Question about Dell Inspiron 1525 (dndppa1_3) Intel Core 2 Duo T5550 (1.83GHz/667Mhz FSB/2MB cache) 120GB/3000MB PC Notebook
Im looking for a charger board for a dell 1525 is it seperate from motherboard thanks
  • 569 Answers
This machine does have a separate charger board that plugs onto the motherboard, held by two screws. The charger board accepts the power cable and also has two USB sockets. (top right on the laptop when looking from above)
The board is available, Part number 48.4W006.021, cheapest on ebay. It does require disassembly down to removal of the motherboard
What exactly is the problem you are trying to solve.
Posted on Dec 08, 2009
  • 3,940 Answers
From what I can discern, there is a separate power button board, but no separate charger board (It seems to be part of the motherboard.
Posted on Oct 03, 2009
Testimonial: "thank you it is the power button board,can it be bought seperate "
Dell 1525 not charging
Borrow someones 'Dell' brand A/C adapter charger.
If that works then yours is bad. If it doesn't then it could be the battery, but more likely the main board.
Oct 22, 2013 | Dell Keyboard for Inspiron 1420, 1520,...
Have a dell inspiron 1525 that will no longer charge, replaced battery, charger and power adapter card in laptop. What can problem be - read that it can be some capacitors. Where are they and how do I...
Tom
i have inspiron 1525 as well ... if the computer wont boot up, then the mainboard may have experienced a power surge of excess current. did you have t-storm or power out while your computer was plugged in with Ac adapter ?
if not , to answer your question, the capacitors you inquire about are so small, it would require special solder machine to replace these CAPACITORs, as they are very tiny in size and require absolute temperature (heat) from solder gun to pally appropriate solder to replace the capacitor(s).
i think your mainboard is gone.
if i can be of further assistance, please let me know-- i can help
Nov 02, 2010 | Dell Inspiron 1525 Notebook
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 battery quit charging when warranty quit. Bought new charger, didn't help. Told motherboard needs replacement? This seems fishy to me. What kind of laptop works longer than the...
It is possible the battery itself has wore out. They have a limited amount of time they can be recharged. Does the unit run while the charger is plugged in??
Jan 26, 2010 | Dell Inspiron 1525 Notebook
Dell 1525 not charging. dc usb board replacement
rubberman
Sorry to hear that you are still having trouble. The only other thing to try is your battery on your buddies notebook. If it works there then it is the charging mechanism on your notebook and this would mean replacing the motherboard.
Issken
Jan 11, 2010 | Dell Inspiron 1525 Notebook
My laptop is not chage dell 1525 when power is on laptop is working ok when power is rimove laptop is totaly off
I think the battery is bad. how long have you been using it now?
Look for someone that has the same laptop, remove the battery and test it with yours to be sure if it is the battery that is bad or not.
Please give me feedback if it is not the battery.
I wish you the best.
Nov 13, 2009 | Dell Inspiron 1525 Notebook
What model motherboard do i need for a dell inspiron 1525 model no.PP29L?
The Inspiron 1525 has 2 motherboards. Part # N122G and J046C. You'll have to get the board that was sent with the original base configuration. Just call technical support at 1-800-624-9896 and check which part # is needed for your system and then order one accordingly from sales.
Thanks and rate if useful.
Jul 23, 2009 | Dell Dimension 4600 PC Desktop
Dell inspiron 1525 will not charge the battery
1525 owners (possibly other models) DO NOT replace the mobo before reading this! Just read step 3 and 3a.
The Dell 1525, 600 series, and probably all other models using PA10 or PA12 power supplies have a power jack that uses the center pin to detect the presence of a genuine Dell power adapter. There have been considerable writings on the problems with this 3rd pin on the internet.
The symptom is that you can run the laptop when plugged in but the battery won't charge and you get a warning message that you are not using the proper power supply or it can not be identified.
The best place to see power supply status in the BIOS under battery status.
You MUST use a genuine Dell adapter, period. None of the non OEM supplies have the center pin enabled (proprietary chip).
CAUSES:
1. The power adapter sensing line can be damaged by static electricity but I find this to be rare.
2. The center pin in the power supply is loose or the wires are breaking (test by wiggling the power cord at the strain relief while holding the plug steady in the laptop - replace the power supply for $<20 on eBay.
3. The center pin connector on the laptop jack is loose - symptom is that it works sometimes and not others. Requires a full breakdown and replacement of the jack. Can be done yourself if you are very handy AND WILLING to FOLLOW DIRECTIONS which are excellent on the Dell web site. Does require soldering on most laptops.
3a. At least on the 1525 there is a sub board for the power and USB which you can get for $80 on eBay and just plugs in - still requires pretty much total breakdown. The board itself is usually the problem so replacing the connector won't help - it is in the multilayer trace from the power jack to the mobo connector. There is a bypass wiring method that requires super close tolerance soldering - I will post that if asked.
4. On some older models (P4 1 core) you can go into the BIOS and turn off Intel speed step to get the laptop running - it will run slower but you probably won't even notice the diff.
This whole mess is the result of Dell trying to protect the mobo and battery (life and fire prevention) but packing too much wiring into a too small package. They should have used a larger, 3 prong type power jack knowing how much strain is put on the power cord.
Mar 12, 2009 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 no display
i have recently worked on an inspiron 1525 that the dispaly got cracked. it works perfectly if it is hooked to an external display. would you like me to see if it is avalible for sale?
Jan 04, 2009 | Dell (E210882) Motherboard
Dell Inspiron 1525 (dndppa1_3) Intel Core 2 Duo T5550 (1.83GHz/667Mhz FSB/2MB cache) 120GB/3000MB PC Notebook Logo
1,124 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
