Question about Dell Computers & Internet
My computer screen flickers with lots of lines running running through the screen
    Problem Solver:
  • 17 Answers
Check to see if you have the latest drivers installed for your model. Go to the Dell web site. DO NOT use any drivers from Microsoft updates.
Do you have any electrical devices near the laptop, like a fan, air conditioner or heater? Try moving it away from them. It may be picking up interference from them.
If this does not correct the problem, you may have a failing screen or LCD cable. The cable runs through or near the hinge. Everytime you open and close the lid this cable flexes. Sometimes they wear through and cause this problem.
Posted on Oct 03, 2009
Testimonial: "Thank you that was very helpful. I expect it is a failing screen - laptop old!! However, I will check cable first-may save money. Thank you"
Monitor flickers with lines across screen
screen is going bad which is why its flickering and has the lines across the screen. Theres a board behind the lcd and when that doesn't process the voltage properly it can cause the screen to flicker. White lines across the screen means the screen is going bad. At this point unless your monitor is under warranty, go ahead and replace it.
May 28, 2011 | Norcent Technologies LM-965WA Monitor
Computer Screen problem
Hi! there's a lot of computer screen problem. it can be a dead pixel, garbled display, vertical/horizontal lines, flickering display, dimmed display and many more. please provide more information about your computer screen problem. thanks for using FixYa.com
Jun 03, 2010 | Dell Inspiron 1000 Notebook
Compaq presario laptop screen flickering
Hi there.
It sounds like you may have a loose inverter cable or the ribbon cable behind the screen is loose.
Is the machine in warranty? I
May 29, 2009 | Compaq Presario CQ50-215NR Notebook
There is lot of disturbance on the screen
Control Panel
Display (or Display Properties)
Settings tab
Advanced
Monitor tab
under Screen refresh rate, change to 70 hertz or higher
Apply, black screen
(Your desktop has been reconfigured. Do you want to keep these settings?) Yes
OK
OK
Nov 03, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Ghosting, Flickering, Green Sparkeling Lines, Color Washout.
There is a component failure on the board inside the display. Since you did not post the model number that is all that I can tell you.
Mar 17, 2017 | LG Studioworks 700B (White) 17 in.CRT...
Flickers and Lines
you have the vertical circuit "closed" you have to repair it checking
transistors and capacitors . if you can  it this work may be at low cost - few dollars
Mar 21, 2008 | Dell UltraSharp 2000FP 20.1" Flat Panel...
Compaq presario v2000 monitor is having horizontal purple lines that flicker.
Try reloading the drivers, delete the device in device manager and reboot. It should then pick up the drivers and reload them, if that does not work I would suspect the screen is on its way out (flickering normally means the screen or its connection is bad)
Jan 26, 2008 | HP Compaq Presario V2000 Notebook
Screen flickers
Computer Video Card Support and Help The below image is an example of a screen running at 640 x 480 which means 640 ... Refresh rates below 75 Hz can produce an often-imperceptible flicker.
Monitor Help ... you may encounter a flicker or a noticeable steady line scrolling from the ... While new monitors (VGA / SVGA) do not have this issue.
Good Luck , Please dont for get to Vote/Thank You.
Dec 22, 2007 | Acer Aspire 3610 Notebook
Flickering crispy screen
maybe ur screen was put into a lot of magnetic interference. so check for any magnetic rays emitting devices like speaker adapters etc. a simple check would be to degauss( its in the screen properties). raja
Feb 28, 2007 | LaCie Electron IV 19" CRT Monitor
Computers & Internet Logo
368 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
