Question about Acer AL532 15" LCD Monitor
When I switch my PC on, I just get the following message on my screen "VGA MODE NOT SUPPORT" and .. I just cannot get anything else.. What can I di ?
  • 657 Answers
It is possible that your Video Card drivers are corrupted.
Please try the following options
Start the computer in Safe mode
Change the screen Resolution to 800 x 600 or above
Restart the computer in Normal mode
Posted on Oct 03, 2009
  • 329 Answers
Reset your bios
    Guru:
  • 355 Answers
Try to run your computer from safe mode
I have a HP LP20265 monitor, and it seems have problem, with signal detection.
well why not test it on another system
DT or LT
desk top or laptop.
why connect 2 data cables at once, this is SO wrong.
only 1 at a time.
Mar 09, 2017 | HP LP2065 Monitor
wow ,, why not test the monitor on any other PC or laptop.
see if its good or bad.?
this is the only way to find this, unless guessing works.
i got lost in your post.
try 2 machines
the post photos of what screen does bad, words never work for telling graphics./
Mar 08, 2017 | HP LP2065 Monitor
My hp compaq laptop screen is black after installing vga but when i connect it to another monitor it works
problem with your resolution.
Restart your Laptop press F8 key select safe mode press enter to continue follow the screen instruction. Go to my computer properties in that remove the display driver than restart the Laptop.
Don't do anything it will open in normal mode and windows will install VGA driver automatically.
Oct 11, 2010 | HP Compaq nc6220 Notebook
Analog out of range display on the screen
try the lcd monitor on another PC, if the same message pops out, your monitor needs reprogramming of its A/D board, bring it to a LG service center..
if it works fine on another PC, try to boot your PC on VGA mode..
May 10, 2010 | LG 22" FLATRON LCD Monitor
"Out of Range"
OK, when you boot up next time press F8, and choose BOOT IN VGA MODE, this will then allow you to ar view the monitor, now, go into settings and make sure your video card resolution settings are set to say, 1280x1280, or maybe even less to start, say 1024x768, all 32bit. Now, when you restart next, the monitor should be OK. But, if it doesn't you will have to do it again, set lower, and then get a new Video Driver, and install, and try again, at the higher settings. If you cannot even boot up in VGA Mode, then i suspect the Monitor is faulty.
Apr 14, 2010 | AOpen F2705-8S (Black) LCD Monitor
I have a Toshiba Equium L40-156 laptop.When switching on a message appears saying windows is loading files,the screen then goes blank.
on startup press f8 a screen with a black background and white writing will display select enable vga mode. after windows loads reset display settings
Jan 22, 2010 | Computers & Internet
GX520 screen display message: cannot display this video mode
This means that the windows setting you have set can not display on your current monitor. There are two ways to fix this, one is to boot the computer in safe mode by pressing f8 after the POST screen and change the resolution and the other is to plug the computer into a different monitor to see if supports that resolution and then change the resolution in windows to a lower setting.
In case you don't know how to change the resolution in windows, follow below.
Right click on the desktop
Properties
Settings at the top
Move the slider to 1024x768
Click ok
Try rebooting. If that still doesn't work, try another resolution.
Oct 19, 2009 | Dell OptiPlex GX520 PC Desktop
I HAD REPLACED THE GRAPHIC CARD, NOW WHEN I SWITCH ON THE COMPUTER ALL I SEE IS SIGNALS OUT OF RANGE. IM RUNNING W/XP.& A HP PAV. F 1523
Switch on the computer. Just as the BIOS messages or full screen logo is about to end, press F8 several times. Then you will see the Startup Menu for Windows XP. It will look like the following.
Safe mode Safe mode with command prompt Safe mode with ... .......................... ..........................
Check whether you have a option as 'Enable VGA mode'. If you see this, select it with arrow keys and press enter. You may have to press enter again.
(Since the computer was not shut down properly the last time you switched it on, you might see this menu when you switch on the computer. So simply select 'Enable VGA mode' )
The problem is you have a new VGA card and somewhat old monitor. The current Video Refresh Rate of the VGA is not supported by your monitor.
So once you start the computer in VGA mode, go to Display Properties, select 'Settings' tab (1), Click 'Advanced' button (2), Select 'Monitor' tab (3), Select the minimum value from the list (4) and click OK buttons(5).
Good luck! If you find this information useful, please give me a good rating.
Jul 13, 2009 | HP Pavilion F1523 15" LCD Monitor
Problem with lcd 22'' tv come monitor connection
firstafal youtell that detials you working to onborad vga are addan vga tell ok aftar you insttall that display drivers
Nov 25, 2008 | Samsung Computers & Internet
Acer AL532 15" LCD Monitor Logo
69 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
