Question about Epson Stylus CX4100 All-In-One InkJet Printer
Ink finishes even with little printing over time
  • Epson Master
  • 511 Answers
Better you use CISS.
Posted on Oct 03, 2009
I have an almost full black ink and my color ink is running a little low.. but when I did a test page.. color prints, but the black does not.. I did a couple cleanings.. like 4 times.. and totally wasted...
because you don't use it enough the nozzel is probably blocked with dried ink, even the cleaning option wont work in this case, the only thing you can do is to get help from a professionnal technician to unblock the nozel, some times diping the printing head in hot water unglogges it and some times the technician needs to force a cleaning/ink solution through the nozel with a surringe, but what ever you do (DO NOT USE ALCOHOL) you will damage the print head.
Aug 18, 2011 | Epson WorkForce 600 All-In-One InkJet...
Brother lc61 printer will not print in black even wit a new cartridge installed
Hi innercepter,
1) Open the printer
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head and each ink cartridge.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then you have one of two possibilities:
(1) One of the ink cartridges is defective and causing the error
(2) If it's definitely not that, then the print head will need to be replaced.
Oct 15, 2010 | Brother Office Equipment & Supplies
Does not print
First of all please check the ink level. If it is not finished try followings:
First try to run a cleaning cycle. To do that:
- Load paper in the paper tray. - Access printer utilities. (Right click your printer icon, select printing preferences and click the utility tab to access printer utilities) - Click the nozzle check icon. - Print to check it.
Then click the clean button to clean the print head. - Try it a few times.
İf it doesn't help you can try to run power cleaning cycle. But it uses much ink. There must be enough ink in the cartridge.
Hope this helps.
Apr 24, 2010 | Epson Stylus Pro 4800 InkJet Printer
Canon MP190 not printing using only black ink, color ink finished
hai there...you try press the reset and colour button in the same time...the printer will back to normallyl
Feb 25, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon i950 won't print
Starting with printer in off condition holding reume and then power respectively,now press resume twice and and release power button le green light blink until printhead has finished moving
now is the most crucial information that has to be followed
0 presses - green light - Test Print
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
Thanks And Regards
May 12, 2009 | Canon i950 InkJet Photo Printer
Won't print won't run clean routine
Did you try this
Press Ink.
2 Press ▲ or ▼ to select Cleaning.
Press Menu/Set.
3 Press ▲ or ▼ to select Black, Color or All.
Press Menu/Set.
The MFC will clean the print head. When cleaning is finished,
the MFC will go back to standby mode automatically.
If you clean the print head at least five times and the print has
not improved,
Apr 28, 2009 | Brother MFC 420CN All-In-One InkJet...
Ink cartridge
you may check your ink cartridge
long time less using cause 3 color ink chanel(holes) a little dryer, could not print well even refilled.you may take out the color ink cartridge and put it's surface of bottom (just touch ) in the clean water 1 -2 Hrs, then set back and test it. still not fixed, you also need to do same thing if your print head is separated from your ink cartridge
Jan 20, 2009 | Lexmark X75 All-In-One InkJet Printer
Little or no ink on the paper
check your ink cartridge ink is probable dried up or it's finish.
Dec 22, 2008 | Canon S520 InkJet Photo Printer
Check print cartridge error
Try pushing it gently using some pressure. I had the same problem and it got solved using a little push.
Aug 27, 2008 | HP PSC 1210 All-In-One InkJet Printer
Black ink won't print at all
Run the cleaning process a couple of times.  The printhead might have gotten sucked dry.
Oct 30, 2007 | Brother MFC 210C All-In-One InkJet Printer
Epson Stylus CX4100 All-In-One InkJet Printer Logo
51 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
