Question about Mitsubishi VS-5043 50" Rear Projection Television
Mitsubishi VS-585R
I have a Mits 50 inch big screen, when I power it up it comes on for a second then shuts down.
Can anyone help me.
Thanks
Anthony
    President:
  • 4,402 Answers
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Posted on Dec 21, 2007
Anyone know how to fix a Panasonic Viera 50" Plasma that powers off a couple seconds after powering on?
tThe diagnostic circuits is shutting your TV down. In most cases the set will shut it down immediately. Apparently your set hasn't shut completely down yet. When you turn your TV on the diagnostic circuits send a low voltage, low frequency signal through all the circuits and depending on how they come back whether the sets powers up to full power. If a problem is detected it will shut down to protect the other circuits. It sounds like you might have some capacitors going bad on your power board. A capacitor that is going bad would let it come on for a few seconds then the diagnostic circuits would see the capacitor getting further out of tolerance and shut the set down. If you are a DYS type person you might want to lay it flat of it;s face and remove the back. A bad capacitor will be bulged out on the top. are Replace capacitors with the exact uf value and if you can go above the rated voltage but never below., If this isn't the problem then it is probably the main board (the board where your cable hooks up to), There are other things that cab causes for this but I would check the capacitors first.
Col. Dana Gillespie
Sep 09, 2014 | Panasonic Viera TH-42PZ80U Plasma TV
I push the power button the kocaso screen comes on and tells you injoy colorful life and then goes to a screen that said android for five or six seconds and then shuts off well it does not shut off it...
I used this link and found it had a 50/50 chance of working...
http://forums.androidcentral.com/android-4-1-4-2-4-3-jelly-bean/347622-kocaso-m1066-tablet-system-ui-has-stopped-working.html
I know it's not for your exact model, but manufacturers often have the same method of hard reset for all of their devices. Specifically:
"The button to hold down is the menu button next to the home button. With it powered on hold down tthe menu and power buttons until it goes off, then release the power button and then hold it again while holding the menu button. An android with an exclamation and triangle will appear. Tap the power button and the menu for reset or updates appears. Select factory restore and follow instructions then select reboot at next screen and you`re done."
Hope it helps u too
Chadman
Dec 27, 2013 | Kocaso M M9100 9-Inch 8 GB Tablet
I have a 42 inch Gallevia model GV 42L. When TV is initially turned on blue screen comes up for about 2 seconds, it then goes black and a screeching noise comes through both speakers on the TV. No...
The power source has failed - the sound is the source that autooscillates because even its protections have been damaged and are no longer capable of safely shut it down.
It's a big failure so call a repairman, ther's nothing more you can do.
Aug 31, 2010 | Vizio SV470XVT 47 in. LCD TV
50 in mits tv wont power on. green reset light
Hi, It's either the lamp or the power supply capasitors. Thanks.
Sep 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
T.V.powers up I get light blue screen then shuts down mits.wd-625
not bulb component is damaged in power supply serction shutting down to protect other components
Sep 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
TV does not power up
I have mits 35" CS 3505 will not turn on... just turned off and thats all she wrote,,, what is the estimate cost of the deflection circuit board
thanks
artie
Jul 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Immediately Shuts off with blinking light codes
I suggest doing a google search using the tv model # and brand.
I have learned myself that different big screen tvs seem to each have their own common problems. I have read before of power supply issues that cause what your describing.
Mar 11, 2009 | Samsung HL-R5078W 50" HDTV
Replacement Parts - Rear Projection TV Mits. WS-48511
possibly . here is the link I am one of the support techs there and we have alot of the 50 inch mitsubishi and we resize the screen assemblies to fit various mitsubishi models . Heres the link.
http://servicemanuals.vstore.ca/
Mar 31, 2008 | Mitsubishi WS48511 48" Rear Projection...
Problem with philips 50p8341 big screen tv
if in 20 seconds maybe you have lost contact at the main board hot side section!
Oct 03, 2007 | Philips 50P8341 50" Rear Projection...
Televison & Video Logo
232 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
