Question about Sony FD Trinitron WEGA KD-32FS130 32" TV
Tunes Terrestrial analogue stations but will not tune digital stations. Help!
  • 58 Answers
If this is in the UK, Have you got a Modern, Fit for Purpose, Digital spec Airiel properly instaled with good cable?
If not, get it done.
Posted on Oct 03, 2009
Testimonial: "Thanks for your response. Yes I do have a digital aerial and all was working well until I had to retune the TV for the new Digital broadcast standards"
  • chris_kyan Oct 03, 2009
    Hi, You may have separate analog and digital tuner menu's. (Not sure it would have)
    Did it show a digital tuner scan progress bar as you re scaned?
    Have you an airiel booster and was it on as you re-scanned?
    Will another TV work on that airiel socket?
    Certainly try it again, Full Re-scan.
    Good luck
You need to get the manual for this its a bit tricky and involves the blue button on the remote through the menu to retune digital, i sat for half an hour fiddling before i got the manual out and then had to read it a couple of times just to make sure.
Posted on Nov 12, 2009
The recorder is 10 years old. All appears to work OK. But on retuning the stations it finds none. Is this because we have moved over to digital and the recorder has an analogue tuner? any fixes?
Hi I have a Panasonic DVD recorder analogue u can connect a digital set top box just tune in the box & set you're input on recorder cheers
Mar 03, 2016 | Televison & Video
Just got digital service, can't tune the stations
Check and make sure that your TV has compatibility tuner [analogue / Digital] provided inside. If not, you have to buy a digital to analogue converter to receive digital transmission. Refer the device user manual for details. If f the tuner is digital/analogue compatible; and you can't receive digital channels, it is faulty. The tuner have to be replaced. http://electronicshelponline.blogspot.com/
Dec 06, 2015 | Televison & Video
TV won't recognize channels. Help
Without knowing where you are in the world let me ask
are you trying to tune analogue or digital stations
Here in australia analogue tv has been discontinued and all transmissions are in digital.
your tv even though it says HDready does not have a digital tuner
so if you are scanning for digital you won't have any luck
If i am correct the only option will be a digital set top box or a newer model tv..
Len
Oct 13, 2014 | LG 42PC3RA 42 in. HD-Ready Plasma TV
How come i cant find the radio for my Phillips go gear vibe?
From the main menu, select the icon that looks like a little radio
To search for the next stronger signal, press and hold the up or down arrow
To fine tune the frequency, briefly press the up or down arrow
From the main menu, select to enter
radio mode.
• The earphones cable acts as FM
antenna.
Manually tune a radio station
While in mode, you can manually tune to a
radio station:
1 To search for the next stronger signal,
press and hold / .
2 To fine tune the frequency, briefly press
Auto-tune preset radio
station
The auto-tune feature of GoGear Vibe helps
you find radio stations and save them under the
preset numbers.
1 While in mode, select [Auto tune] >
[Yes].
»» The radio automatically tunes radio
stations and saves the frequencies to
presets.
»» There are 20 presets available.
»» To stop auto tuning, press .
»» To exit radio, press and hold for 2
seconds.
EN
Jan 09, 2011 | Philips GoGear ViBE Digital Media Player
We have a phillips model #32PFL5332D/37 it has a flat screen. Is it digital or analog
Yes this TV should tune to both Digital & Analogue reception. See below I have copied an extract from the Philips technical site which gives you verification that this has digital capability. Hop this is of help to you. Next to analog NTSC broadcast reception, your TV has an integrated High
Definition TV tuner which receives, decodes and displays terrestrial ATSC and
unscrambled cable (QAM) signals.
HDTV quality is only reproduced when a broadcaster or cable provider broadcasts
HDTV signals.
Jul 24, 2009 | Televison & Video
Digital TV Stations
The term digital in this case is the mechanism used to tune in stations. Rather than making adjustments using a front dial to fine tune the stations, there are digital circuits that will lock in the station. The "digital" stations you are referring to now are the over-air digital broadcasts what use a different method for transfering the signals over the air. These stations now broadcast a digital stream of information rather than an analogue TV signal. If you are using an antenna for receiving these over-air broadcasts, you will require a converter.
Dan
Sep 18, 2008 | Disney 13" TV
Deleted too much?!
Try reformatting.
If nothing changes, then cold reset.
Feb 13, 2008 | SanDisk Sansa m240 MP3 Player
Bose Wave radio
Use the tune arrow buttons on the remote - left arrow tunes down; right arrow tunes up.
Once you have the right frequency for the station you want to preset, press and hold the number button that you want to store it under for around 5 seconds
Jan 10, 2008 | Bose Wave Radio
Sony FD Trinitron WEGA KD-32FS130 32" TV Logo
164 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
