Question about Refrigerators
Have a Servis Quartz A Fridge freezer with numbered temperature dial. When set at 3 fridge freezes up. Should the number be higher or lower?
SOURCE: Samsung RS21w USA style frige freezer panel problem
hold down the 2 lower buttons for 5 seconds to unlock the display panel
Posted on Sep 20, 2007
HVACRH20
  • 237 Answers
SOURCE: temperature adjustment
Generally the freezer temp is the REAL temp of the unit. Fans, dampers and manual control levers let some of that cold freezer air into the refer compartment to cool it. Check your owners manual for damper operations if you have one. If you have a refer temp control all that does is control a damper to let the cold freezer air into the compartment. Also make sure you don't block off any of those vents in the refer or freezer compartment or bad air circulation can occur.
Posted on Nov 09, 2006
Answer the question is 1/2 or 4/5 colder?
Posted on Feb 04, 2007
  • 90 Answers
SOURCE: FRIDGE/FREEZER MODEL: SR42NMB Multi Frost
You have a clogged defrost drain tube. best way is to thaw unit out. Your vents are being blocked so no air flow is pushed down.
Posted on Jan 05, 2008
  • 57 Answers
SOURCE: I don't know how to
You should have 2 dials one is the thermostat when you set it all the way one direction it will shut you refrigerator off. Turn it back to about the middle if there are no numbers. The other dial is the air damper between the freezer and the refrigerator. The fan circulates the air through refrigerator by this damper. If you open this open to much your food in the refrigeration section will freeze. Close it back to about 2 that will give you a colder freezer and should be about right for the refrigeration section.
Posted on May 18, 2008
Top of fridge freezing with temperature on lowest setting
You need a new thermostat but there are some things you can check in the link. 1 is the warmest setting.
Most refrigerator temperature settings are controlled with a dial or slider. They are sometimes labeled 1 through 5 or 1 through 9. If you are not sure what to set it to, then set it somewhere in the middle. If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher. If it is at 3 and you want your food colder, set it to 4 and test 12-24 hours later to see if your food is at the temperature you want.
Why Is My Refrigerator Too Cold
Dec 18, 2016 | Refrigerators
What setting must my fridge and freezer be at. Thanks
RFA70 settings Controlling the Temperature of the Fridge Compartment The left hand control wheel on the front panel adjusts the internal fridge compartment temperature. The internal temperature should be 5?C or colder, although some sections such as the salad bin will be slightly warmer. The setting of the control wheel will depend on the location of the fridge freezer, the room temperature and how often the door is opened. The normal set point (marked by a 3 on the dial) is usually suitable. If you need to adjust the temperature turn the control wheel using a coin to avoid damage: Clockwise (higher number) - Colder Anti-clockwise (lower number) - Warmer
Here is a user manual go to page 6 http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Fridges/HBRFA60.pdf
APPLIANCE 911
Sep 04, 2016 | Refrigerators
I cannot adjust the fridge/freezer temperature
Hi, there
Purchase an appliance thermometer that is specifically made for refrigerators and freezers. These special thermometers were made to withstand cold temperatures and provide an accurate reading when exposed to such temperatures.
2Place the appliance thermometer in a glass of water.
3Set the glass of water with the thermometer in the refrigerator on the middle shelf.
4Check the temperature on the appliance thermometer after 24 hours.
The temperature should register between 37 and 40 degrees Fahrenheit (2 and 4 degrees Celsius) in order to store food safely.
Only barely above freezing -- say 34 degrees Fahrenheit (1 degree Celsius) is even better for food storage at the cost of slightly higher electricity consumption. But check that food is not slowly freezing in any part of the refrigerator, which could make it less palatable.
5Look for the temperature control dial inside the refrigerator if you have to adjust the temperature, and make it warmer or cooler.
If you can't easily see the control dial, check the owner's manual for a diagram that shows the location.
When looking at the refrigerator temperature dial, you may see numbers rather than degrees. The majority of refrigerators use a set of numbers, with the lower numbers representing cooler temperatures and the higher numbers representing warmer temperatures.
6Move the temperature dial in the necessary direction to adjust the temperature up or down. Be sure to move the dial only one number in either direction because it probably will not take much to change the temperature in the refrigerator.
7Adjust the temperature balance control if your refrigerator has such a dial or sliding switch. This allows you to direct more or less cold air to the refrigerator section from the freezer section.
8Wait at least 24 hours, and then check the refrigerator temperature again.
9Observe the amount of frost in the freezer section of the refrigerator if you are unable to properly set the temperature.
10Defrost the freezer if the amount of frost is more than .25 inches (.64 cm) thick.
11Repeat the steps as necessary until the temperature is within the safe range.
12Use a permanent marker to draw a line on the dial after you locate the best setting on the refrigerator temperature dial. This will give you a reference point in case your dial moves and needs to be adjusted in the future.
Hope that helps in solving the problem...
May 07, 2011 | Refrigerators
Servis fridge freezer,which is lower temperature number 5 or number 1?
the higher the number the colder it will get, past 7 it may say coldest on the control
Nov 14, 2009 | Televison & Video
Temperature
Lower numbers are warmer temps.  Get an outdoor thermometer and put it in the fridge.  It should read about 40 degrees F if you've left the door closed for an hour or so.  Don't worry about the freezer too much.  It should be at 0 F or so.  Generally, leaving the settings at 2 or 3 is right on most units.
Oct 27, 2008 | Kenmore 64802 Top Freezer Refrigerator
Beko LF320 temperature dial numbered 1 to 10 which way is coldest?
Right to the point people. ok to make it warmer, it is the lower the number
thanks and go night ;)
Oct 01, 2008 | Refrigerators
Gorenje KE267MLA Fridge too warm
higher the number, colder the fridge ie 7 is the coldest setting
switch with red dot is for summer/winter operation. only necessary to switch it on if the appliance is in a cold location
Sep 30, 2008 | Gorenje Refrigerators
I don't know how to set the temperature setting on my Hotpoint RLAV21 fridge. The dial goes from 0 to 4. For fridges I have had in the past the higher the number the colder the fridge but I've got my...
May 17, 2008 | Hotpoint Refrigerators
Which way do you turn the temp. knob
loper the number on the thermostat dial, warmer the fridge. higher the number, colder the fridge. normal setting is about "3"
Apr 19, 2007 | Magic Chef MCBR170 Compact Refrigerator
Refrigerators Logo
275 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
