Question about Samsung Televison & Video
If i put my samsung le32r88bd back to factory settings will it be a problem as i have my mini mac running through my tv. if it does not cause a problem how do i put it back to those settings the rason i ask is that i can not retune the tv. it runs off the ext1 ext2 and pc modes. thanks
3 Suggested Answers
  • 3 Answers
SOURCE: Trying to retune Samsung LCD TV LE26R7 but
HI,this might just help!...
1.press D.MENU on youre tv remote
2.scroll down to SYSTEM
3.access the RESET function
4 enter 0000
5 follow on screen instructions
TV will then wipe all existing channels and start from scratch.
worked a treat on my SAMSUNG LE26R7........However i noticed my signal strength dropped significantly!!...obviously them at the other end (digital tv boffins)have been mucking about,A bit of fiddling about with my existing arial did the trick!!
REGARDS.......G WATSON
Posted on Oct 15, 2009
budmrtn
  • 11361 Answers
SOURCE: How do I select PC mode to connect my laptop to my
Here is the user manual telling you how to do it using HDMI or D-SUB15HD.
http://www.retrevo.com/support/Samsung-LN-46A650-TVs-manual/id/17150bh339/t/2/
Posted on Jul 02, 2010
Mini Mac screen keeps freezing
Back up your profile data using Time Machine. Restore your computer to factory settings using the disc that came with your Mac and transfer settings from backup.
Oct 13, 2012 | Apple Mac Mini 2.66GHz Intel Core 2 Duo...
Hi my Samsung dv3 Model no: le32r88bd keeps reseting its display mode to dynamic, with a horrible backlight. Every time I reset it to standard or cinema and deactivate the backlight it resets it self...
The television is doing that because it was either the display model at a store or when it was set up store mode instead of home mode was selected. What needs to be done is for the intial setup to be redone with home being selected instead of store. The tv resets to dynamic for optimal viewing when on display next to other televisions in a store.
Aug 23, 2011 | Samsung Televison & Video
Just bought a samsung smt24a550 monitor and TV in one....to run with my mac mini...have mini screen output/HDMI cable in use, but resolution sucks on all settings. Samsung website only has windows...
I had exactly the same issue. Just start ColorSync Utility and check under the devices tab if your TV is identified on the "monitors/displays" section. If so, go to System preferences >> Displays >> Colors and select the color profile provided by the TV (namely "display" or "HD 709-A"). Hope this helps.
Aug 01, 2011 | Computers & Internet
Trying to run a mac mini to philips flat tv
Hi Ralph
Normally it's either one of the AV channels OR the channel marked RGB.
What connector are you plugging into on the TV?
Jan 21, 2010 | Apple Mac mini
My lcd tv samsung le32r88bd has a small black shadow on the screen, just over 2 years old can it be repaired and if so is it expensive. cheers
The panel is bad. Yes it is expensive to replace. I would contact mfc to see if they will help. Be firm but not nasty.
Dec 05, 2009 | Televison & Video
Trying to connect laptop to Samsung HD LCD TV using VGA cable.
I had the same problem with my Samsung series 6 32" Lcd. After many hours of trying different settings and banging my head on the wall I found the solution. What the problem is your VGA cable not supporting the high resilotion of your Samsung TV. The simple solution is to buy a new VGA cable that supports HD. Take a look at this site you need something like this one! Hope this helps.....C
http://www.clearly-av.co.uk/PGM1110.html
Sep 19, 2009 | Philips 32PF7421D 32 in. LCD HDTV
I am trying to re-connect a Mac Mini DVI output to an old (original model) Gateway42" plasma TELEVISION. The problem is I re-set the display on the Mac Mini to a widescreen resolution, which the TV will...
Unplug both from power , and remove mac battery, restart first mac then TV, already connected.
Check source with tv remote, and ensure mac res is correct.
Mar 28, 2009 | Televison & Video
Archos problem
hmmm...nice assortment..and would you please restate the problem here, or link back to original issue?
May 26, 2008 | Archos 605 WiFi Digital Media Player
Set up help!!
Firstly connect your home theatre outpu HDMI to HDMI input1 on the TV. Then connect the PS£ HDMI to the other HDMI input on the TV. Now connected the optical cable from the PS3 to the optical input of the home cinema system. Your should now have surround sound from the PS3 and DVD.
Sep 11, 2007 | Samsung HTP-1200 System
Televison & Video Logo
165 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
