I frequently loose my wireless connection and have local access only - I have no idea why
  • 329 Answers
It seems the problem is in your telephone wire.
DO check with physical lan connection....
Posted on Oct 03, 2009
Wi-fi connection gets disconnected frequently and reconnects by itself. Tried to reinstall the wi-fi drivers but no improvement. The same laptop is working perfectly at another wi-fi environment.Tried to...
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls, mirrors, fish tanks and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Apr 01, 2013 | Computers & Internet
I have a MFC 790CW and connected using wireless to a MacPro 15 in 2,8 GHZ Intel Core 2 Duo and frequently get a disconnection from the printer or can't find the printer message. I'm using OSX 10.6.6. Have...
Even though the connection network is wireless, there might be some necessary connections which are needed to setup wireless connection with the printer. You have to check that, the router is getting the power supply. You would also make sure that Brother MFC printer is connected firmly in the power plug and is on. If there are any sort of loose connections these devices would not work and would cause troubles in setting up the wireless network.
Jan 11, 2011 | Brother MFC790cw All-In-One InkJet Printer
No wireless connection
Dont enter the Router IP as WWW.192.168.0.1, Instead just type 192.168.0.1 and it should let you access the Router EWS Page. you are trying to access Internal network ( which we can call local network or LAN ) so do not use WWW.
In the Address bar of Internet Explorer, just type the IP Address.
Jun 24, 2010 | D-Link AirPlus DI-524 Wireless Router
I have a Sitecom WL330 wireless repeater
Hi I'm having the exact same problem with a Sitecom WL330 and a BT business hub. Just get unidentified network when trying to connect. Did you resolve your problem? and if so how?
Thanks
Jan 16, 2010 | Computers & Internet
Hughes net hn9000 I lose connection when I try accessing Inter.
Try to upgrade the firmware of the router.
After upgrading the firmware, reset the router and reconfigure the router.
Click Here for more info
Dec 31, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
I loose internet connection with HAMA Wireless LAN Router
Try changing the channel that the router uses. This will be a setting in the GUI. I have a Netgear wireless router and if I let the router choose the channel to use, it always chooses the same channel that my cordless phone uses so whenever I use the cordless phone, I get kicked off. You can also try updating the firmware on the router but I'd bet trying a different channel(s) will work.
Apr 13, 2009 | Computers & Internet
Global Online Banking
You could try adding the ip address to the router's allowed list.
Jul 26, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Connection to the internet.
If it worked for a long time then stopped, there might be a new wireless transmitter around. XP is awful at picking a connection back up once it drops. Does it drop less when the computer is closer to the transmitter? You might try changing the channel that your unit is broadcasting on.
Mar 17, 2008 | Hawking Wireless-G HWR54G (603992506064)...
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
