Question about Home
My toilet tank fills up incredibly slow, but if I turn the valve all the way off and then on again it fills up quick. Also the tank only fills up about 1/3 of the way so when it flushes it barely takes anything down. Can I adjust something or replace a part. I live in a really ruff apartment complex and I don't want the maintanence guys in my place. Please help.
  • 38 Answers
It sounds like dirt could be in supply line. shut off valve,take off supply line from toilet. have a bowl or bucket handy. with supply line aimed into bucket turn on valve see how good the pressure is. shut off valve look to see if there is any dirt in bucket. if this is fine replace fill valve. hope this helps. duane.
Posted on Oct 04, 2009
Slow filling toilet tank
Was taking over two minutes to fill. Problem was with fill valve.
To resolve problem either replace fill valve or remove the flow restriction. Here is how I done it.
Turn off water!!!!
Remove the supply line.
Inside of the fill valve is a rubber piece. It is about 3/4" in diameter by about 1" long. This rubber piece has become distorted after years of use. This has to be removed.
Believe it or not, use a corkscrew and thread it into the rubber piece that is located in the very lower section of the fill valve. You can't see it so you will have to feel. Pull it out.
Re-connect the supply line.
Turn on water.
Check for leaks.
Problem solved.
NOTE>>> This only works for American Standard fill valves.
Mar 01, 2012 | American Standard 4021 White Cadet 3...
The toilet takes a long time to refill after a flush would there be a certain part that is plugged or wore out ?
Is the flapper valve slow to return to the closed postion allowing water to flow through the flush valve? Make sure the toilet flapper is moving freely and is sealing properly against the flush valve. If there is no lengthy or continual water flow in to the toilet bowl then this is not the problem.
Is the water valve on the water fill line to the toilet tank fully open? This may seem silly but it could be this simple.
Check to make sure your fill valve is opening fully. If you have an older toilet there may be some deposits that need to be cleaned way to allow free movement.
If toilet does eventually fill to the desired level, there is no leakage, water valve on fill line is fully open and fill valve is opening fully then recommend you shut off water supply, drain toilet and disconnect water fill line from the water valuve and toilet tanke to make sure there is not a blockage. If the water line and connections are clear you may need to remove the fill pipe in the tank and check for blockage. If this is very old, conisdering the cost and effort, it may be simpler to replace at this time rather than trying to extend the life.
Jan 15, 2011 | American Standard Home
My toilet makes a high pitched whine after being flushed. Pressing down on the top of the tank mechanism makes it go away but the next time it flushes the whine returns.
I would suspect that the flush valve has a blokage in it that is causing a harmonic distortion to be transmitted thru your cold water piping.. One way you may be able to help this is to slow fill rate down on your flush valve. If your fush valve has a seperate float to shut off water supply to tank when it;s full there should be a adjustement screw onside of valve where float rod goes in. Adjust screw down to raise float and thus slow fill rate of tank, this should help with the noise. Ifyour toilet does not have adjustable float see if you have a valve on incoming water supply. If you do you can try slow down flow thru supply valve and see if that helps, Thanks
Nov 18, 2010 | Kohler K-11466-0 White Cimarron Comfort...
Just installed the cadet 3 and here is what is happening. First let me say that the toilet it replaced was working good. The water filled very slow and the bowl would not fill much. I messed with the...
The amount of water in any toilet bowl is determined by its construction and no tank adjustment will ever change that. American Standard has a history of having small water surface areas in their low or ultra low flush toilets. Take a large container of water and pour directly into the bowl. If the ending level remains the same, then that is the manufactured level for your toilet.
Not all tanks completely discharge all of the water when flushed. Measure 1.5 gallons of water into a container. Turn off your water supply to the toilet then flush normally. Replace the water in the tank with your premeasured amount and observe this new water level. You might be surprised to find it is at the same level it always is. Since water weighs more than 8 pounds per gallon, one concept used in todays toilets is to have more than 1.5 gallons of water in the tank and use the extra weight push the water past the flapper at a faster rate while designing the flapper to drop after only 1.5 gallons have passed through.
Sep 29, 2010 | American Standard Cadet 3 Right Height...
When the tank refills, the amount of water that is
The fill level can be adjusted by either lowering the filler valve column or bending the filler arm down. The adjustment method is dependent on the type of filler valve. Be cautious not to allow the fill level to go above the designated fill line.
Jun 21, 2010 | Bemis 1200 Slow Elongated Toilet Seat,...
I have an American Stadard Toilet that is only 2 years old. The toilet will not stop running. Could you give me some trouble shooting ideas?
There's a lot of variety in the works in the toilet tank. Assuming this is not a pressure-assisted toilet-----First understand the three valves are: 1. The shutoff valve - on the supply line coming into the toilet tank. 2. The fill valve - inside the tank, opens with the float descends, closes when the tank fills up. 3. The flush valve - inside the tank on the bottom. Common old style is a flapper on a pivot. Yours may operate straight up and down rather than on a pivot.
Three very common problems are---- 1. The chain that connects the handle to lift the flush valve is getting caught, not allowing the flush valve to close. 2. There is problem with the flush valve being able to get a good seal when it closes - could be debris or misalignment. 3. The fill valve is not closing when the tank is full, could need adjustment or there is debris preventing the valve to seat. . Here's are some steps to diagnose---- close the shutoff valve. Wait a few minutes as you watch the level in the tank. If the water level decreases, you have problem with the flush valve. To confirm the fill valve as the problem, turn the shutoff valve back on. Lift up on the float that is supposed to turn off the fill valve. If it shuts off, you should be able to adjust it - most have a +/- plastic adjustment screw. But if raising the float by hand only slows it down, you have problem with the seating of the fill valve - which can sometimes be cleaned, but more often would need to be replaced.
I hope this is helpful. Thanks for using FixYa.
Apr 02, 2010 | American Standard Home
Tank fill valve sticks
Defective fill valve contact Toto for a free replacement part
Dec 07, 2009 | Toto Drake ADA Compliant Toilet with...
Toilet Bowl Water Level Slowly Drops
Check the fill tube in your toilet one easy way to see if it's leaking is get food coloring and pour in your tank to color the water this makes it easier to see and squeeze the tube in the tank when it's full if you see the colored water running down the middle of it you have a winner! if not you can look around for it sometimes the plastic under the flapper gets cracked too
Aug 01, 2009 | Kohler Home
Toilet fills up slowly
buy a universal fill valve and replace it
Jan 03, 2009 | Home
Toilet fills up very very slow
REMOVE FILL LINE FROM VALVE. HOLD IN BUCKET AND TURN WATER ON, IF GOOD PRESSURE REPLACE COMMODE FILL VALVE. IF BAD PRESSURE CHECK FOR BLOCK ON LINE IT MAY HAVE SEDIMENT ON THE FILTERS.
Oct 25, 2008 | Home
Home Logo
187 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
