Washer Power Requirements
I'm trying to figure out wht size of standby generator I need for my house. Part of that "equation" is understanding the starting and running AC power needs of the appliances in my home. Can you help with the power ratings for my HE3T washer? Thanks Kevin
Hello kgodsave,
You are not really going to run everything in the house while using your washing machine, isn't it? If your machine runs on 1 horse power (HP) motor (which is unlikely), thats already 746 watts. say you are running some little wattage appliances say total of 1,000 watts. Double that figure and you get 2kw. A 2kva to 3kva generator would be ideal...got plenty clearance for unexpected load.
Posted on Dec 29, 2007
Why does it crank and almost start on 1st try?
Generac Generator Troubleshooting - YouTube
? 1:39
https://www.youtube.com/watch?v=AKN2dc59cxY
Dec 20, 2013 - Uploaded by Appliance Princess
I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
Generac Power Systems - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Utilities
Rating: 1.3 - ‎26 votes
Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
Generac standby generator - Propane - wont start?? - DoItYourself ...
www.doityourself.com/.../487838-generac-standby-generator-propane-w...
Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
141 GENERAC complaints and reviews @ P'ed Consumer
Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
I have a mi t m 7500 generator, how do i fix it to run my house?
unless you are a master electrician this becomes very complicated. First you need a generator that is large enough to power everything in your house, then you need a auto power up system
Guide to Buying Standby Generator
Aug 04, 2015 | Mi T M Electrical Supplies
My generator does not supply power I have checked there is no current from the generator housing I have also checked the power diode and they are fine
Try flashing the rotor field. It may have lost its magnetism. Most standby generators will lose this if in long term storage.
If you don't know to do this have someone that does as you can damage your generator's alternator if done incorrectly.
Apr 20, 2015 | Electrical Supplies
What size wire to hook up a 15kw generator to my house
At 240v, a 15KW generator will produce appx 62A or 31A per 120V leg. Therefore allowing for some overload, a conductor sized for 35A per leg would be adequate, but you should verify local code requirements.
Aug 28, 2014 | Generac Electrical Supplies
Engine will turn over/crank but will not run
All internal combustion engines have the same requirements. They must have the correct air fuel mixture and source of ignition in order to run. Although I am unfamiliar with the system you have, the fact thst it will start without the air filter but won't with the air filter indicates that you either have a dirty air filter (you said yours was clean) or you have too much fuel entering the combustion chamber. Beyond that I would only be guessing the reason (air fuel mixture regulator, worn jet, wrong size jet, something else bocking air flow etc.)
Dec 26, 2012 | Generac Power Systems Generac 5525 20 Kw...
Generac 20,000kW Standby generator doesn't start shows message STOP ALARM OVERCRANKED
Overcrank means that it tried to start and couldn't. It will go through 5 crank cycles and then stop with this alarm. Switch to off, hit enter to clear fault and then try to start in manual. Check to make sure you have fuel and pressure is 11 to 14 in WC.
Jun 21, 2012 | Generac 13,000 Watt / 13,000 Watt Home...
HAVE A TRANSFER SWITCH IN MY HOME TO PLUG A PORTABLE GENERATOR TO. PROBLEM IS WORKED GREAT BUT WAS ON OTHER SIDE OF HOUSE. I HAD A 4' CORD BUT BOUGHT A 80' CORD TO PLUG INTO THE TRANSFER SWITCH NOW WHEN...
Hello, what you are not telling us is the size of the wires in the 4' cord and the 80' cord. However, you are correct in your thinking that the longer cord is cutting back on the available power that you have. Yes, if you extend the length, then the wire size in the cord has to be increased as well. To give you a size we will need to know the generator size. Having said that, an 80' cord is going to be a BIG amount of money. You might want to tell yourself how much money you are saving pulling the generator around. If you have to use the generator a lot, you might consider installing a cable to run the generator with.
joe
Feb 22, 2011 | Honda Electrical Supplies
We have a power back generator 5050 watt we are trying to install the cord to plug into our house, what size cord do we need
If you are wanting to connect using the 120/240 outlet, I would use a #12 gauge 4 wire cable. If over 25 feet, then I would use a #10 gauge. The wire size will make a difference, so that is why I am offering the two sizes. Please make sure that you have a transfer switch if you are connecting to the panel. This will prevent someone from getting seriously hurt or killed.
thanks Joe
Jan 10, 2011 | Coleman Powermate Powermate 5000W...
I,m wiring an outlet in the garage to plug my honda 3000 into , to power a few circuits in the house. How many amp circuit can I run with a Honda 3000? Thanks RJ
On your sump pump, there is something called a nameplate which lists model number, serial number, manufacturer, and power requirements. The power can either be listed in watts directly, or in amps (at 120v). Also click on this web page and You will be able to figure it out. http://www.donrowe.com/inverters/usage_chart.html Hope that answers Your question.
May 26, 2009 | Honda 3000 Watt Portable Generator
Open Questions:
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
