Question about Brother HL 2140 Laser Printer
Paper jam Paper stuck on the bottom, can't pull it out
    Guru:
  • 355 Answers
Ya but slowly
Posted on Oct 03, 2009
Paper jam. Sheet printed but didn't pass through the rollers
  • Remove the paper tray completely by pulling it out towards you.
  • Now pull the jammed/stuck paper out gently.
  • If you cannot remove the paper by the above procedures,open the printers front cover to access the cartridges assembly.
  • Pull the cartridges assembly gently and slowly.This will come out together with the jammed paper.
  • If jam not cleared,open the back cover and pull the tab outwards to access the fuser unit.Remove the stuck papers here.
  • Hope this helps.Thanks!
Oct 31, 2011 | Brother HL-2040 Laser Printer
Brother 2170W, toner is stuck after paper jammed. I try to pull out the toner (even with force!) but it stuck, there is a paper at the bottom that i can't pull either. I guess this paper holds the...
If the paper get stuck inside the printer you can also remove it fro the back of it. Open the back cover and try to remove the jammed paper inside of the printer. If still the paper can't be remove try again to removed the drum and toner.
Open the front cover or pull down the cover right above the brother logo infront of the machine then hold the handle of the drum and toner assembly.Pull the drum and toner assembly towards you, just put a little force on it. Then remove the jammed paper.
Just to make sure, remove the toner from the drum by holding down the tab on the side and lift the toner out. Look for any small piece of paper inside of the drum unit. Reinstall the toner back to the drum. reinstall the drum and toner back to the machine, make sure that you here a click sound. After that close the front and back cover.
The blue light should lit up again.
Hope this helps. Thanks
May 06, 2011 | Brother HL-2170W Laser Printer
Paper jammed when loading paper, don't know how to clear jam
Welcome to FixYa.
To clear the paper Jam, follow the steps below.
1. Remove all loose paper from the paper In tray.
2. Do not pull paper jam from under the front cover.
3. If there is more than one sheet stuck in the printer, remove the paper sheet at a time.
4. Make sure no scraps of paper are stuck in the printer.
5. If there is open the door at the back of the printer.
6. Pull the jammed paper out of the printer.
7. Check again to make sure no scraps of paper are stuck in the printer.
8. Close the back door.
9. Restart your computer.
Hope this information will help.
Thank you for using FixYa.
Mar 24, 2011 | HP Photosmart 2610xi All-In-One InkJet...
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    We keep getting paper jam after paper jam (at least 7x's now) The jams seem to be toward the bottom where we take the paper drawer out. We do push the green release button and pull out the paper. We have...
    hi did u have cheq all the paper path sensors may be any one of them stucked or may be if you have old machine may you have clean whole paper path sensors thanks
    May 12, 2010 | Sharp FO-4400 Fax
    Printer pulls paper in from one corner
    this problem occurs only when one side of the paper spooler is jammed and stuck. the spooler pulls the paper causing the paper to rotate inside the printer and getting stuck.
    take professional help in clearing the jam and freeing up the spooler.
    Mar 15, 2010 | Canon PIXMA MP160 All-In-One InkJet...
    Paper keeps getting stuck
    see if the paper sensor are jam or if the machine have paper jam.
    Jun 18, 2009 | Canon Office Equipment & Supplies
    Saying paper jammed ..but no paper is jammed????
    The course of the problem could well be when you pulled the paper the wrong way out ot clear the jam. Open the machine and have a close look at the unerside of the flap. There should be a micro switch, which could well be desloged.
    George
    Jun 01, 2009 | Sharp UX P100 Plain Paper Thermal transfer...
    The machine says "paper jammed, open the front cover and remove jam papers" I have done this and turned it on and off, but couldn't find the jammed paper. what do i do? please help!!!!!!!!
    there mat be a small scrap/piece of paper stuck in the bottom of your drum unit. pull out drum and look at the bottom right in the middle. if not there, open rear door and inspect thoroughly.
    hth,
    razors
    Apr 08, 2009 | Brother IntelliFAX 4100 Laser Fax
    Paper Jam error
    try to open the cover and reseat the ink.
    the machine is trying tell you there is something stuck inside where the switch or the senser is located. usually right before the heater path. after the paper pickup roller.
    Oct 11, 2008 | Lexmark X5470 All-In-One InkJet Printer
    Brother HL 2140 Laser Printer Logo
    96 people viewed this question
    CheckitRight
    CheckitRight
    James Cagle
    James Cagle
    Samyfam
    Samyfam
