Question about Epson LX-300+ II Matrix Printer
Can not print with Epson LX-300
LX - 300 does not have an USB output, it has only parallel out put. It is also not PnP. My new system has no parallel port. I have a USB to parellel cable (bf 1284).
Both are installed but printer does not print.
What should I do?
  • 526 Answers
The USB to parallel converter does not always work.
You should buy a Parallel port for your computer if you have can extra slot inside the machine. The cost for the parallel port is usually under $20.
thanks adi
Posted on Dec 12, 2009
Testimonial: "Yes that can be done but you have to have extra slot.So I wondered if some software would do the trick.Otherwise your solution is the only way! Thanks"
Epson lx-300 parallel to usb printing problem
Make sure driver for Parallel to USB adapter is installed properly, this doesn't guarantee that it will work. Suggestion is, check for interface availability for Epson printer if you can change parallel interface at the back of it to USB interface. Call Epson for details and availability.
Sep 21, 2012 | Epson LX Office Equipment & Supplies
Im using a windows 98 SE OS and using Epson LX-300+ii and when i try to print either from MS-DOS or Windows the output is still garbage. need help
I'd check the printer emulation. One of the choices in the printer's internal menus is which kind of printer commands it uses. In this case, the choice is between Epson's own "ESC/P" commands or the IBM 2380's.
Find the instructions under "Using the Control Panel" in the manual, which you can download here.
Another possibility is a bad cable. A USB cable will probably either work fine or not at all, but a parallel or serial cable could have one broken wire inside and cause the printer to put out garbage.
Mar 10, 2011 | Epson LX-300+ II Matrix Printer
I have epson lx 300+ printer and bought a new cpu without any parallel port... now my printer does not print documents even a successful printer driver installation
You can install a parallel port adapter on you computer.
This WEB site has parallel port adapters that suit your computer.
http://www.ieci.com.au/products/product_list.asp?class=3&basecat1=50
Since you did not provide details of your computer I cannot advise you exactly what adapter you need, but you can select or ask the supplier the correct one for your computer.
Jan 29, 2011 | Epson LX-300 Matrix Printer
My epson LX 300+ was already installed but will
First, you must install the driver of lx-300+. open control panel, printer n fax then find epson lx 300+. Don't forget to test what port that your lx-300+ support. LPT1. Then print test page...If your printer run... it's finish... you have succses instal the printer...
Jul 19, 2009 | Epson LX-300+ II Matrix Printer
How do i install an epson lx 300 printer to a vista machine using a parallel to usb converter? i can't locate nor create usb 001 port with the driver cd of the said printer.
1. Start
2. Settings
3. Printer and Faxes
4. Add a printer
5. then Next
6. then Next
7. then Next
8. then Next
9. select Manufacturer name : Epson
10. select Printer name : Epson LX-300
11. Next
12. Windows will automatically install the driver for your Printer
Jun 21, 2009 | Epson LX-300+II Matrix Printer
Can print correcly
plz check all the settings, language setting must be check , after that if the problem not solved then uninstall the driver and again reinstall the printer driver
May 27, 2009 | Epson LX-300+II Matrix Printer
XP Cannot able to print on Epson LX 300+
This is XP's parallel port problem
try changing the settings:
find: Start Button, Control panel, System
Device Manager, then Ports !
Change the settings for LPT1 to enable
Detection of Legacy Plug and Play devices
o and Here is the service manual for this printer:
http://ca.geocities.com/artiedc/LX300SvcMan.pdf
Ed
May 25, 2009 | Epson LX-300 Matrix Printer
Windows xp printer install
Hi, Have you tried the Epson driver "ep10759.exe"? It is available at http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14250&prodoid=8192&infoType=Downloads&platform=Windows It this still doesn't workout for you, pls post back as to how you connect the 810 to your PC (USB or LPT/Parallel), Good luck and kind regards.
Oct 08, 2007 | Epson LX-300 Matrix Printer
Epson LX-300+ II Matrix Printer Logo
1,607 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
