Question about Neff T1323 Electric Cooktop
I have a neff T1.D20 dual circuit hotplate but although the inner lights up and gets hot the outer part doesnt. Is the outer part supposed to?
  • 379 Answers
I have a T172 model which also has a dual circuit hotplate.
In the control area you should find a dual circuit control pad - this has two concentric circles on it. With the hob switched on, pressing this button will chnage the mode of the dual circuit hot plate bewteen:
1. Just the inner part
2. Both the inner and outer together.
When the hob is switched off using the Standby control pad, it remembers which mode was selected and will therefore work the same next time it is switched on. However, it is worth noteing that when the mains power to the hob is interuppted, either by an isolator switch/breaker, or a power cut, the hob defaults back to just the inner ring mode.
Posted on Oct 03, 2009
My Neff T67S76NO hob has a Wok burner problem, I think. The inner ring flames are fine but the outer ring can't be turned above half on before the flames start to go ragged. The more it's turned up th
it sounds to me that u need to reduce pressure although u say pressure is correct try reducing pressure and see what happens i presume u use bottle gas L P G?............in any case the flame shud not ever lift of burner and flame doesn't need to touch pan to cook hope this helps
Jan 07, 2014 | Cooktops
REPLACE SWITCH BUT DOES THE SAME THING BEFORE I REPLACE THE SWITCH POP CIRCUIT BREAKER I THINK MAYBE THE GROUND
A hotplate of that size requires a designated plug. It must be wired correctly with the right wire size to handle 15 amp. If the wiring is sloppy or is just one of 12 plugs and or lighting on that circuit it will trip the breaker if it is working flawlessly. Also never use an extension cord with it.
Nov 09, 2013 | Wells H33 Hotplate w/ Single Burner
My GE glass cooktop has a red light that goes on when in use (not theburner indicator light but a general light as soon as you turn one of the knobs. For some reason, today it is dimly on--even though...
I assume you are talking about general pilot light which illuminates when you turn any of the four hotplates on. This light gets its power supply from the hotplate contollers. The controllers generally have a pilot light circuit which links all 4 controllers to the pilot light. I haven't seen this problem before. Either a small amount of power is escaping across the pilot light contacts inside the controller or the pilot light is getting a feedback from another source/fault in the cooktop. The only solution is to dismantle the cooktop and use a voltmeter or similar to trace the fault. Unless you understand how the problem occurs it's probably best to call a repairman.
Feb 11, 2011 | GE Cooktops
Frigidaire ES340 Range One element from Dual element doesn't work
The elements DO BURN OUT. Replace it.
Often you can see evidence of a hot spot on the element where the final failure occured, but not always.
Oct 27, 2009 | Cooktops
Neff induction hob safety lock
safety lock is on. How can I release safety lock?
Jun 18, 2009 | Cooktops
We have a neff induction hob which for some reason has no instructions and my little brother managed to lock it (so that a key symbol lights up above the on switch and all functions are disabled, i need to...
Try - set all hotplates to setting 2. Switch off jot plates one after another starting with front right in clockwise direction, touch main switch for at least 5 seconds & a signal will sound - this activates & de-activates the child lock - or so the instructions say...
To use the hob with the child lock on - it says to press the main switch for more than 4 seconds & that lets you use it.
Jun 15, 2009 | Cooktops
Gas oven knobs seizing when oven hot
hi my name is mark, yes most manual gas valves can be disassembled and lubed. you will need gas valve grease. remember a little goes a long way and shut off the gas to the unit before disassembly.
Feb 21, 2009 | Cooktops
Safety lock on Neff hob
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
Sep 27, 2008 | Neff 23 in. T4343 Electric Cooktop
COOKTOP
its been my experience that the dual burner switch is far more likely the culprit, unless you can physiclaly see the outer ring is broken( visual inspection works wonders. as far as trying to ohm out i generally look at theelemnet itself (4 wires lead to the elemnt you can trace 1 to the outer portion of element, and 1 to the inner portion.WITH POWER OFF Iswithc those 2 wires and the restore power try element ad watch for outer ring to work inner ring no good. now i know its the switch not sending power. reset wires and order new switch
Mar 08, 2008 | Cooktops
Neff T1323 Electric Cooktop Logo
593 people viewed this question
Top Neff Cooktops Experts
Jim London
Jim London
Samyfam
Samyfam
ray gallant
Are you a Neff Cooktop Expert? Answer questions, earn points and help others
