Question about Canopus ProCoder 2.0 (77010147100) for PC
When do you insert the dongle during the Canopus 2 Procdoder setup process?
  • 729 Answers
Try to read the manual if you have that one, or simply run the setup and during the installation it will ask you to insert the device :O)
Hope that helps
Have a nice day over there
Please rate my answer
Posted on Oct 03, 2009
Downloadable windowsxp boot disc winxp setup process
Windows XP Professional
http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=55820EDB-5039-4955-BCB7-4FED408EA73F
or
Windows XP Professional SP2
http://www.microsoft.com/downloads/details.aspx?FamilyId=535D248D-5E10-49B5-B80C-0A0205368124&displaylang=en
Step 2: Run the Setup disk program to create the Setup disks
When you download the Setup disks, the download contains only one large program file. When you run the downloaded file, it extracts the files. You receive the following message:
This program creates the Setup boot disks for Windows XP. To create these disks, you need to provide 6 blank, formatted, high-density disks.
Please specify the floppy drive to copy the images to:
Type the drive letter for the floppy disk drive (this is typically drive A). After you type the floppy disk drive letter, you receive the following message:
Insert one of these disks into drive drive letter:. This disk will become the Windows XP Setup Boot Disk.
Press any key when you are ready.
When you press a key, the downloaded file starts to extract and copy the files. Continue to insert the blank disks as you are prompted to do this until all six disks are created. If the process is interrupted, you must run the downloaded program file again to create all six disks.
Make sure that you label each disk appropriately with the number that is specified by the program. You must use the disks in the correct order during the Setup process.
Step 3: Start your computer by using the first Setup disk to begin a new Windows XP installation
After you create all six disks, insert the first disk in the floppy disk drive, and then restart the computer. The computer must be configured to start from the floppy disk drive. You may have to modify the BIOS settings on your computer to do this.
The Setup process starts. Insert the other floppy disks when you are prompted. You must use the Windows XP CD-ROM to finish the Setup process.
hope it helps
May 20, 2012 | Iwill XP4 Barebone
Windows XP download
hope it helps
May 13, 2012 | Microsoft Windows XP Professional With...
Reboot and select proper boot device or insert boot media in selected boot device and press a key message coming upon my hp mini 110
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to ......,press escape then press f10 to save to cmos to restart
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
?????????????????? hope this helps
Dec 27, 2010 | HP Mini 1000 Netbook
Let's edit 2 doesn't work with windows 7 I can't install it, can someone help me?
Installing LE2 in Windows 7:
install a newer version of QuickTime than the 6.x included with LE2
run Setup.exe in the "Let's EDIT 2" folder of the LE2 disc
(do not use SetupMgr.exe in the parent folder!)
enter your serial number
continue the installation until the unhandled exception occurs
Error number: 0x80000FFFF
Description: Catastrophic failure
do NOT close the error window yet!
(otherwise the installed files will be deleted)
use the windows explorer and go to C:\Program Files\Canopus\
(the chosen installation location)
rename the "Let's EDIT" folder, for example "Let's EDIT.save"
go to C:\Program Files\Common Files\
rename "Canopus Shared" to "Canopus Shared.save"
make a copy of the desktop shortcut
(copy - paste shortcut)
make a copy of the "Canopus Let's EDIT 2" start menu folder
now click OK in the exception error window and wait a few seconds
restore the "Let's EDIT" folder name
restore the "Canopus Shared" folder name
start Let's EDIT and adjust the settings
especially video standard (NTSC/PAL) and format (DV/DVCAM)
close Let's EDIT
add the following entries to the registry in order to allow installing 3DRT
(adjust DestDir if installed into a different path)
these entries will also allow installing the 3DRT update
(if you have the updated 3DRT 2.01 version that has the improved 3D PIP)
REGEDIT4
[HKEY_LOCAL_MACHINE\SOFTWARE\Canopus\Let's EDIT\Installation]
"DestDir"="C:\\Program Files\\Canopus\\Let's EDIT"
"SetupVersion"="2.03"
run install.exe in the "3D RT" folder of the LE2 disc
(or install 3DRT 2.01 instead, if you have it)
Apr 06, 2010 | Canopus Let's EDIT 2 (77610158100)
Canopus ADVC110
Yes you can. I have that very same setup using a surveilance cam as my webcam =)
Yawcam is a pretty good allround webcam application with lots of features, I recommend it!
Sep 29, 2008 | Canopus ADVC-110 (77010150100) Video...
Connecting 3 mobile internet dongle to draytek 2800vg via its usb port
Make sure to install the drivers that came with the internet dongle. Just run the setup CD the that came with it, when it asks you to plug the dongle, please do. That should guide you through the whole setup process.
Aug 12, 2008 | Draytek Computers & Internet
Problem setting up a dongle to my PC
NEVER install the dongle before the CD.
What has happend is windows has automatically installed your dongle with the wrong driver.
Try this.
Keep your dongle plugged in.
Goto start > control panel
Click system
Along the tab at the top select hardware, now click device manager.
Find your dongle, it should be under 'network adapters' (if you are not sure if it is the right one, unplug it at this point. If it dissapears from device manager - that is the one)
Now, click on it in device manager and press delete. Click OK to deleteing the driver.
Now, follow these steps carefully:
Unplug the dongle.
Restart the computer.
Start installation from CD
Only plug in the dongle when it tells you to, or the installation is complete.
Hope this helps
Tony
Mar 03, 2008 | Computers & Internet
Canopus ProCoder 2.0 (77010147100) for PC Logo
51 people viewed this question
Top Canopus Computers & Internet Experts
Aris C.
Aris C.
ali_zulfikar
ali_zulfikar
Are you a Canopus Computer and Internet Expert? Answer questions, earn points and help others
