mitsubishi Master
  • 5,138 Answers
Ballast Board Call Encompass Parts 1-800-638-3328 or contact
Mitsubishi 1-8000-332-2119 Also the e2p Board can cause this
Posted on Jan 27, 2010
Tv comes on then turns itself off
Sounds like the projection bulb is heating up then it shuts off for safety reasons. If you can locate the bulb, there is most likely a screen (wire mesh) that traps dust when the fan is on to cool the bulb. Try cleaning this screen and see if it helps. It could be already too late and you might have to replace the bulb.
Feb 27, 2014 | Sony KP-65WS500 65" Rear Projection...
I have a Sony KDF-55WF655 and the bulb blew out and I smelled something electrical burning.
3 blinks is indicating that the lamp door cover isnt making contact so the lamp door cover is either attached wrong or the switch is defective.
Oct 26, 2011 | Sony Grand WEGA KDF-55WF655 36" Rear...
The lamp light is blinking once every 5 seconds. The manual says that " Lamp will not light or light is abnormal"
HI,
Panasonic PT50LC13 lamp indicator blinks to tell you the lamp is faulty.
You need to replace the bulb or TY-LA1000 lamp assembly. This link displays all Panasonic TV Lamps and TV Bulbs. This page shows Panasonic lamp location and How to Replace TYLA1000 bulb. TY-LA1000 Bulb Replacement requires the use of a long Philips Screwdriver to reach screws within the lamp cage.
Unplug AC power before removing the lamp and re-install all doors, etc, correctly before starting the TV. Vacuum any visible dust or lint from air vents and lamp area. Do not used forced air to blow out dust, big problems may result.
The user's manual has a description of what the Blinking LED indicators mean.
Image of TYLA1000 lamp.
Robert
Apr 14, 2011 | Panasonic PT-50LC13 50" Rear Projection...
Sony Wega KF-42E200A Projection Bulb
New bulb is just fine.
3 blink shows that lamp cover after replacement of bulb in TV is not fixed properly or not seated well in its position.
Put new bulb and carefully place back lamp cover in its position because lamp cover will press tinny safety switch inside that will send signal to system control of TV that lamp is installed properly.
Turn On TV and get vivid picture of Sony.
Thanks.
Oct 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
No video but there is audio after replacing bulb
NAKE SURE YOUR FRONT COVER THAT GOES OVER THE LIGHT IS'NT ON TO TIGHT ALSO CHECK THE 2 SCREWS THAT MOUNT THE LAMP COVER MAKE SURE THERE NOT TO TIGHT AND THAT THERE BOTH SCREWED IN THE SAME AMOUNT AND ALSO CHECK THE FAN ON THE BACK OF YOUR T.V. AND CLEAN IT IF NEEDED
Mar 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Green bulb or tube
Let me know the symptom in detail.
Green bulb (CRT) gives high bright light and tv goes to standby? Do you see few horizontal (retrace) lines while this happens? If yes, you need to replace Green bulb (CRT) of your tv.
Please mention exact model number of tv to guide you further.
and what IC chip you replaced in tv?
Oct 22, 2008 | Sony KP-46WT500 46" Rear Projection...
RCA Scenium HTV won't turn on
My tv is about not even 3 years old, the bulb was already replaced once and now the tv will not turn on, we replaced the bulb again, but no change... The blue lights come on and flash but eventually turn off.
Jul 14, 2008 | RCA Scenium M50WH187 50" HDTV
TV turns on and off.
It is possible that the ballust assembly is causing the lamp to fail. You likely need to replaced the ballust with a new lamp because if the ballust is bad it has likely already damaged the lamp. If you have been handling the glass of the new lamps with your bare hands this could be the cause of the short lif as the oil from your hands will cause premature failure of the lamp.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Apr 27, 2008 | Sony Grand WEGA KF42WE610 42" Rear...
1 second red blink followed by 2 second blink on "status" led
there is a service bullietin related to this.. it has to do with a thermal sensor inside next to bulb..this sensor monitors the temperture of bulb... it says getting hot....this sensor needs to be replaced
Dec 04, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Bulbs not working
the big converence ics like SK----- as they go bad your covergence with shift and shift and become unjustable..need to replace them. the bulbs? if your messing with CRTS dont or even try turning the yokes. sometimes it takes me hours and days to put all back right what the customer did....alot of times if you call my shop and said you were working on it Id tell you to call somebody else. good luck
Aug 16, 2007 | Samsung HCM422W 42" Rear Projection...
Mitsubishi WD62527 62 in. LCD HDTV Logo
511 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
