Question about Cameras
Will not power up change batters stile will not power up vivitar 2x digital vivicam3615
Is the vivitar auto 2x custom tele-converter model 2x-1 compatible with a Nikon EM
Melissa. The 2X-1 is for use on a M42 screw connection, like on Pentax The 2X-3 is for Nikon.
Dec 19, 2013 | Vivitar Auto 2x Custom Tele-converter...
My Vivitar 3305 no longer powers on.Replaced batteries and still nothing.What is the problem?
Sounds like the switch has gone bad, this is not a user fix and needs to be replaced.
Jan 17, 2013 | Vivitar ViviCam 3305 Digital Camera
Can't find batters charger for vivitar carmers
Hi. Thanks for choosing fixya. Please purchase a charger here:
http://cgi.ebay.com/VIVITAR-VIVICAM-8225-T328-8025-WALL-CHARGER-AC-ADAPTER-/130513249743?pt=Batteries_Chargers&hash=item1e633225cf
Hope that helped.
May 25, 2011 | Vivitar ViviCam 8025 Digital Camera
Vivitar 8025. The battery won't charge
This is more than likely a Manufacturing problem. A lot of Vivitar cameras have this problem as well as many others that are usually not the consumers fault. Just a glitch in the technology. I alone have gone through four Vivitar cameras in the last six months. The best thing to do is contact Vivitar directly. This is there website: www.vivitar.com It is best to see if you can find the number for technical support. To see if they can give you a refund or replace it for you. I hope this helps. -Richard
Also maby try getting a replacement batter before you send it back. Vivitar should also be able to help you find where to get a replacement battery
Jan 31, 2010 | Vivitar ViviCam 8025 Digital Camera
My vivitar 8025 wont turn on'' and its fully charged
This is a problem I have also encountered. that is very common. You should take out the battery and clean the connections on the batter and the camera with something dry like a Qtip. This should work but if not. This is more than likely a Manufacturing problem. A lot of Vivitar cameras have this problem as well as many others that are usually not the consumers fault. Just a glitch in the technology. I alone have gone through four Vivitar cameras in the last six months. The best thing to do is contact Vivitar directly. This is there website: www.vivitar.com It is best to see if you can find the number for technical support. To see if they can give you a refund or replace it for you. I hope this helps. -Richard
Jan 07, 2010 | Vivitar ViviCam 8025 Digital Camera
Thinking of buying a vivitar teleconverter
If the vivitar 2x is not autofocus, then you will obviously give up 90% of the cameras focus, metering and flash functions. All 2x lenses loose 2 stops of light so the f2.8 lens will now be f 8. If that is acceptable then it may be worth the few dollars to get double the power for the lens
Feb 08, 2009 | Vivitar Series 1 for Nikon AF 2x (318604)...
Where is vivitar service center?
not batter working
Nov 14, 2008 | Cameras
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
