Question about Brother HL 2140 Laser Printer
Trying to remove printer cartridge but depressing green lever releases the cartridge but can't pull it out from the drum unit. First time I've tried to do this - what am I doing wrong. Don't want to be too violent in case any of the plastic breaks!
    Guru:
  • 355 Answers
Take the help of manual book
Posted on Oct 03, 2009
Ink box full
1.Turn off the printer power switch. Press the front cover release button and then open the front cover.
2.Hold the green handle of the drum unit. Lift the drum unit up and then pull it out until it stops.
3.Release the gray lock lever (1) that is on the left side of the printer. Pull the drum unit completely out of the printer.
4.Hold the green parts of the belt unit with both hands and lift the belt unit up, then pull it out.
5.Remove the waste toner box from the printer using the green handle.
6.Unpack the new waste toner and put the new waste toner box in the printer using the green handle.
7.Put the belt unit back in the printer. Match the mark on the belt unit to the mark on the printer. Push down on the green area of the belt unit to lock it in place.
8.Put the drum unit back in the printer as follows.
Make sure that the gray lock lever (1) is in the up position and put the drum unit in the printer. Push down the gray lock lever (1).
Push the drum unit in until it stops.
9.Close the front cover. And turn on the printer power switch.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Feb 03, 2014 | Brother DCP-J140W
Brother HL-2140 laser printer, where is the toner located
The toner cartridge is inside the printer's drum unit. To change the toner, make sure that the printer is on and then open the front cover by pulling it down. Then pull the drum and toner cartridge assembly out of the printer. (Take care not to touch the electrodes on the sides of the drum.) Push down on the green lever (on the left side of the drum unit). Then you can remove the toner cartridge from the drum unit.
Open your new toner cartridge and then shake it gently and remove the protective cover. Put the new cartridge into the drum unit and push down until it clicks (the green lever should come up automatically). Slide the green tab along the corona wire back and forth several times. (Return it to the home position when done).
Then return the drum and toner assembly to the printer and close the front cover. Wait until the Ready light is lit before turning off the printer or reopening the front cover.
For pictures of the HL-2140 drum and toner assembly (and the toner replacement procedure), see page 60 and subsequent pages of the manual here: http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002308/cv_hl2140_usaeng_usr_d.pdf .
I hope this helps.
Dec 26, 2011 | Office Equipment & Supplies
How do I remove the toner cartridge on HL 2040 ?
Open front cover and pull out the toner cartridge with drum unit. To release toner cartridge from drum unit just push blue lever down and lift up toner cartridge.
Feb 01, 2011 | Brother HL-2040 Laser Printer
I cannot get the drum cartridge out of the XC356 copier by Xerox. I have lifted the green tab, however it is still locked or hard to come out and I am afraid I will break same. Do I need to do something...
You can always find a soution to your Xerox problem at www.xerox.com/support Here is a link to this solution:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=22,E=0000000002703238142,K=7389,Sxi=4,Solution=obj(18692)
  1. Turn the copier off.
  2. Remove the Toner Cartridge:NOTE: If you are not sure how to remove the Toner Cartridge, refer to Related Links at the bottom of this page.
  3. Remove the Input Tray on the right side of the copier, if applicable.
  4. Slide the Platen to the right by pushing in on the grey square Release Button on the back of the copier, then sliding the Platen.
  5. Fold up the Exit Tray on the left side of the copier, if applicable.
  6. Stand the copier upright on its left side.
  7. Remove the Bottom Access Door (see Related Links).
  8. CAUTION: Be careful not to touch the red surface of the Drum.
  9. Locate the green Drum Cartridge Release Lever at the bottom of the Drum Cartridge.
  10. Lift up on the Drum Cartridge Release Lever.
  11. Pull up on the bottom of the Drum Cartridge. The Drum Cartridge will pivot upwards.
  12. Pull back on the Drum Cartridge to remove it from the copier.
Jan 26, 2011 | Xerox XC356 Copier
I was unable to loace the Toner Cartridge. Could you please tell me where to open up and how to replace the tomer cartridge? Thank you. Regards, Lisa Li
Make sure that the printer is turned on. Open the front cover. Slowly but firmly pull the drum unit and toner cartridge assembly out of the machine. Push down the green lock lever and take the toner cartridge out of the drum unit. Unpack the new toner cartridge. Hold the cartridge level with both hands and gently rock it from side to side five or six times to spread the toner evenly inside the cartridge. Pull off the protective cover. Put the new toner cartridge firmly into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically. Clean the primary corona wire inside the drum unit by gently sliding the green tab from right to left and left to right several times. Put the drum unit and toner cartridge assembly back in the printer. Close the front cover.
If you want even more detailed information, there is a how to guide with ilustrations on each step on the Brother website.
Dec 07, 2010 | Brother HL 2140 Laser Printer
I need to change the toner of my printer HL-2140 model.how can i do it?
