Question about Logitech Squeezebox Duet
After latest upgrade to 7.4 the music is reguarly pausing at the end of a song requiring it to be ff to the next track via the handset
    Novelist:
    Champion:
  • 250 Answers
Hi, you must download and install Squeezebox server 7.5.0 http://downloads.slimdevices.com/ This issue should have been solved in 7.5.0. Thanks and have a nice day J-
Posted on Jun 15, 2010
How do I download songs onto my phillips gogear cam
  • Charge your Philips GoGear ViBE for at least three hours before turning it on.
  • 2 Insert the small end of your mini USB cable into your GoGear ViBE. Insert the other end of this cable into one of your computer's USB ports. Turn your GoGear ViBE on by pressing and holding the "Power" button for two seconds.
  • 3 Insert the Philips GoGear ViBE software disc into your computer's CD-ROM drive. Follow the onscreen prompts to install it.
  • 4 Open "Computer" from the "Start" menu and locate the GoViBE icon to make sure it has been successfully connected to your computer.
  • 5 Navigate to your music files. If you're unsure about their location, start by looking in the "Music" folder under the "Start" menu.
  • 6 Drag and drop your music files from their folder onto the GoViBE icon in your "Computer" window.
  • 7 Right-click the USB icon with the green arrow, located in your taskbar, to disconnect your device. Click "Safely Remove hardware," then wait until your computer confirms that it's safe to remove the device. Disconnect the USB cable from both your computer and your GoGear ViBE.
  • 8 Select the musical note icon from the main menu of your GoGear ViBE to open your music files. Navigate to the sub-folders section, and select a song from either the artist, album, track list or genre. Press the "Play/Pause" button to begin playing a song
Oct 07, 2011 | Philips GOGEAR SA6045 MP3 Player
I recorded about an hour of music from records. set cd track markers. wondering how to track the project so each song is a different track, when recorded to a cd. right now it's one long track.
Hi rudempis,
I not familiar with Sony's ACID Music Studio, but think it should have some of the same standard features other music studios have.
You should be able to load the long track that you have and see the graphic representation of the music. Slowly scroll to the right until you see an almost flat line, this will be the pause between songs. Once you find the pause, cut out that section and save it as an individual song. Do this with each song. When your done you should be able to burn all the songs to CD with no problems.
Hope this helps
Dec 22, 2010 | Sony ACID Music Studio 6.0 (ASAC6000)
Je 440 stops between tracks. I use MD players as my main music supply in a mobile disco so they do get a fairly tough life.I have had the same problem with three different model Sony JE players. They have...
Have you checked your setup option for auto pause on / off? This may well be old hat for you but it's amazing how many folk don't know about it and it's none too prominent in the manual. I don't know the page off-hand and it probably varies with different models, but it's under edit / setup / auto-pause. Hope this is helpful.
Oct 25, 2010 | Sony MDS-JE440 Mini Disc Player
Music player pauses as minute changes
I really think that this is an option in the mibile itself. go to setting and look for some settings that actually gives 1 min of song and track to the next song. you can disable this option andlisten to your music.
Thank you.
Feb 25, 2010 | Samsung Cell Phones
Volume Control
The upgrade might be corrupted you would need to downgrade and redo the upgrade and it should be fixed :)
Kyle
Jun 16, 2009 | RIM BlackBerry Storm 9530 Smartphone
N79 freezes while accessing few application.
That might any a problem with memory partition, try to remove external memory and formatted your memory with the handset..
You can Reset your handset by dialling the no *#7870#.., please take the back up of your handset before doing that because it will delete all your data.. than try again. If it doesnot work than you have to get your handset flashed from your handset dealer. Nokia support number: 1-888-NOKIA-2U
Nov 22, 2008 | Nokia N70 Cellular Phone
Motorola HT820 Music Skipping
have you ever upgrade the firmware of your ht820?
you can find that on motorolafans.com
Apr 06, 2008 | Motorola Mobility HT820 Wireless / Cable...
Sansa is unable to synch new music and only has 5 "bad tracks" on it that I can't delete...
Two possible methods:
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Mar 29, 2008 | SanDisk Sansa e250 MP3 Player
WHAT CAUSES MULTIPLE COPIES OF TRACKS ON SONGS
download the latest media player 11 and upgrade your firmware and programs.
http://us.creative.com/support/downloads/
Jan 15, 2008 | Creative Labs ZEN V Plus MP3 Player
Mp3 player wont download songs
I would recommend going into 'my computer ' and going into the music folder in your Rio. If your music is in here then make sure that it is a supported format (Eg. MP3, WMA. AAC is not supported)
If it is in here and it is a supported format then try formatting it and putting the tracks on again.
If that doesn't work then try upgrading to the latest firmware.
Hope this helps,
Mowcius
Dec 25, 2007 | Rio SE510 (512 MB) MP3 Player
Logitech Squeezebox Duet Logo
93 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
