Question about JVC XV-N5SL DVD Player
DVD picture has no colour, i.e. Black and White
JVC XV-N5SL
Not too sure what is happening, but the DVD output is in black and white,i.e no colour, even at the power on state which is normally a blue screen. It has worked perfectly for about 7 years. No one is owning up to altering anything and I have changed SCART leads with no change.
DVDs will play fine, just in B&W, and I cant see anything in the DVD menu which will help.
My television has colour on every other channel, so I dont think it is that.
3 Suggested Answers
dna_killer
  • 34 Answers
SOURCE: Jvc xv-s302 only plays black and white
Look at the back of the DVD player it should have a NTSC & PAL switch ,but remember to switch off the dvd player after you change it over to NTSC or PAL
i hope this will help you
craig:)
Posted on Jan 21, 2008
walesarumi
  • 6993 Answers
SOURCE: My JVC XV-N5SL DVD Player plays all dvd's in w/b:
If you had not lost the remote, you would have simply pressed the PAL/NTSC button on the remote and problem would have been solved.
I don't think there is any menu on your DVD player. So, what you can do now is to enter your TV menu, go to picture settings and change it to PAL or AUTO as this might change the it to colored.
Also, you can check the back of the TV for component input. Component comprises of Green,blue and red. The combination of this three is equal to video. Try this connection method if bother the TV and DVD player has this input at their back. This might as well change the color.
Lastly, you can borrow a remote from a family of friend that uses the same DVD player and set it to PAL with the remote.
I hope you understand the above.
Good luck.
Posted on Jan 03, 2011
My daughter sat on her JVC tv/DVD combo LTdd42J remote and now her DVD's only play in black and white, when watching the TV the colour is fine. I have tried looking in the settings but cannot fin
Cable damage is the first thing to check. If the cable is external this is an easy check by trying a new one. Otherwise it is probably internal cable damage or damage to the video output plug.
Feb 18, 2013 | JVC XV-S302 DVD Player
PAL to NTSC output
How are you hooking it up to yur TV for the output?
Apr 01, 2008 | Televison & Video
Black and White
Check on the Tv sistem look on the remote for this button
Aug 23, 2008 | JVC XV-N5SL DVD Player
Colour gone
Did you possibly switch where your wires are hooked up? I just tried hooking my player up to a new tv and I had a black and white picture at one point. Make sure your video wires hook to the proper colored ports.
Jul 12, 2008 | JVC XV-N212 DVD Player
Help - loads with this problem....
check the setting and make sure you have the right format for playing and the out put of the machine.
Jan 02, 2008 | JVC XV-S302 DVD Player
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Dec 21, 2007 | Televison & Video
craig:)
Jul 01, 2007 | JVC XV-S302 DVD Player
Hooking up DVD player to HD wires.
Have you tried to go to a different channel?
Apr 16, 2007 | JVC XV-LTR1 DVD Player
No Colour
what is a jvc xv player? how about if u connect ur tv to a cable program, does it give u the same problem? if not, ur xv player is not compatible with ur tv or tv needs to configure setting and also that means ur tv is ok. if yes, there is a problem in the color circuit of ur tv. have it check by a serviceman. but if its not economical to do it, just buy a new one.
Jan 15, 2007 | JVC XV-N312
Picture in Black & White
if you are using composite cables (yellow,red & white), make sure your yellow (video cable) is into the yellow output. if you plugged the wire into the green on the back of the dvd it will give you a black & white picute. But if it is in the yellow then you most likely have a problem with the dvd player that will need to be taken to a service center.
Nov 01, 2006 | Sony DVP-NS730P DVD Player
JVC XV-N5SL DVD Player Logo
135 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