Turn on printer,open cover by pulling the handle (the one with a depression)towards you and pull down,you can see the ink drum of the printer,grip the drum assembly out.Get a big page of newspaper and lay the toner drum on to prevent the ink of making a mess. Then you'll notice a green lever on the drum,press it down to release the toner cartridge(carefull handling must be observed).Put the cartridge in plastic bag for proper disposal.And with a new toner installed in the drum do the reverse of the procedure.
Oct 27, 2010 | Brother HL 2140 Laser Printer
I am unable to print to my HL-4040cn printer. I tried to print a the printer settings from the menu and I get a {RED} Print Unable E1 message on my 4040cn. I tried off and on several times. Same problem. ...
Follow the instruction below to clear this error.
Caution DO NOT use flammable substances or any type of spray to clean the inside or outside of the machine.
  1. Power off the printer using the On/Off switch located on the right side of the printer.
  2. Press the front cover release button and then open the front cover.
  3. Pull out the drum unit as follows:
    • Hold the green handle of the drum unit. Lift the drum unit up and then pull it out until it stops.
    • Release the gray lock lever (1) that is on the left side ofthe printer. Pull the drum unit completely out of the printer using thegreen handles on the drum unit.
      Caution Hold the green handles of the drum unit when you carry it. DO NOT hold the sides of the drum unit.
      Caution
      • We recommend that you place the drum unit on a clean, flat surfacewith a piece of disposable paper underneath it in case you accidentallyspill or scatter toner.
      • To prevent damage to the printer from static electricity, DO NOT touch the electrodes shown in the illustration.
  4. After the drum unit has been removed, carefully look inside the printer and remove any paper, scraps of paper or labels.
  5. Remove the 4 toner cartridges fromthe drum unit. Hold the handle of the toner cartridge and pull it outof the drum unit. Repeat this for each of the toner cartridges.
    Caution We recommend that you place the toner cartridgeson a clean, flat surface with a piece of disposable paper underneath itin case you accidentally spill or scatter toner.
  6. There will be four open slots on thedrum unit where the toner cartridges were installed. Examine theopenings and the black roller in each slot for pieces of paper orlabels and remove them. Also inspect the right and left sides of thedrum unit for pieces of paper or labels.
  7. Turn the drum unit over and check for pieces of paper or labels that may be stuck in or on the black rollers.
  8. Turn the drum unit back over and reinstall the tonercartridges. Hold the handles of the toner cartridges and then slidethem into the drum unit. Make sure you match the toner cartridge colorto the same color label on the drum unit. Fold the toner cartridgehandles down once the cartridges are in place.
    1. C- Cyan, 2. M- Magenta, 3. Y- Yellow, 4. K- Black
  9. Hold the green parts of the belt unit with both hands and liftthe belt unit up, then pull it out. Check the bottom of the belt unitfor paper that may be stuck to the belt surface.
    Caution We recommend that you put the belt unit on a clean, flat surfacewith a piece of disposal paper underneath it in case you accidentallyspill or scatter toner.
  10. Remove the waste toner box from the printer using the green handle.
    Caution Handle the waste toner cartridges carefully in case you accidentallyspill or scatter toner. If toner scatters on your hands or clothes,wipe or wash it off with cold water at once.
  11. Look inside the printer, especially towards the back, forpieces of paper or labels. A piece of paper or label may be stuck nearthe roller located deep at the bottom of the printer. Check the rollerand remove any paper or labels in the printer.
    Caution
    • DO NOT use a sharp object to avoid the damage of the roller. It may cause the printing problem.
    • DO NOT touch some internal parts shaded in the illustrations. Those parts will be extremely hot after you have used.
  12. Put the waste toner box back in the printer using the green handle.
  13. Put the belt unit back in the printer. Match the down1.gif mark on the belt unit to the up1.gif mark on the printer.
  14. Put the drum unit back in the printer as follows.
    1. Make sure that the gray lock lever (1) is in the up position andput the drum unit in the printer. Push down the gray lock lever (1).
      Note When you put the drum unit in the printer, match the green guides(1) of the drum unit handle to the green arrows (2) on both sides ofthe printer.
    2. Push the drum unit in until it stops.
  15. Close the front cover.
  16. Power the printer back on.
  17. Try to print again.
    If this error still remains, contact the Brother support center.
Feb 19, 2010 | Brother HL4040CN Laser Printer
How to replace the toner cartridge. Pushing down on the green lever is not releasing the toner cartridge. DCP 70 40 Brother
Remove the drum and toner unit from the machine first, then. Press the green lever while picking up on rear of the toner unit. Be careful not to grab the drum unit tray (under the toner unit), as the toner sits in a sort of tray of the drum unit.
Dec 24, 2009 | Brother MFC-7820N Printer
Error Light on Brother HL-2170W
Do not try to depress the green lever, since you need to remove the cartridge AND its base altogether. Just grab the front middle part of the assembly, pull it out slowly and steadily. You may need to apply extra force in doing so as it does take some effort to disengage the cartridge assemly from its seated position.
After the cartridge is removed, you may find some jamed paper inside. simply remove it and the printer should work again.
You may email me at stevenjoy@gmail.com should you have further questions.
May 12, 2009 | Brother HL-2040 Laser Printer
Brother HL 2140 Laser Printer Logo
73 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
