Question about Graco Quattro Tour Travel System
I have a graco - model number 7525GCKU / serial 1112050105 / the front wheel has broken off and i need a replacement - where can I get as I place these numbers into the GRACO replacement web and they don't recognise either!!
  • 17 Answers
SOURCE: graco quatro wheel removal
There are several different styles of the Graco Quattro Tour stroller, but it seems that all styles have similar instructions for the wheels. For the front wheels, you might need a flat head screwdriver. The front wheels snap into place, so there should be some form of clip that is holding them in place. You will need to locate this clip (which may be inside the piece connecting the two wheels together. Use the screwdriver to reach this piece, and push it in, then slide the wheel off while the clip is still compressed.
The rear wheels will also require the use of a flathead screwdriver. There is a Graco logo on each back wheel. It is an oval piece that should be pried off with the screwdriver. You will then see a locking pin under it. You will need to use the screwdriver to spread the open end more so that the pin will be wide enough to slide out of the axle hole. Remove the wheel and the washer (be careful to move the pin and the washer somewhere where you child cannot find it, as they can be choking hazards).
The following is the link to one of the Graco Quattro stroller instruction manuals. http://www.gracobaby.com/assets/pdfs/instructions/ISPA173AB.pdf
You should be able to look at this for detailed pictures for the stroller assembly, but then follow those directions in reverse to remove it.
I hope this has helped.
Posted on Jan 01, 2008
SOURCE: GRACO STROLLER FRONT WHEEL BROKEN
I have the same problem, the airline broke ours the last time we flew. I just found on Graco's website that you can order replacement parts. Here is the link, http://www.gracobaby.com/store/order/default.asp?N=10418+10413+10421&Ne=11
You'll need the model number and serial number. I found ours on a sticker under the footrest. For our stroller it's $19 plus shipping for the front wheel assembly.
Hope this helps.
Posted on Feb 11, 2008
  • 126 Answers
SOURCE: Stroller Wheel Broke
replacement parts
LINK: http://www.gracobaby.com/store/order/default.asp?N=10418+10413+10421&Ne=11
Telephone
Graco Customer Service is available Monday through Friday, 8am to 5pm Eastern Time.
1-800-345-4109 (US)
Postal Address
Graco Children's Products Inc.
Attn: Graco Store Consumer Services
150 Oaklands Boulevard
Exton, PA 19341
Posted on Apr 28, 2008
SOURCE: graco mosaic pushchair
CONTACT GRACO. THEY WILL SEND YOU A NEW SET OF WHEELS NO CHG.
Posted on Sep 20, 2008
  • 5 Answers
SOURCE: our graco tandem duo
http://www.gracobaby.com/ReplacementParts/Pages/ReplacementParts.aspx
Posted on Dec 29, 2008
I need to put the wheels on my graco stroller
hi have a look for your serial or model number for stroller then ring graco on this number 08444121212 they will help you with wheels as i ordered a front wheel for my graco they was helpfulful too.
Dec 14, 2012 | Graco LiteRider Baby Gear
you can get the wheel here
http://www.amazon.com/Graco-Quattro-Deluxe-Stroller-Renaissance/dp/B000CEXO0C
Jun 18, 2008 | Hauck Infinity Umbrella Stroller
Spare wheel for Graco Buggy
Hi Kedia,
I have a few gracos here in the work shop, I've googled yoiur details above, but it comes up as a different buggy. If you'd send me a detailed photo, I might be able to help you.
take care, Nina
Nov 18, 2012 | Baby Gear
How do i find a replacement back wheel for a graco cleo pram?
Hi, did you check the Graco website?
If you input your model number and either serial number or manufacturer date (found on the sticker on the stroller) you can browse through Graco's available replacement parts and find out if they have those wheels or not.
Jul 02, 2010 | Graco Quattro Tour Travel System
Hello i am looking for back wheels for a graco buggie. model 6d97vusu jj serial 0728080151 any ideas where i can buy these
contact Graco directly .... google them online and get a phone number .... they sent me replacement wheels from my stroller free of charge .. hope this helps
Jun 24, 2010 | Graco Quattro Tour Travel System
Broken rear wheel on graco duo stroller
You can order replacement parts from the Graco website.
Go to the Help Center, then Order Replacement parts. You'll need the model number and serial number or manufacture date. Site helps you locate the information on your product.
Jun 09, 2009 | Graco DuoGlider 7444 Twin Seat Stroller
I have a Graco Stroller serial number 7525GCKU (1 think that it is a Quattro Tour Deluxe) and one of the front wheels has come off. The piece of plastic that connects between the metal leg and the wheel...
I know this sounds a bit cheap, but superglue/adhesive is too brittle to make a good fix. Especially seeing as the unit cracked unevenly.
I took the unit off the arm of the pushchair by pushing the little metal clip in at the bottom and pulling it down.
The rest of the unit which was still inside the wheel needs a pair of tweak nose pliars and a flat head screwdriver (and a lot of patience). You need to use the pliars to grab the unit in the middle of the little circle, then use the flat head screwdriver to push in once side of the expanding clip in the middle.
Once you have both broken parts, hold them together in the correct place and wrap A LOT of cellotape around the two bits. Then clup both bits back on and hey presto, it works!!
Just taking it for a "road test" so to speak now, but it was an easy fix. You just need to be careful when removing the parts that you don't break them beyond recognition!
I tried to pull the two parts apart with my hands after and to be fair, the fix is probably stronger than the original flimsy bit of plastic.
If anyone wants any help on how to fix it (pics or more of a descriptoin of how to get this bits off) drop me an email at we_want_goat@hotmail.com.
Jul 20, 2008 | Graco Quattro Tour Travel System
Broken Wheel
Call Graco for replacement parts, phone number below.
800-345-4109 (US)
800-667-8184 (Canada)
Jun 12, 2008 | Graco DuoGlider LX 7946 Twin Seat Stroller
Hope this helps.
Jan 13, 2008 | Baby Gear
replacement parts
Telephone
1-800-345-4109 (US)
Postal Address
Exton, PA 19341
Apr 28, 2007 | Graco CoachRider Chauffeur 7512BNT...
Graco Quattro Tour Travel System Logo
497 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
john milligan
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
