Question about Iomega MiniMax Desktop - Hard drive - 500 GB - external - Hi-Speed USB - 7200 rpm - buffe
My external drive has suddenly stopped being recognised by my Mac
After rebooting without success, unplugged everything and rebooted again. Simple is often best! Thanks
Posted on Oct 10, 2009
5 Suggested Answers
  • 18 Answers
SOURCE: Macintosh computer not recognizing the LaCie external hard drive
First thing to check is whether the Mac recognises the LaCie hardware. Go to the Apple icon, and select 'About this Mac/Computer' then more info, which will launch System Profiler, check the FireWire section under Hardware to see if your drive is listed. Assuming it is, and that the Disk Utility program doesn't see the drive, then you'll need a Disk analysis program like 'Drive Genius' or a recovery program like 'Disk Warrior'
Should your drive not be seen under the FireWire section, you have an interface failure on the LaCie, which isn't terminal, you'll just need to put the drive in another HD case and then read the data. Reply to this and I'll try and give more help depending on the results you get in System Profiler.
Posted on Apr 06, 2010
lock123
  • 6831 Answers
SOURCE: My external hard drive suddenly won't show up in Finder
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
  • 103 Answers
SOURCE: My Vista Laptop suddenly stop
There can be two issues: 1. Virus (Use AVG free) 2.. Corrupt registry ( Use reginout) I am sure it will help you.
also read below article for more help.
http://ezinearticles.com/?Computer-Randomly-Restarts!-How-to-Fix-a-Computer-That-Restart
s-Randomly&id=4247551
Posted on May 04, 2011
  • 413 Answers
SOURCE: my WD external hard drive
Unplug the power supply from the hard drive, leave for 15 seconds.
Plug power supply back in.
Try another USB cable if that does not work.
Posted on Aug 08, 2011
My WD external hard drive has suddenly stopped being recognised by my computer
Aug 08, 2011 | Western Digital Elements powered by WD 320...
My Western Digital External Drive is not working. When I plug it into my laptop it starts to run and shortly stops with one blinking light. It is not recognized by my mac.
Observe the device details to ascertain compartibilties. For example devices that are manufacturer for apple mac computers least get recognised on microsoft computers. usually the observation on the pheripheral device with mac logos is prior indication of likely incompartibilty to microsoft computers.
Feb 20, 2011 | Computers & Internet
My seagate external HD is not recognised. WHIRR sounds instead.
Go to:
http://h20180.www2.hp.com/apps/Nav?h_pagetype=s-001&h_lang=en&h_cc=us&h_product=96120&h_client=S-A-R163-1&h_page=hpcom&lang=en&cc=us
select your exact model and download the drivers you need
Dec 27, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Toshiba external hdd not recognised by any computer i try
connect your hard disk to other computer which has different os like windows xp then check it is detected or not if it is not detected then it has some internel issue.
Thanks
Jul 15, 2009 | Apple PowerBook G4 Mac Notebook
Harddrive is not recognisable by both PC and MAC.. Its either one or the other..
Partition the drive into 2 250 Gig partions, Call 1 partition MAC and the other one name PC, for the apropriate partion on each machine
Apr 13, 2009 | Computers & Internet
Smartdisk 160GB Crossfire hard drive
I had this same problem. One option is to open the smartdisk up. It should have a seagate ata drive inside. Attach it to a computer as a slave drive. Your dive will appear as a secondary drive on your computer. you should be able to get all your files off the drive. If your worried about voiding your computers warranty you can buy a usb adapter to make the drive act as an external drive. I highly recommend never using this drive again. I used it as my main hard drive and it fried on me. If you plan on getting rid of this drive let me. I need the circuit board to get my music files and portfolio off my failed drive. Thank you.
email: bizzybone@csufresno.edu
Mar 26, 2009 | SmartDisk Crossfire Desktop (xf160f) 160...
Recognise my hard drive but is blank!!!
1. You might reformate it ore it whos an error will trying.
Jan 09, 2009 | Western Digital External USB 2.0 80 GB...
Open Questions:
See all Iomega MiniMax Desktop - Hard drive - 500 GB - Questions
Iomega MiniMax Desktop - Hard drive - 500 GB - external - Hi-Speed USB - 7200 rpm - buffe Logo
477 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
