Question about Ryobi 18-inch Electric Chainsaw Chain Saws
I have a ryobi chain saw PCN 4545 - won't fire. Is there soemthing simple I'm not doing. Has worked efficiently for 2 years. Don't think it's flooded. Does it have a spark plug ? Would appreciate soem advice Peter Taylor
    Problem Solver:
  • 12 Answers
A COMMON PROBLEM FOR A CHAINSAW OVER 2 YEARS OF AGE IT IS USUALLY THAT A WIRE HAS BUSTED THAT NEEDS REPLACING CHECK FOR ASSISTANCE IN THE MANUAL IF YOU STILL HAVE IT THERE SHOULD BE AND AFTER CARE PHONE NUMBER FOR FURTHER ASSSISTANCE
Posted on Oct 03, 2009
PCN 4545 Chainsaw I unfortunately used unleaded petrol instead of 2 stroke, now can not get saw to start, is it game over for carberette?
Hi, it won't affect the carby which I'm afraid is the only good news. It will need a new piston and probably a cylinder. Depending on the price of these parts to suit your model it may not be worth repairing. Sorry Phil.
Jun 20, 2011 | Ryobi 18-inch Electric Chainsaw Chain Saws
My Ryobi chainsaw PCN 4545 overheated
Sawdust/dirt build-up helps cause this situation. Usually, the band is deformed so that it drags. The melted case parts may or may not need replacement, but will likely need trimming. The band usually does as it is difficult to remove the small bends in it. After repair, make sure the chain turns freely by hand. Set and reset the brake several times to make sure it works correctly. The clutch outer drum rarely deforms when this happens. Hope this helps!
Jun 01, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Hi, I have a Ryobi PCN 4545 petrol Chainsaw that i have owned for about 4 years with little use. I went on a Chainsaw users course over the weekend and took the saw on the instructors recommendation....
http://safemanuals.com/user-guide-instructions-owner-manual/RYOBI/PCN-4545-_E
You probably don't want to hear this, but there have been many many problems with this unit. It is now, discontinued, Personally, I would get another one, any other one. To have any chance of any type of repair, you must get a service and repair manual. I have searched extensively but have been unable to find any manuals other than the User, one supplied.
http://www.shouldersofshoreham.co.uk/sos_17Bamp.mvc?P=pcn-4545
Above is an exploded parts diagram, that should be of some help.
May 25, 2010 | Garden
Carnt keep ryobi pcn 4545 running when i increse the power
How do you increase the power to an electric saw? By your question, I'm assuming a fueled engine model. Check the fuel filter, air filter, and muffler for any plugging. Check condition of fuel lines and tightness of carburetor fasteners. If no help, turn the H jet needle CCW about 1/4 turn--which should result in the engine 4-stroking. Will the engine now run at speed (but not as fast as before)? If ok, warm the engine up, open the throttle and adjust H CW until the engine speeds up somewhat, but still 4-stroking. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. This produces best power and least heat! Hope this helps!
Apr 26, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
How to change the oil pump on the chainsaw model pcn 4545
Patrick;
I could not find anything matching the number you provided. I did find an electric saw "RY43006 Chain Saw" here (follow the instructions):
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
I think with the IPL as a disassembly guide replacement is pretty easy. There are a couple of hoses listed, I suspect one of them failed rather than the pump.
If this is not your saw please provide some different numbers (reply below) and I will try again. Good Luck. HTH
Lou
Feb 25, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Ryobi pcn 4040 chain saw
I have the same model chainsaw with the same fault. The brake is not releasing when the brake handle is pulled right back. I can only run mine if the brake handle is pulled back to the main handle with a tyrap - defeats the object of the auto-brake completely. Design fault I reckon.
Sep 28, 2008 | Ryobi 18-inch Electric Chainsaw Chain Saws
Ryobi Chainsaw - PCN 4545
Ryobi boasts a two year warranty. Have you contacted anyone about a warrantied repair?
An IPL (expanded parts list) for your saw with any oil system detail can be found here:
Homelite/Ryobi.com
The numbers Homelite & Ryobi use don't match the numbers everyone posts. A careful inspection of your saw should find something that matches.
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Aug 22, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Ryobi 18-inch Electric Chainsaw Chain Saws Logo
324 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
