Question about Brother MFC 420CN All-In-One InkJet Printer
Printing too light like it's out of ink but the ink monitor shows there's plenty of ink
  • 117 Answers
Might probably be because of the malfunctioning printer head. Check with a technician to see if it is aligned correctly else you need to align the printer head properly
Posted on Oct 03, 2009
I have an epson stylus tx115 multifunctional printer with the continuous printing system installed . there is plenty of ink in the printer . A red light is flashing telling that there is not ink , I...
You must reset the cartridges chip. About " there is plenty of ink in the printer " you mean ink leakeage in to printer ? If yes, first thing is to clean the printer ( the ciss is not instaled corectly) and reinstall the ciss. The ink tank of ciss should stay at the same level with the printer.
Dec 31, 2017 | Epson Stylus Photo R320 InkJet Printer
All 8 new ink cartridges, new MT tank, nothing prints. it goes thru the motions of rinting, but no little to no ink is on paper, less and less ink each subsequent print. Most recent print has a hint of...
take your ink cartridge out from your printer. you can see at the ink carriage there are little pipes where the ink usually flow from cartridge. If head cleaning and power cleaning does not work, then try to clean those pipes by using 96% alcohol fluids and **** the pipes using something.
Sep 12, 2009 | Epson Stylus Pro 4800 InkJet Printer
Nothing appearing on paper when I am printing
on the cartridge there is a circuit if the circuit is faulty then the cartridge will not print.let there is plentty ink but due to faulty circuit it will not print.another problem is the printer driver is got corrupted so reload the driver and check out. also try giving out printer test page from pc and check out. if the circuit is faulty cartridge has to be replaced.
Aug 30, 2009 | Dell 962 Photo All-In-One InkJet Printer
Red light flashing above ink symbol but plenty of ink
hello! the ink indicator is showing because the catrigde sensors could be coated by some dirt or ink . try cleaning the catridges slot with soft material .then put it on
Jul 10, 2009 | HP DeskJet 940c InkJet Printer
Ink shows empty when toner is not even close to empty
there is one thing that if you refill the cartriage and then use again then still ink indicator shows low ink as its' ckt is designed so.
there is no problem you can print easily.
your printer will show correct ink level when you put in new cartriage.
but remember one thing that if your printer stops printing and shows message on computer that no ink in cartriage ,, then you need to reset printer counter, (this resetting process is present in your printer manual)
so no problem in printing, it shows low ink because the circuit inside it is designed soo.
so that you purchase new cartriage.
(remember : you need to reset the counter , refer to manual)
Jul 09, 2009 | Epson Stylus Pro 9800 InkJet Printer
Blinking teardrop light blinking
Blinking drop light on HP6122 signifies an ink cartridge is out of ink. There are two cartridges -- color (larger of two) and black (smaller of two). Blinking drop light only indicates either, but not which. HP6122 service software and print driver are available from HP website http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=83027&lc=en&cc=us&dlc=en&lang=en&cc=us. HP6122 service software has a printer maintenance utility which includes ink cartridge monitor. Use the maitenance service utility to determine which (or both) cartridge is out of ink. With cartridge replacement, printer should automatically print test page, then reset and be ready for printing from your computer. To clear printed documents from print que, open the HP6122 print que via control panel > printers > double-click on HP6122 driver to show que > select document tab > select cancel.
Mar 26, 2009 | HP DeskJet 6122 InkJet Printer
C88 stylus printer does not print
When did this failure to print occur? Was it sudden e.g. after changing cartridges, or did the print quality slowly deteriorate to nothing? Are you completely confident that you have good ink cartridges containing plenty of ink. What the Status Monitor is showing you in terms of the quantity of ink remaining may well be incorrect. If not sure, try a new set of cartridges, making sure you use the proper cartridge replacement procedure so that an ink charging cycle takes place. If ink starts to appear on the paper, do not carry out head cleaning cycles willy-nilly. Leave it for 24 hours to disperse air bubbles then do a couple of cleaning cycles. If it's still not perfect leave it for another 24 hours etc. Patience is required here.
If you have already done lots of head cleans with no result, and you're sure you have a good ink cartridge properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. If still nothing, report back
If this information has been of use to you, please rate it
Jan 27, 2009 | Epson Stylus C88 InkJet Photo Printer
Printing very light
I am not sure your printer cartrige with head or not, and it is color or black, it there any color lost, in general you may try
1) if the cartridge seperate print head, find a cartridge spacial clean liquor or steam water and take out the ink cartridge, put a little into the ink hole and back the ink box test it,
2) if printer ink with head, take out and put in team water (just touch water surface to the head hole for 1 Hr. and then put back and test.
3) check printer manu adjust darkness to darker.
Dec 28, 2008 | Lexmark X75 All-In-One InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
104 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
