Question about Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator
Samsang rs2555sl Ice maker
I had a problem with the ice maker, the ice tray was warp and was replaced with a different one. Now this tray does not hold the same amount of water as the old one so it spills in the the ice bucket and causes blocks of ice. Now the repair company said this is the only tray they produce samsang and do not produce the old tray, now they are telling me I have to replace the whole ice maker for over $400!!!. How do I find a old tray that would work? Also is there a way to adjust the water for the tray?
  • 833 Answers
Call Samsung and get a straight answer.
Posted on Dec 23, 2007
The ice maker overflows the ice tray, so water runs down the side of my freezer.
if it has worked for 3 years then I would guess just a new tray
Feb 18, 2015 | Kenmore Refrigerators
Lg ice maker overflow
The ice tray warps after so many years and is no longer level. Replace ice tray for $3.05 from RepairClinic.com Item #1266779 ...From what I can see this Item is the same for for all LSC #######TT refrig.icemakers. Another solution I found was to adjust the flow amount into the tray. The only screw that might have worked for this did not turn.
May 11, 2012 | LG LSC26905TT Side by Side Refrigerator
My samsung RS2555SL refrigerator ice maker needs to be replaced. I have found the ice maker at the samsung parts store for $61.29. Is it possible to easily replace or should I get a professional? I live in...
this is a easy job . the ice mker will change out with no changes . maytag uses this same unit and is very common . 3 mounting screws and the wire harnes is a plug in / no spec wiring needed .. mm hope this helps . feed back pls .
Sep 19, 2011 | Refrigerators
The ice stripper on my icemaker has warped. Its
when ice maker goes into harvest the unit stall on the ice /the heater comes on and when tray is warm the ice moves out on the stripper . . i would think the tray is loosing its coating and the ice does't release and the heater stayes on too long . may have to replace the mold or ice maker .. ****
Jan 18, 2010 | Refrigerators
Samsung ice maker tray won't reset
I had the same problem and would "temporarily" fix it by opening the front plastic cover (remove the 4 screws) and CAREFULLY remove the front - sometimes all the plastic gears will fly off but you can get them back because they only fit one way. Once the gears are off, you can reset the tray back to its fill position. Fit the gears back into place. Replace the front cover and it worked like a champ for a couple of weeks when I'd have to do it all over again. I finally got tired of it and ordered a new unit through ebay. Easy to replace BUT now the water won't come on to fill the tray!!!! UGH Hope this helps
Sep 21, 2009 | Samsung RB215LASH
Samsung rs2555sl ice maker trouble
check to make sure that the tube that fills the ice maker is not froozen upo and causoing this problem
Feb 21, 2009 | Samsung RS2556 Side by Side Refrigerator
Ice Cube Tray Sticks
53282922_1db7fdbcf7_m.jpgHeavy Frost on the Coils
This is good! This indicates a defrosting system failure which is a simple control problem. It also means that the sealed system (compressor, evaporator coil, and all associated tubing) is fine as wine in summertime. Defrost system problems are easy fixes that anyone with a pulse can do with maybe just a little help from their friends. The problem will either be the defrost timer (or Adaptive Defrost Control board, if so equipped), the defrost thermostat, or the defrost heater. To locate these parts in your fridge, check out these cool, interactive parts diagrams.
Jul 13, 2008 | Refrigerators
Ice Maker Freezing Up and Ice not dispensing
Check your ice cube tray to see if it is warped. Mine was. I took the tray off and dipped it into boiling water and remoulded it to the original shape and re-installed it. So far no problems. The tray gets warped because of the ice cube release mechanism. The tray is rotated around until it meets a block on one corner which creates the twisting motion we used to do on manual trays. Over time it tends to warp the tray. Good luck
Nov 26, 2007 | LG LRSC26925 Side by Side Refrigerator
Samsung RS2555SL Ice Maker gone nutty!
The icemaker relies on the motor to twist the ice tray about 120 degrees or so the dump the ice out of the tray. In order to get the ice to separate from the tray the force of the motor actually torques the tray against the rear plastic support (much like you would twist an old fashioned ice tray that you fill up by hand). Anyway, this puts a lot of force on the plastic elements that support the tray and they break after time. Once the plastic support breaks in the back there is nothing to get the ice out of the tray and each subsequent filling of the ice tray results in water spilling all over the ice bin and eventually leaking out the front of the refrigerator. You can order the part and fix it yourself (the part is DA61-00244A and is available from a number of websites. Total cost about $16 with shipping.
Oct 20, 2006 | Samsung RS2578BB Side by Side Refrigerator
Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator Logo
231 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
