There is a coin stuck in my front loader, how do i get it out...
Its a LG intellowasher, there's a little door on the front bottom to open to get bits out and i have gotten one coin out but one is stuck, i can feel it, but when i do it goes just out of my reach and i really can't get very far in to grab it. i can manage to usually still wash fine, till it gets stuck again and stops proper removing of all water. there must be a way for me to get it.....
  • rayrayrayray Oct 04, 2009
    thanks, but tried that doesn't work, space too hard to get into,
    your hand goes into the main space and off to the right is a small
    ( too small for hand) passage where coin is, you just push the coin back before you can grad it. and you can't really maneuver tools in the space.
    i need some kind of magnet or some wierd solution....
  • Tameson Godfrey Oct 23, 2012
    I am having the exact same problem! Let me know if you figured out how to get it......
    President:
  • 1,304 Answers
Needle nose pliers
Posted on Oct 03, 2009
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
How do you take the filter out to clean it? Front Loader Washing Machine LG
I assume you mean the filter behind the little door down the bottom. You open the door and unscrew the cover to remove the filter. if it won't come then it must be jammed. Try using a pliers to carefully work away at it . It probably has coins etc jammed inside. I have broken these by trying to remove them, but it has to come so if this happens it doesn't cost much for a new one good luck
Mar 05, 2011 | LG Washing Machines
Lg intellowash 7.5 wd1025fb. loud dry bearing like noise on spin cycle
could be a coin or something stuck around the drum area. check all areas around where it spins. get a magnet if you don't see anything visible and run it along all the area.
Aug 03, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Intellowasher (Model WD-1023C)
The water pump can be blocked and thus stop the machine from finishing the wash cycle. In front on the bottom there is as hatch that can be opened with a flat screwdriver, the small black rubber pipe can be used to first drain all the water before the opening the filter. Small objects such as coins coluld be found in here, blocking the pump. Clean the pump by removing these, optionally blowing into the outlet (yuck!), to dislodge anything. If that does not help to fix the problem, you can clean that actual water pump, but this requires you to use a screwdriver to remove the pump.
Tilt the machine on its side, the pump is attached with 3 self-tapping screws. (if you can't figure out what the pump is you should probably let a technician do this). The pump has 2 parts to it, take it apart carefully and clean out all the dirt that has accumulated in there. Plastic friendly, waterproof grease can be applied to the pump spindle and bearing if available.
If the problem still persists a new pump is available from LG at a reasonable cost.
Jul 30, 2010 | LG Washing Machines
Kenmore elliet washing machine, front loader
To open the door manually:
UNPLUG the machine...
Remove the toekick panel (way down at the bottom).
Feeling along the inside of the front panel. You should be able to find a tab shaped like a teardrop attached to the door latch unit.
Pull the tab down just a little bit ... gently ... until the door opens (or you hear the latch click - then try to open the door).
Is the machine displaying a code?
Apr 29, 2010 | Kenmore Elite 45986 Front Load Washer
I can't open the door of my washing machine it is a front loader lg intellowasher 7 kg wd8013c please help asap
FOR ANY REASON THE WASHER MACHINE DIDNT FINISH ITS CYCLE!!! AND IT IS A SAFETY THAT IF DOESNT FINISH ITS CYCLE THE DOOR WONT OPEN!!!!
I HAD ONE LIKE THAT AND I BROKE IT APART!! AND I SAW THE WATER PUMP WAS THE PROBLEM SO I CHANGED IT AND PUT IT BACK TOGETHER AND LET FINISH ITS CYCLE AND OPEN THE DOOR!!! AND STILLS RUNNING!!!
Oct 05, 2009 | Washing Machines
My bosch wfk2401 front loader is stuck on spin
Hi
There is a door bottom right of the system which has a screw out (by hand) plug.
Remove this and ensure there are no foreign objects such as coins, bobby pins etc stuck.
I have found this to be a problem with the Bosch systems and cost me $150 the first time.
Ensure you have some towels as when you open the plug, water will escape
Mark
Mar 04, 2009 | Bosch WFK 2401
Washing Machines Logo
124 people viewed this question
Top Washing Machines Experts
