Question about Panasonic Audio Players & Recorders
Dvd/cd player model no dvd-cv52, displaying HO7. have unpluged from power, and cleaned disc.
  • 189 Answers
HELLO
I have just recently posted a cure for this - but here we go again. Fault H07 is the fault code for the spindle/disc motor and to cure it do this!
With the lid of the player removed, locate the spindle and where the motor shaft goes into the motor itself, use a little light oil or WD40. Don't drench the area or you'll really have fun cleaning it up!
Let it soak in a while and try it again - you should now find it works.
I am now finding quite a few owners of Panasonic DVD players are starting to get this message on the display. The same happened to me!
I wish you luck! (:-)
Posted on Oct 03, 2009
Testimonial: "good job tonygill, it worked a treat."
  • Tony A Oct 04, 2009
    Thank you for your kind testimonial. I had to do the same with my DVD/VCR unit Panasonic NV-VP31 it was chucking out the same error - glad it worked for you too!
    CHEERS.
Panasonic DVD-CV52 Multi-disc DVD Player? H07 error
HELLO
Ah, the infamous HO7 error! This is to do with the disc motor and there is a solution which MIGHT work for you (it did for me).
You need some sewing machine oil and a precision oiler. Don't be tempted to use WD40 as it will get everywhere and is not really suitable. Just put a couple of drops into the spindle (disc) motor. Where the shaft goes into the motor and leave it for about an hour or so then try it again.
The only real solution is to replace the disc motor, but this can be a fix depending on the situation. Give it a try - what have you got to lose?
GOOD LUCK!
Mar 15, 2010 | Panasonic DVD-CV52 DVD Player
Error code ho7
email me your email address and i will show pic's how to my email address is markusmaritz@yahoo.com plzzz email me i will help but for now i will help step for step.
1)open your driver and pull out the plug.
2)nou the driver is open pull of the cover infront of the dvd player.
3)nou screw open your dvd player and take of the cover.
4)screw of the driver take it out.
5)nou clip of the lazzer and take it out gently.
The top resen of the HO7 is problem is it movement is dry use selicone spray to spray it there will be a thing that makes it spin but for screen shots plzzzz email me.PLZZZ RATE ME FOR NOU BECOUSE THIS PROBLEM IS NO MORE IT IS SOLVE FOR SHORE.
Nov 08, 2009 | Panasonic DVD-CV52 DVD Player
Does not play DVD and displays HO7. We have tried
This normally means the spindle motor is faulty,there is a little coupler and this splits,this will cause the machine not to load.
Oct 07, 2009 | Panasonic DVD-RV32 DVD Player
ON A DVD-CV37 PANASONIC DVD/CD PLAYER KEEPS GIVING
This normally means the spindle motor is faulty.
Jul 21, 2009 | Panasonic Televison & Video
HO 7 error on a Panasonic DVD/CD player.
I got mine to work. I looked around a bit on the web, and it seems that HO7 means that the disc isn't spinning. Whether it's the motor that's bad, or just dirt etc, the problem is that the disc doesn't spin. I took the cover off of mine and blew out the dirt. Then i gave it a spin by hand to get it started. I'm not sure if I just had dirt clogging up the gears, but at least it works (for now). Good luck on yours.
Jan 03, 2009 | Panasonic DVD-RV32 DVD Player
Wont read disc-error message HO7
Please chande your dvd lense you can purchase it from the market please note the lense number and may be the mechanisum problem.
Jun 10, 2008 | Panasonic DVD-CP67 Multi-disc DVD Player
Error code H01
I opened up by Panasonic dvd-cv52, which I purchased in Dec 2002 for H07.
The H07, based on research, indicated that the spindle motor had an issue, a post I found suggested trying some 3-in-1 oil.
I tried this and it worked (note, pop the top off firstm then power up the unit, then press the open button, then unplug the power, this will make it easier to lubricate).
Once I had done this and powere back up, I got h01.
Turns out I neglected to put back the elastic that is used to spin the carosel for the dvd's (I have a multi dvd player).
I would check to see if there is an elastic in place to spin the carosel, maybe your broke (assuming you have a multi carosel also)
Good Luck
Louie Whote
Oct 27, 2007 | Panasonic DVD-CV52 DVD Player
check out this link I think this information will help you. http://www.ledcar.com/pdvdh07/
Sep 17, 2006 | Panasonic DVD-CV47 Multi-disc DVD Player
Getting "HO7" when loading disc
After calling Panasonic, they suggested pressing the reverse skip (<<) button, the pause button and the open/close button all at the same time. The DVD player will then say "initialize." Turn off the player and unplug it for about 1-2 minutes. Plug it back in and turn on the player and load a disc. If the HO7 error code pops back up, you need to take it to a dealership for service. Or, at the price of DVD players these days, just get a new one - which is where I'm going right now.
Aug 21, 2006 | Panasonic DVD-RV27 DVD Player
Error Message H07 - what is it?
The last time I opened up my Panasonic DVD-CV52, I looked at the little white bush on the motor spindle, it has a small spring which presses against the side of the bush. I can see no purpose for this spring/bush other than to provide some drag to the motor. Anyway, I removed the spring, so that the bush would no longer drag against the shaft, that was a few years back, and I haven't had a problem since. Of course a temporary solution is to oil the bush!
The www.ledcar.com/pdvdh07/ link mentioned above provides an excellent pictorial guide to disassemble and reassemble the player.
Jun 09, 2006 | Panasonic DVD-CV52 DVD Player
201 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
