Question about Fuji FinePix Z5fd Digital Camera
Have received 3 separate NP40 compatible batteries from supplier - none of which indicate charging in the camera itself - blinking red charging error - none operate the camera. My original battery works immediately. Have been assurred no battery batch problem. Have tested voltage of all 4.21v-4.27v. My original battery shows 4.21v. ???
SOURCE: Battery life
I bought this type of camera a few months ago.  Instantly I noticed that is wears down batteries.  I would not get to take a lot of photos if I was on a vacation trip.  I have to keep the two batteries on a charger if I wanted to take many photos.  This is disappointing.  I have no solution for you.  However, if someone does have a solution, I, also would like to know it.
Posted on Nov 01, 2007
  • 27 Answers
SOURCE: Camera will not come on
try to use another battery and if it does not work please contact the manufacturer to get the camera replaced.
Posted on May 22, 2008
SOURCE: FUJI F20 Won't Power Up - Good and Charged Battery
Fuji FinePitteryx refuses to power up,even after new lith. batteries were installed
Posted on Oct 09, 2008
SOURCE: battery seems to be charged but when you try to focus it blurrs
hi there it may look like ccd prob try fuji tech help they may tell u exect stuff coz mine have some kind of same prob and i send it for repair and they said it was ccd fault
Posted on Mar 01, 2009
Steve5
  • 423 Answers
SOURCE: Card error with compatible memory card (Z30fd - Fujifilm)
Try doing a "format" of the card through the set-up menu.
Posted on Aug 08, 2009
Camera won't charge red light is on but the green light doesn't come on . What is my problem ? Could it be the battery
hi Kenny.
With most cameras, an amber, yellow, or red light indicates a battery that's currently charging. A blue or green light usually means the battery is charged. A blinking light sometimes indicates a charging error; other times, it indicates a battery that is still charging.or faulty battery.
have you tried,take the battery out and then put it back in?.
make sure the battery is seated.and its making a good contact.
Dec 01, 2017 | Green Cameras
Scooter charges but doesnt run
could be one of many problems is the battery indicator blinking on the control box if so
check on/off switch
check seat switch
free wheel switch located in the slot on the back right side of the battery cover check for proper position
also there are 2 small lights just to the lower left and lower right of the battery indicator that will blink a error code examples are 1blink pause 2 blinks or 2 blinks pause 2 blinks and many others if you have the error codes contact amigo for a help 1-800-my-amigo
Aug 24, 2012 | Amigo RD 3-Wheel Scooter w/33AH Batteries...
Redl ight blinking but battery(ies) fully charged
Flashing red could indicate dew sensor (camera has condensation/ damp) or other fault. See your manual Troubleshooting section.
Mar 08, 2012 | Video Cameras
What does it mean when the charger red light keeps blinking when I try to charge the battery?
Hello sandra,
Unfortunately this generally means that the battery has gone bad, and needs to be replaced. Luckily they seem to be very reasonable in price.
http://www.amazon.com/Casio-NP-40-Battery-EXILIM-Cameras/dp/B00020KPB2/ref=sr_1_1?s=electronics&ie=UTF8&qid=1313359400&sr=1-1
Good luck.
Aug 14, 2011 | Casio NP40 Replacement Lithium Ion...
Red "faulty battery" indicator with newly-charged Batteries
You can buy new batteries and buy the one it says to buy on the package.
Apr 09, 2010 | Canon Elura 100 Mini DV Digital Camcorder
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
The batterie charger for my Casio Exilim EX-Z77 has a blinking red light instead of a continous red light when i try charging the batterie. also, it doesnt appear to be charging it at all. Left in in for...
The blinking light indicates a charging error. Try connecting a 9 volt battery to your camera battery. Sometimes if the battery has lost all charge, the charger doesn't recognize it properly.
Dec 05, 2008 | Cameras
Digimax i5 problem charging battery
■ Charging LED
Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
 Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
If the charging LED doesn't turn to green could mean a signal that the battery is bad or can't charge 100% anymore = too old, needs a new battery. Hope this helps.
Jul 06, 2008 | Samsung Digimax i5 Digital Camera
Charger red lite flashing. Camera comes on for one second and shuts off
Here's a copy from the owners manual:
■ Charging LED
Green LED is on = Carging is complete
Another charging error is when the batteries are so depleted, they won't charge up to 100% anymore = red light doesn't go out and remains on for too long, means get a new battery.
Jun 10, 2008 | Samsung Digimax i5 Digital Camera
Same Problem
Hello, it was:
■ Charging LEDCharging LED
Or if the red LED remains on without turning green could mean a bad battery that no longer charges to 100% - get a new battery. Hope this helps
Jun 05, 2008 | Samsung Digimax i5 Digital Camera
Fuji FinePix Z5fd Digital Camera Logo
19 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
