Question about LG 32LC7DC 32 in. LCD HDTV
I have white lines running horizonally from the right side of scr
Do you have any ideas?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To reset the picture you’ll need to reset all the Video menu options to their original factory present values follow this step-by-step procedure---
Press the Menu button and then use up or down arrow button to select the Video menu. Now press the right arrow button and then use up or down arrow button to select Video Reset then press the right arrow button to reset the Video menu options to original values.
If still the problem persists, then you’ll need to check for local interference such as an electrical appliance or power tool and also check the antenna. If required change the direction of the antenna.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Oct 03, 2009
Got a blue vertical line on me plasma
Ohh you have a problem with the PLASMA gass ( RGB balance failiure )..don't switch it on again run to service center....
causes ;- heavy nonstop use, heavy impacts , can have probs from LG factory , we have nothing to do the only advice is run to a service center...don't try to do it yourself ....
so i identified your prob...PLEASE VOTE ME AS "FIXYA" (Successfully solved) for my help
May 29, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Two inch horizonal (black and white) line move from botton of screen slowly up the screen. Each line is about 24 inches apart. Also at times the picture will become dark with muted our of focus images. ...
The best way to determine what is at fault is to disconnect the Denon tuner and run the signal straight to the TV. If the problem goes away, the Denon is at fault.
May 17, 2011 | Hitachi 51F500 51" Rear Projection...
Toshiba Satellite A-105 doesn't have a Numeric
Hold down the FN key at the bottom left of the keyboard & press either (scr) (prt scr) or (sys rq) key witch is at the top right hand side of the keyboard, There indicated by a white square round them.
Jan 16, 2010 | Toshiba Satellite A105 Notebook
Horizonal lines
Unfortunately you can't.
This is what happens when you blow pixels on your monitor.
If it is still in warranty this will be covered.
If you are outside of your warranty then you will need a new monitor
Sep 26, 2009 | Acer AL1916W 19" LCD Monitor
Line across screen
scane for virus and reinstall the operating system
May 30, 2009 | Computers & Internet
31'sanyo tv analog has a white horizonal line thru it
There is a failure in the vertical amp section. This can be the main output IC, or any of the support components in this area.
An experienced tech can troubleshoot the set, and determine and service the fault.
Jerry G.
Apr 27, 2008 | Sanyo DS31590 31" TV
T.V. has no picture
I noticed a bright horizonal line about 1/4 in.wide centered in the middle running from side to side. Audio is fine. This just all of a sudden happened it was not gradual. it is due to vertical section failure. please minimise bright to protect crt. solution. solution 1 check supply to vertical section. 2 check for ic failure in vertical section 3 check vertical output section parts. Is it fixable or dumpable?? Please HELP!!!! yes it is fixable it is common problem not major one. good luck.
Oct 07, 2007 | Televison & Video
Thin horizonal line in middle on dark screen
The several thin white lines at the top of the screen is the warning that the vertical output IC is not getting the boost voltage it needs to run correctly. The IC cannot operate for long like that and shorts out inside, which is when the vertical collapses altogether and you get the thin white line through the center of the screen. The good news for your son is that he had nothing to do with that, and it has nothing to do with the cable F connector. The set needs to be serviced by an experienced tech who will restore the boost supply and replace the vertical output IC, and when I do that I charge $75 but techs in your area will vary, so be sure to ask around.
Jul 26, 2007 | GE 24GP653 24" TV
Horizonal White Line
Your problem could be one of the common ones as this set has loads of bad solder connections. Your problem is most likly the verticle output IC connections or the B+ feed componets have bad solder connection on them. In some cases though the Output IC is defective and will need to be repalce. if you have no soldid state repair or soldering skills play it safe and get a pro to assist you in this repair. It should not cost you more then a hundred bucks or so and thats the high end. good Luck, And Merry christmas.
Dec 25, 2006 | GE 19GT270 19" TV
LG 32LC7DC 32 in. LCD HDTV Logo
66 people viewed this question
Computer Repairing
Computer Repairing
