Question about Canon PIXMA MP600 all-In-One InkJet Printer
Canon MP 540 and U043 error.
I have an Canon MP 540.
Although i put in a completly new and original cartridge i get the U043 error.
Any ideas?
MightyFalcon
  • 32 Answers
SOURCE: canon pixma mp 110 - saying 'put in cartridge'
The print heads on this printer are integrated to the cartridges. I would check the inside of the cartridge caddy, and make sure that all of the gold contact pins are exposed, not looking damaged, and that there are no tears on the film it is connected with. If you notice anything shady with that film, you want to do an RMA (Return to Merchant Authorization) so you can get a replacement,
Canon offers a 1 year upgrade warranty with all of its printers, which very few people use or pay attention to. This means that if you did not void this warranty by using remanufactured cartridges or freaked out the chips on genuine ones by refilling past 1200 prints, you will actually get the newest model (currently the Canon MP140)
Posted on Jan 08, 2008
SOURCE: MP500 ink tank cannot be recognized error U043
my mp600 was struck down today (was intermittently doing it, but now permanently) with the Yellow tank doing Error 150.
Phoned Canon (In Australia)
They said they would replace the faulty cartirdge.
Send them (in Australia only) to
Canon Australia Pty LTD
Attn: CIPG
PO BOX 313
North Ryde NSW 1670
Posted on Mar 13, 2008
SOURCE: canon mp600 printer
MP600 Easy fix for unrecognized ink cartridge
Posted on Jul 18, 2008
msasse
  • 8 Answers
SOURCE: Error U043 - Ink Tank Cannot be recognized
Try to open and close the main cover a bit, ... ink recognition will start and may solve the probleme ...
... otherwise remove the cartridge and clean the chip contacts e.g. with spirit
Maybe also pressing the stop/reset-button for >10s will also help to continue printing, but in this case the fill level of the cartridge will no longer be shown
Posted on Aug 29, 2008
Same problem - two solutions I found helped me work out mine. One said contacts needed to be cleaned and it worked to use a Q-tip and alcohol or just click it in position several times until it recognizes the cartridge - this may work. Another said that they got it to work by installing a brand new cartridge - cool, but I have one full of ink it won't recognize. So I pulled the little circuit board off a used cartridge (like you need to do with some refills) and put it on the cartridge that it wouldn't recogrnize - works great. Still haven't figured out how to get it to acknowledge ink levels though. Canon really should be more consumer friendly since these problems seem to be intended to compel the use of proprietary cartridges.
Posted on Sep 04, 2008
Canon mg5350s u043 error
Easiest solution is to buy an original cartridge, any colour and this will normally reset, otherwise your Google the problem and you should find a solution to disable this function, but chaeck reguarly as you wont get a warning that the cartridge is empty after you disable the function
Jul 15, 2014 | Canon PIXMA Office Equipment & Supplies
Canon mp 530 error u043 cant get rid of it
It is registering a empty ink cartridge. If you had the cartridge refilled instea of replacing the cartridge that is what happened. The chip on the cartridge wont register the refilled ink and tells the printer it is empty.
Oct 01, 2009 | Canon PIXMA MP530 All-In-One InkJet...
I get the U043 error on my Magenta. Cartridge is set properly.
Ink tank not installed.
[1660]
U043 (Applicable ink tank
icon)
The following ink tank
cannot be recognized.
Install the applicable ink tank(s) properly,
and confirm that the LED's of all the ink
tanks light red.
Sep 13, 2009 | Canon PIXMA MP600 all-In-One InkJet...
U043
The U043 error code indicates that an ink tank is not installed. One or more ink tank icons on the LCD should also be lit up. The lit up icon indicates the applicable ink tank. Verify these tanks are indeed fully seated in the print head and that they are lit up red.
You can also press the OK button to clear this message and continue.
May 19, 2009 | Canon PIXMA MP600 all-In-One InkJet...
When i Put in PG5Black I get an error message U043. Help
most likely a faulty Cartridge, try a new one,
otherwise it will be a faulty internal component(cartridge contact, mainboard or carriage assembly) will need service
May 29, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Apr 26, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
I have a canon mp510 pixma same message U043 and a u150 fault.
I cant see any chip to replace and have replaced my original cartridges with a non branded cheaper type, this might be why. Does this make a difference or is this the same problem occurring with replacement canon cartridges as well.
Dont want to buy genuine ones if its not going to make any difference.
Anyone who can help me would be appreciated
Nov 14, 2007 | Office Equipment & Supplies
I had the u043 problem on the blue cartridge on my mp830.
I was using non-original replacement inks but re-using the chips from the originals - replacing the blue cartridge would cause it randomly work but i then noticed the chip holder was not centred so I realigned it and hey presto! the problem was solved first time.
Sep 17, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
692 people viewed this question
old marine
old marine
