Question about Technics Audio Players & Recorders
I've got a technics su-x520 integrate amp and i dont now from where i will connect my pioneer equalizer so all my sources equalized
  • chris_kyan May 11, 2010
    Dont do it, you are degrading the quality of the audio with such devices. If you must, then the output of the equaliser should go to the input of the integrated amp. Source selection would then be on the equaliser. Make sure your output of the equaliser is at line level so as not to overload your integrated amp input. Just dont bother, save up for better kit. As with all electrical appliances. If in doubt get an expert involved. Safety first.
marsrover
  • 682 Answers
SOURCE: hook up pioneer stereo amplifier model SA-1270
for audio system always you have left and right channels.
get the output (left&right) from tuner---go to equalizer input left&right.---from equalizer output go to amplifier inputs.and certainly from amplifier output to speaker.
Posted on Mar 11, 2008
robotek
  • 1512 Answers
SOURCE: Bose 901 equalizer
Hi Mark, had a look for a manual on your Yamaha, but not got to one as yet. Does it have any RCA connections on the back marked as preout prein? best place to put the 901 EQ is in line with L and R front channels at this preout prein point.
Some amps DO NOT HAVE IT. If our does not, then you could connect it in the tape loop, tape out(rec) to input on the EQ. and the output of the EQ connected to tape in(play), but connected like this, the EQ would affect the tone across all channels(unless you are just running a stereo rig, then this way works great!!) Try this and you may just have solved you problem anyway.
regards
Graeme
Posted on Mar 29, 2008
  • 319 Answers
SOURCE: connect a kenwood amplifer to a graphic equalizer
There are several ways to hook up a EQ to amp. If you have a tape monitor unused, you can plug tape-in of amp to 'out' of EQ.
Plug tape out of amp to 'in' of EQ (both channels). When you engage monitor on amp, EQ will work.
Posted on May 30, 2008
  • 5 Answers
SOURCE: How to connect the FISHER EQ-273 equalizer to the FISHER CA-885
It goes between whatever you are using to create the sound and the input to the amplifier.
e.g. for a standard HiFi.. HiFi aux out to equalizer input... equalizer output to amplifier aux input.
Trying to keep left and right channels the same through out. They are usually colour coded. Red = right Left = white.
Hope that helps.
We all start somewhere
Posted on Mar 30, 2009
SOURCE: HOW TO WIRE AN EQUALIZER TO A SONY TA-FE370 AMP
You can't wire an equalizer to this amp unless you only want to equalize one source, because it doesn't have a tape monitor function.
Posted on Aug 01, 2009
I HAVE A BSR 3000 EQ, A TECHNICS POWER AMP SE-9021K,AND A TECHNICS SU-9011K PRE AMP HOW DO I HOOK IT ALL UP?
Very easy.
SOURCE > PRE-AMP > EQUALIZER > POWER AMP.
Not sure why you want to do it, though. Your pre-amp already has an abundance of sophisticated tone controls and filters.
If I might venture a guess, you are trying to correct some serious deficit in your speakers or in your source. If you need sophisticated tone controls, filters, AND an equalizer, you need to ask yourself why ... and fix that problem.
Oct 12, 2012 | Audio Players & Recorders
How do I hook up a stereo reciver to the technics su-g91
I assume you want to use the SU-G91 as a power amplifier to drive your speakers. If your receiver has connections for inserting an equalizer (may be labeled pre-amp output and power amp input), remove the jumpers between the pre-amp and the power amp, then run cables from the pre-amp to the SU-G91 inputs. You can have an equalizer between the receiver and the integrated amplifier.
If this is not available, use the recording output (for a tape recorder on older receivers). Note that the volume control on the receiver will be bypassed with this connection.
Sep 23, 2012 | Audio Players & Recorders
How do I connect my bose equalizer to my pioneer amplifier
The manual is at Bose.com.
In any question regarding connections the exact models of all parts in the scenario should be defined.
"Pioneer amplifier" is not unique nor revealing. Integrated amplifer? Power amp? Tape Loops available? Pre-Outs? What's involved as a preamp?
The key thing to know is that any amplifier channels driving 901's must not drive other speakers as the Active EQ severely modifies the Line Level source input. If the EQ (or any sound processor) is used in a Tape Loop on a modern multichannel digital-audio-capable AVR, ONLY 2-channel analog sources will function when the Tape Loop is engaged; and all downstream speakers will be affected by the processing. That's par for the AVR course.
Bose 901 use in multichannel applications (which I have) will require access to Pre-Amp outputs for the chosen channels (likely the Front) and you will need to get a separate amp for the 901's, placing the EQ in series with the chosen amplifier. I currently drive mine with a Carver MT-200T.
Sep 20, 2011 | Bose 901 EQ1915 Home Equalizer
How do I hook up a graphics equalizer SH-GE70 to the amp SU-A707? I've already plugged in the CD player SL-PG5 and the tape deck RS-TR474M2, but can't see how to wire in the graphic. If I could...
hi,
Try this. You need 4 RCA setreo Chord for this.
1. connect the cd player out to the LINE input of Equlizer.
2. connect the Record out of equlizer to Tape's Record input.
3. connect the Play out of the Tape to the Play in of Equlizer.
4. connect the Line out of the Equlizer to the CD input of amp.
Always Select CD in the amp. And select between tape and CD in the Equlizer.
OK
Aug 22, 2011 | Technics SH-GE70 Home Equalizer
I have an old integrated amplifier and an old BSR EQ-3000 stereo frequency equalizer. i just bought a used bose 901 speaker set. how do i hook-up the bose 901 equalizer in this system?
Hook the signal source to the equalizer input and the equalizer output signal to one of the signal inputs on your amp. This is one way, but this way only one signal source will go through the equalizer (unless it has several signal inputs and a source selector switch).
The other way (inserting the equalizer between the preamp and the main amp) is:
If your amp has RCA connectors on the back named "preamp out" (or similar) and "power amp in" (or similar) that have slugs connecting them, remove the slugs, hook the "preamp out" signals from the amplifier unit to the signal inputs on the equalizer and outputs from the equalizer to the "power amp in" inputs on the amplifier.
Basically, what you do is that you insert the equalizer between the preamplifier section and the power amp section of the integrated amplifier so that you can still select the signal source without having to switch any signal cables (however, i can't say if your amp has got this type of "slug" connection feature between the preamp and the power amp on the rear panel, so i'm not sure which way you'll have to hook it up).
Hope you can make it work the way you want.
regards
Triarcuate
Sep 30, 2009 | Bose 901 VI Main / Stereo Speaker
Using graphic equalizer on a Pioneer CD player
try to connect it in tape in-and confirm that you select the right input in the receiver(in our situation you will select tape as input source).
Sep 14, 2009 | Audio Players & Recorders
Power supply connection for pioneer eq-6500
top left - orange.....goes to aux or memory wire
top right - blue.......goes to the remote wire used with amps
bottom left - black.......goes to the ground wire
bottom right - red........this goes to your hot wire
May 31, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Dec 13, 2008 | Technics SH-GE90 Home Equalizer
Dont know how to connect everything so it all works
you need a small mixer from radio shack near you.
1-connect cd player to channel 1 in mixer.
2-connect tape to channel 2 in mixer.
3-connect mixer out to equalizer in.
4-connect equalizer out to amp in.
Nov 09, 2008 | Audio Players & Recorders
Technics su-a808 amp & sh-ge70 graphic equaliser.
connect your media source(dvd-cd player)to equalizer in-connect equalizer out to amplifier line in-or aux in-connect amplifier out to your loudspeaker.
Jun 24, 2008 | Audio Players & Recorders
374 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
