Question about Shure Audio Players & Recorders
Wiring came apart inside shell of green bullet harp mic
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
The wiring diagrams are in the User Guides. User Guides for various versions of the 520 can be found at: http://www.shure.com/ProAudio/Downloads/UserGuidesAndTechSpecs/us_pro_ug_disc_mics_content
Posted on Nov 18, 2009
How do I disassemble a sony ecm-nv1 microphone?
remove the sony sticker and you reveal 2 screws.
unscrew them with a small cross screwdriver then take apart the 4 parts shell (2 sides, top cap and rubber bottom) running your nail trought the border.
now you can access the electronics :D
Feb 07, 2013 | Sony ECMNV1 Microphone
Can you replace a melted cord
I posted the reply pasted below on how to take the Bullet apart - really not difficult once you know where the hidden screws are apart. Once apart it easy to see where the power cable terminates and should be easily possible to connect in a new cable in its place.
Yes its easy to take the Magic Bullet apart.
1. First pry out the 4 black rubber feet on the base with small screwdriver and unscrew the 4 cross head screws revealed below.
2. Remove this black base to reveal the inner black base Unscrew the cable clamp - 2 screws and the 3 screws that retain the remaining black base to the body of the bullet - slide it off over the power cable.
3. Turn the bullet the proper way up and pry out the 3 white rubber bumpers with a screw driver blade that are set inside for the cup to rest on - each is located with two rubber pins. Once all 3 are removed you will reveal 3 more cross head screws - these countersunk - remove all 3 and then the internal motor will be free to lift out through the top of the Bullet casing.
4. Its possible to slip out the 3 white plastic sliders - taking care to note how they seat each on a small spring to cleanup both the slides and the sliders.
To re assemble step by step in reverse - noting to align the motor cable with the cutouts on the bullet base.
Aug 22, 2012 | As Seen On TV Magic Bullet Food Processor
How do i remove the old hose assembly non my simplicity 7350 so i can install the new part? It seems to be locked in tight, do i break the tabs?
Are you just trying to put the hose into the cuff? If so, you just need to know that the cuff is threaded so the wire of the hose fits in the threads. If you're asking about the assembly at the top of the hose--I don't know. Probably you have to take the green shell apart and work from the inside. Good luck.
Sep 12, 2010 | Simplicity 7250 Deluxe Vacuum
Dropped a small object in the botton
It is a difficult job for users.Unless where it has fallen, it is difficult to give suggestion.
Try to check the drain area inside wash machine from the wash chamber side.
Apr 10, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a 30 year old TriStar (bullet style with thick bumper gasket around the middle) and the High/Low speed switch is burnt out. I am trying to find instructions for how to separate the shell to get to...
you remove the screw up front and the 2 scews buy the the rewheels from the bottom and then you pry the shell apart from the gasket it is tight but once you get it to loosen it come easy
Feb 25, 2010 | Vacuums
Gun keeps jamming. when shooting it jams.
Well you didn't give a lot of information about your gun. If you reload bullets you probably need to trim the cases. You also need to probably clean the bolt and oil the shell casing latches and make sure there isn't any dirt, powder residue or other foreign objects stuck inside the latches that keep it from gripping the bottom of the shell casing.
Nov 16, 2009 | Sport & Outdoor - Others
The part that ejects my bullets out
Not certain for sure, but that part is called the extractor. It's a tiny hooked shaped device that grabs the rear part of the shell to eject the shell. Good Luck
Sep 11, 2009 | Sport & Outdoor - Others
AKG Model C451 EB Microphone.
I drilled a tiny hole (.038") through the outer shell and the cartdrige where the body of the XLR connector is mounted and screwed a tiny screw into it from a pair of old glasses.
Sep 29, 2008 | AKG (WMS40DIV444US54) Microphone
Gxl 2400 wiring connections
well best to just resolder it if you know the wire it should have a standard diaphragm with standard layout. should be asimple fix.
thanks,
Nate
Aug 12, 2008 | Audio Players & Recorders
Wet phone
hi take apart the battry look in the battry socket, there are "star" screws inside buy a screwdeiver with that head open the shell(after removing the screws) gently shove a flat blade in the side shell if you will use force you will brake the little tabs which holds the two half shells in place opened it ? good seek for corrosion on the little soldering clean it all WELL!! take a spry conductor and give it hell check if the other mic fits and works... if not buy a brand new 1 assemble the whole thing togheter (gently) good luck
Apr 09, 2006 | LG VX6000
997 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
