Question about Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder
I have lost ITV1 and Channel 4 following the recent digital retune. How do I get them back? My postcode is W12 9NE.
    Brigadier General:
  • 3,006 Answers
The Sagem PVR 6280 is specifically listed as a model which will have problems with the retune.
See theaddress below for a chart of affected models, but the official advice isthat you must contact Sagem directly on 0845 0900 316 for either an overthe air update or an update DVD depending upon the manufacturer.
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
Sorry Ican't provide you with a definite solution but I hope that I've at leastreassured you that it's not something which you have or haven't done!
Please return the favour by rating my answer.
Posted on Oct 03, 2009
    Problem Solver:
  • 6 Answers
IF YOU HAVE A SIGNAL BOOSTER CONNECTED, REMOVE THIS AND DO RETUNE AGAIN IT WORKED FOR ME,YOU CAN CONNECT BOOSTER AFTER RETUNE IF YOU WISH BUT IS NOT NEEDED
My daughter has a Goodmans GTVL19W17HDF in her bedroom for two or three years. She has only now mentioned that she has now lost ITV1 Channel 4 and Channel 5 using DTV, and also has a very inconsistently...
Fisrt check that the aerial connector going into the TV is OK.
The UK is in the process of switching off the analogue channels and reassigning to digital TV. This means that the signal strengths of various transmitters are getting stronger and channels are moving around to different frequencies. Try retuning the digital TV stations. If this does not work then try an external DTV box to see if the TV is at fault or it is a bad signal on the aerial.
May 16, 2011 | Televison & Video
How do you tune in to get freeview HD on the TXP42S21B
You simply need to perform the auto-setup when you first use the television. The freeview HD channels will tune in at the same time as the standard def. (SD) channels. You will find them in your channel list but there are only 3 freeview HD channels currently available - BBC HD (Channel 50), ITV1 HD (Channel 51) and Channel 4 HD (Channel 52).
If these channels are missing, it's may be because the HD broadcasts haven't started in your area yet. Please visit this page and enter your postcode to find out if you can get these channels:
http://www.freeview.co.uk/availability/
If you've gone past the auto-setup and you need information on how to tune your TV, please consult your manual or post back here and I will assist you.
Please rate this solution if you find it helpful. Thanks.
Oct 18, 2010 | Panasonic Televison & Video
Cannot get ITV1, ITV2 or CH5 anymore after retuning. Connected to outside aerial
Go in menu,Picture setting go down to reset,to back to factory seting.Go to retune or CH. again will get everythings back.
Jan 12, 2010 | Grundig GU22DVDPX 22 in. LCD TV
Within the last two days I have lost the signal for ITV1 4 & 5 tried retuning but no signal received, my Postcode is BD20 9AL
Have you tried a complete reset of the TV, since the switchover date in some areas, transmiters have changed too. ry this ad let me know.
Good Luck
Stuart
Jan 12, 2010 | Samsung LN32A330 32 in. LCD TV
CANNOT GET itv1. NEED TO RETUNE BUT DOESN'T PICK
Good Day,
Try this to reset your programming, but try to reset the whole set by unplugging TV and BOX from power source for 3-5 minutes then plug power cord back into power source. If that does not work try this:
Option Menu Setup
Follow the steps below for the initial set-up:
1. Select the "MENU" display by pressing the "MENU" button once.
2. Press the number buttons "0", "1", "7", "0" in sequence to select
the "OPTION MENU" display.
3. Press the "ADJUST" button to select "INITIAL."
4. Press "ENTER."
NOTE: At this time channel 3 is automatically selected.
Good Luck, Big IRISH>
Dec 15, 2009 | Mitsubishi WT-46809 46" Rear Projection...
No BBC channels available after retuning Sony Trinitron TV
When TV channels are moved from one frequency to another frequency that was previously used by a different channel (sorry, but there's no simple way of saying that !) as has happened recently in th UK, some digital TVs and digiboxes struggle to sort the channel list out properly and channels can go missing as you describe.
If your equipment has the option to delete all currently stored channels (normally in the tuning menu options) then do so and then do a full re-tune.
Sometimes, this solves the problem as the equipment is no longer aware of any previous use of a frequency and just loads every channel it finds.
If this doesnt work, or your equipment doesnt have the option, then there is normally the option soemwhere in the menus to retore the item to "factory defaults/configuration". This will clear all previously stored channels and after a full re-tune your missing chanels should be there. However, any other configuration changes you previously made, e.g picture size, output type (RGB/NSCT/etc), etc will be lost and you'll need to set these again.
NB. some regions of the country have lost some channels temporarily now until after the switch over programme completes at the end of 2012. If you visit the Freeview website, this will tell you if your area is affected.
Nov 07, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No digital yet tried to retune but greyed out.
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Jun 03, 2009 | Samsung LE32R73BD 32 in. HD-Ready LCD...
TV CHANELS
this is an activation or signal issue, you will need to contact direct tv
Jul 08, 2008 | Directv D11 DTV Receiver
We have a sharp lcd tv c/w built freeview,the last couple of weeks it keeps losing just 1 channel ie bbc1 or itv1 every other channel is fine if we retune the tv everything goes back to normal, is it the...
no problem occur on your set but the only problem is you can not lock the fine tuning (in manual procedure) but is it better to set the program to AUTOSCAN OR AUTO PROGRAM and authomatically tune and save to the memory all the program channel
Apr 29, 2008 | Televison & Video
Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder Logo
1,059 people viewed this question
Top Sagem Televison & Video Experts
electracon
ka4iup
ka4iup
 Mikey
Mikey
Are you a Sagem Televison and Video Expert? Answer questions, earn points and help others
